Old 09-18-2012, 07:37 AM   #1
zabalzae
My Ride: 01 330ci
Rear clunk gone
01 330ci
Just wanted to shared.
Every time I changed gears it would make a loud clunk from the back. changed my differential fluid last night with Mobil 1 75w-90 and the annoying clunk is finally gone.. the old fluid was at the right level it was just dark..
Sent from my SAMSUNG-SGH-I747 using Bimmer App
zabalzae is offline   Reply With Quote
Old 09-18-2012, 08:29 AM   #2
phubar
My Ride: 335is, HD
I also replaced the fluid but I used royal purple and the clunk is still there (confirmd differental clunk, not subframe or bushings) I might try Mobil1 next, thanks for the tip.
phubar is offline   Reply With Quote
Old 09-18-2012, 08:39 AM   #3
zabalzae
My Ride: 01 330ci
At first I thought it was the motor mounts (not the transmission mounts) bc they are completely gone but I decided to change the fluid first and now the clunk is gone. But I'm still going to replace the motor mounts. You might want to check that, I heard from someone here that the motor mounts can cause that 2.
Old 09-18-2012, 11:32 AM   #4
Steven747
My Ride: 05 330ci
fyi op your diff bushing is prob shot pretty bad
Old 09-18-2012, 01:41 PM   #5
zabalzae
My Ride: 01 330ci
Already replaced them
Old 09-18-2012, 02:17 PM   #6
Steven747
My Ride: 05 330ci
weird how fluid will get rid of a clunk i dont buy it
Old 09-18-2012, 02:27 PM   #7
zabalzae
My Ride: 01 330ci
I know I was reading on bimmerforum that there was something with the fluid that cause the clunk
Old 09-18-2012, 02:28 PM   #8
zabalzae
My Ride: 01 330ci
http://forums.bimmerforums.com/forum...d.php?t=954111
Idk if it's for non m
Old 09-18-2012, 02:54 PM   #9
JasonSmithed
My Ride: 00 323i
Guibo / cmb
JasonSmithed is offline   Reply With Quote
Old 09-18-2012, 02:56 PM   #10
JasonSmithed
My Ride: 00 323i
http://forum.e46fanatics.com/showthread.php?t=944258
Diy flex disc/center mount bearing install w/ home tools. (knocking clanking sound)
Old 09-18-2012, 03:00 PM   #11
zabalzae
My Ride: 01 330ci
Replaced 2
That's why I was going to replace the motor mounts
Old 09-18-2012, 03:34 PM   #12
JasonSmithed
My Ride: 00 323i
Rear clunk
Old 09-18-2012, 09:17 PM   #13
TrippinBimmer
My Ride: Just Fast!
You should as Gear Oil Help with Shock and Heat during operation...
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 09-18-2012, 11:40 PM   #14
Steven747
My Ride: 05 330ci
I see thanks
