Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 204 votes, 5.00 average. Display Modes
Old 09-14-2012, 10:01 PM   #761
bin01123
My Ride: 2001 540i
Originally Posted by jeffb325@DynavinSolutions View Post
Dynavin changed something with the touchscreens that required a different set of drivers, so there is a ROM for the older units, and a ROM for the newer units.
Jeff,
I'm still rocking my Windows version of the Dynavin unit. Are there any updated maps for 2012 or late 2011?
bin01123 is offline   Reply With Quote
Old 09-15-2012, 08:09 AM   #762
BMWMad
My Ride: 323Ci E46
Question Dealer in Shanghai?
Hi guys,
I am not sure if this is the right tread but anyhow. I would like to upgrade/replace my Dynavin E46 V5 due to I got a lemon version from a dealer in UK that disappeared one month after I bought my unit. I will be till Wednesday Sep 19th in Shanghai, does anyone of you know a good dealer here (as good as Jeff ) I want to buy the D99 version.
Thanks in advance!
BMW 323Ci E46
BMWMad is offline   Reply With Quote
Old 09-16-2012, 11:08 AM   #763
kaikkonen
My Ride: E46 320d
Humm. I bought that D99 and I like it. But I thought that it would have a bit nicer radio and other controls like:
but no :/
I haven't found yet different solution for that.
For android I have found modified firms.
Does someone have a way to change that UI?
kaikkonen is offline   Reply With Quote
Old 09-17-2012, 01:23 AM   #764
Pahkis
My Ride: E46 330D
Hello there guys! Got myself the D99 WinCe Dynavin for my E46 bimmer and I have to say I'm really happy about the device. But a couple of questions... first, is it at all possible to change the "splash screen"/boot logo to something else? I'd kinda like it show something bimmer related
And then the other bigger question. About the navi-side of the device. The navi-program has frozen a couple of times in such a way that the only way to wake it up was to reset the device by for example unplugging the power cable. Can this be related to the currently low gps signal strength? I'm gonna put the gps-reciever box to a better place, right now the gps signal strength isn't the best possible. Have you guys experienced this navi freeze problem at all? When the navi frozes it just shows a blank screen and nothing happens... I'm using Sygic's latest maps.
Pahkis is offline   Reply With Quote
Old 09-17-2012, 11:25 AM   #765
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
but no :/
that is a pic of the older D95 unit.... Ive never heard anyone say they like the D95 radio interface more than the D99....but I suppose its a matter of opinion. But to answer your question, no it cant be changed.
Originally Posted by bin01123 View Post
Jeff,
No.
for the splash screen.....in the D99 there is a setting in the "hidden" factory settings menu for that, there was a sheet with your manual that explained the factory settings menu.
Your GPS problems are not from the antenna but dont sound good..... maybe a defective nav card?
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 09-18-2012, 05:50 AM   #766
dayusmc
My Ride: 01 325ci & 06 325ci
Believe it or not... After having both the v5 and D99 unit in our cars for awhile - I like the older interface better. The old unit matchs the car better...
Kyle
dayusmc is offline   Reply With Quote
Old 09-23-2012, 03:54 PM   #767
Georgeramosjr
My Ride: 2003 X5 3.0
Hello all! I'm new to the forum but I've done a lot of reading with respect to the D99 unit which I have in my 2003 BMW X5 E53. I actually bought this car about three months ago with this head unit installed. When I purchased it everything worked fine. The radio reception worked well with Am/FM no matter how hard I pressed display or the frame around the radio it would never reset and it wouldn't bring up is volumevand color*settings. However, I had a guy install a backup camera, big mistake! After the installation if I hit a large bump, press the display too hard, or press the plastic frame around the display too hard, the volume setting comes out or if I was off completely. This wasn't happening before the installation. I'm unsure if the wires or crimped or pinched, or if there's an issue with the actual unit itself. It's currently running the Windows CE version of the operating system. Also now it is very difficult for me to get a.m./FM reception at all. *I ensured that the radio adapter is plugged into the*head unit as much as possible. But it doesn't seem to be flush, it seems like it might be a little loose and maybe some play there. But even when I hold him tight and put it in place and test the frequency I don't get reception anymore. This wasn't always the case. I'm really unsure about what to do, I'm wondering if anyone has had a similar experience. Enclosed is a video with the symptoms of turning on and off
Georgeramosjr is offline   Reply With Quote
Old 09-24-2012, 02:46 AM   #768
syd9d
My Ride: 2003 E46 M3
ROM Update....
Hi Jeff,
I've had my D99 Dynavin for a month now and I have worked out the kinks by now and I love it. I did see that there is an update for the ROM on the Dynavin Android page. Is this for both the Android and WIN CE version? I have the WIN CE version and I was wondering whether I need to download that update.
Will this update fix the iPod Playlist reordering problem because that can really be annoying, if not will there be an update in the near future for the WIN CE D99?
Thanks and keep up the good work.
Sydney.
syd9d is offline   Reply With Quote
Old 09-24-2012, 11:19 AM   #769
J&T Distributing
My Ride: BMW
Thats not a D99.....its an old "V5" D90 E39 unit. When your installer took the unit out and put it back in he did so in a way that is putting a lot of stress on the front panel, to the point where the plastic bezel is putting pressure on the edge of the screen. Might have even bent the metal frame on the back of the panel. In addition some of the wiring may be pinched or have a bunch of pressure on it. In any case, stuff got screwed up, you need to take it out, inspect for damage, and carefully put everything back in.....although things might be screwed up more than that, impossible for us to say from here.
The antenna or antenna adapter probably got damaged at the same time. Inspect and fix.
Originally Posted by syd9d View Post
Hi Jeff,
Sydney.
ROMs are android things, not for WinCE. Dynaivns sort things alphabetically. I would not expect that to change.
Old 09-27-2012, 02:05 PM   #770
J&T Distributing
My Ride: BMW
Dynavin has made some changes with the latest batch of D99 units, they are calling them D99+, I started a dedicated thread here: http://forum.e46fanatics.com/showthread.php?t=946958
Old 09-28-2012, 12:34 AM   #771
Pahkis
My Ride: E46 330D
Okay, I got the splash screen changed so that's all good.
As for the GPS problems, they are getting worse. Now I haven't even been able to reset the device by unplugging it so the GPS is frozen. I did get a new screen in the NAVI mode, it was a blue screen (well, this is a windows based device after all with the text "welcome to navigation". But that didn't do anything, the screen didn't respond to touch.
A friend of mine had IGO Primo nav software so I tried that one, but no luck. So it seems that the gps problems aren't related to the nav card. Ah this is so frustrating because otherwise the D99 really rules.
Old 10-02-2012, 12:46 PM   #772
330touring
My Ride: 330d touring
Hi again, Iíve been using my d99 for almost a year now. The BT has been working great. Last week my wife paired her phone to the d99 and, ever since then, it has rejected my phone. My phone connects at first, but after a few second it disconnects. If I try my phone on my old BT earpiece it works fine, so I donít think anything is wrong with the phone (have reset my phone).
Any idea whatís up with my d99?
Cheers,
ojo
330touring is offline   Reply With Quote
Old 10-02-2012, 12:48 PM   #773
BigDRick323
My Ride: 2000 323i
I still have not been able to get navigation side to work. Considering moving on to something else. I have tried just about everything.
Sent from my VM670 using Bimmer App
Old 10-02-2012, 02:16 PM   #774
J&T Distributing
My Ride: BMW
Cheers,
ojo
Delete the pairing from your phone and re-pair
Android unit? As I have mentioned before I cant help my competitors customers, not enough time, not a good business move either.... But I hate to see you give up on it just because you cant figure this out and you are not getting any help from your dealer (assuming). From looking at your previous posts all you need is the special formatting tool for the SD card. Email me about it and I can email it to you.
Old 10-04-2012, 06:33 AM   #775
bocaj
My Ride: 320D 2002
Sygic upgrade
Hi there,
Does anybody know if I can upgrade my D99 WINCE to Sygic version 12 in stead of version 10?
Regards
Bocaj
bocaj is offline   Reply With Quote
Old 10-04-2012, 05:37 PM   #776
Saginawesome
My Ride: 2003 330 xi
iOS 6 issues
Has anyone else been having trouble with BT streaming since updating your iPhone to iOS 6? I have a D99 (not plus) and before the update my phone would successfully pair about 90% of the time, but since switching over to iOS 6 it's about 30%. I saw that someone in the D99+ thread was having an issue since upgrading to a new iPhone 5 but his was just loss of the track forward button. Just curious to hear if I'm the only one or if others are having the same issue. Thanks!
Saginawesome is offline   Reply With Quote
Old 10-04-2012, 05:49 PM   #777
J&T Distributing
My Ride: BMW
I think "that person" was me......yes it seems that iOS6 definitely has a few issues with bluetooth. I have not seen any pairing issues but the track buttons dont work. If its not pairing regularly, delete the pairing and repair.
Old 10-05-2012, 01:19 PM   #778
KamPow3r
My Ride: ....
I do apologize if this is a repeat question but I do not want to go through 40 pages of reading and if I can please skip that step, that be great!
I Just recently installed my Dynavin D99 to my E92 335i and have been having trouble with my Bluetooth connection. When I go to Bluetooth settings and click the "Turn On" button it trys to scan and then nothing happens after that. I am actually able to connect my phone but with the Dynavin I believe you are able to control music through your phone as well ... is that correct? Cause I really want to take advantage of that feature.
Any help would be GREATLY appreciated!!
Thank you!!
"Aerodynamics are for people who cannot build engines..."
- Enzo Ferrari
KamPow3r is offline   Reply With Quote
Old 10-05-2012, 04:56 PM   #779
J&T Distributing
My Ride: BMW
you are in the wrong area, there is no bluetooth hardware in the android part of the dynavin, that menu option is just part of the android OS, doesnt mean there is any hardware attached to it. The bluetooth is part of the radio side of the unit, press the right side knob and the bluetooth screen will pop up, select music on your phone and you should be good to go.
Old 10-05-2012, 05:24 PM   #780
KamPow3r
My Ride: ....
OK got it! Thank you!!
- Enzo Ferrari
d90, d95, d98, d99, d99 navigation system, dynavin, dynavin android, dynavin d99
