Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 09-16-2012, 06:56 PM   #1
DylloS
My Ride: nothing
Ripping up carpet help
I plan on ripping up my carpet this Saturday and have no idea where to begin. I'm sure I could google around but I'm curious what people here can tell me.
My plan is to get a box cutter and rip it up but I'm wondering what else I need to get or look into.
DylloS is offline   Reply With Quote
Old 09-16-2012, 08:20 PM   #2
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Send a message via AIM to JonJon
You'll have tack strips all along the perimeter. Start by pulling the carpet up there to loosen it.
Depending on how big the room is, square, etc
You might want to just roll it up in one shot. If its not square, too large, etc. pull it up off the floor and cut strips of 4 foot. If you don't care about the floor under it, just run a sharp CARPET BLADE (not a regular razor) without lifting it.
Roll it up... Carry it out.
There will be padding under it. Hopefully it comes right up but really old stuff might stick to the subfloor (sucks!)
WEAR A MASK.
PS: WEAR A MASK and consider googles
JonJon is offline   Reply With Quote
Old 09-16-2012, 09:02 PM   #3
DylloS
My Ride: nothing
WEAR A MASK.
I plan on cutting sections. Probably about that size. I was going to by a mask, and box cutter but I guess I'll look into the carpet blade. Also something to pry the tack strips up. Hopefully I can get this all done in a few hours.
Old 09-16-2012, 10:35 PM   #4
chivo328
My Ride: 328/330/633/M5
Also consider picking up (sorry don't know what it's called) one of those flat long handled scrapping tools to remove any nails that might not come up with the tack strips. basically you use it like you would a broom. You might also find that they used stapels to secure the padding and this device makes removing these quicker and easier.
chivo328 is offline   Reply With Quote
Old 09-16-2012, 11:12 PM   #5
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Regular razor blade will work, but a carpet blade is much sharper and won't dull out as fast.
Tack strips, nails? Get a wonder bar.
It's a tool every man should own next to a hammer
And duct tape
http://www.amazon.com/gp/aw/d/B00002X1XT
I've used this thing a thousands times for almost everything.
It even saved me from amputating my arm once too.
Block wall fell on me and I used it to get my body loose.
Old 09-17-2012, 10:32 AM   #6
DylloS
My Ride: nothing
thanks guys. I'll let you know how it goes. This isn't going to be fun but I have a few guys coming to help out.
Old 09-17-2012, 02:07 PM   #7
SLVR JDM
My Ride: 4Runner
It isn't hard at all. I ripped all of the carpet out of my grandparents 900 sq foot house in about an hour with just the help of my dad.
SLVR JDM is offline   Reply With Quote
Old 09-17-2012, 07:08 PM   #8
IDriveRealSlow
My Ride: goes slow!
take notes james franco
IDriveRealSlow is offline   Reply With Quote
Old 09-18-2012, 12:56 PM   #9
sea6speed
My Ride: 2010 335i Msport 6MT
It is a nasty job. Get some leather gloves as well for handling the tack strips. In addition to the wonder bar get some pliers to pull out staples and nails that don't have a head.
sea6speed is offline   Reply With Quote
Old 09-18-2012, 01:10 PM   #10
GlockMan
GlockMan's Avatar
My Ride: Suburban LT 4x4
You do know that the carpet installers will rip it out before laying the new carpet, right?
!!! ROLL TIDE ROLL !!!
National Champs: 1925, 1926, 1930, 1934, 1941, 1961, 1964, 1965, 1973, 1978, 1979, 1992, 2009, 2011, 2012, 2015, 2017?
Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI on a BMW board since 2005.
2016 Honda Accord Sedan V6 Touring (wife)
2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD
1968 Ford Mustang with Polk/ADS (my first car)
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
GlockMan is offline   Reply With Quote
Old 09-18-2012, 01:28 PM   #11
JJR4884
My Ride: BMW
Have a pair of needle nose pliers as well. that wonderbar might be a little too big for the staples they use to lay the foam padding down... either use the needle nose to rip them out, or a flat head screwdriver would help as well
JJR4884 is offline   Reply With Quote
Old 09-18-2012, 02:45 PM   #12
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Agreed, I was speaking to use them for getting the tack strips up.
Staples are best with NN pliers or channel locks
Old 09-18-2012, 03:54 PM   #13
JJR4884
My Ride: BMW
Solly are you putting new carpet down? If so, leave the tack strip...
Old 09-18-2012, 04:19 PM   #14
brew
My Ride: F150 X5 MR2
Carpet knives are cheap. They have a hooked blade and are super durable. Cutting up a house full of carpet with a box cutter sounds like a nightmare.
Used carpet pad makes a great sub layer for a pond liner. Dunno if you know anyone building a pond . . but there you go.
brew is offline   Reply With Quote
Old 09-19-2012, 10:36 PM   #15
slo323ci
My Ride: 00 323ci
Pics?
slo323ci is offline   Reply With Quote
Old 09-19-2012, 10:56 PM   #16
Guest100615
Account closed per your request
How about saving the old carpet for the garage floor ?
Guest100615 is offline   Reply With Quote
Old 09-19-2012, 11:01 PM   #17
B_Cyrus
Banned User
My Ride: Malfouf
hire mexicans
B_Cyrus is offline   Reply With Quote
Old 09-20-2012, 03:23 AM   #18
DylloS
My Ride: nothing
Laying laminate flooring down. Carpets are not being replaced by another carpet
