Old 09-19-2012, 07:44 PM   #1
tjt131
My Ride: 2001 330ci convert
Unhappy eBay headers WTH!
Trying to install eBay headers myself into my 5pd 2001 330ci. Ran into the usual problems (access, o2 sensor locations, fit to exhaust pipe, etc) but now I can't get the exhaust to stop leaking past the manifold gasket. I originally tried the gasket that came with the headers. Then I ordered new oem, just tried it and it's pretty bad also. I will try tightening everything down again but is there something I am missing? Is there a sealant I could use to resolve the leak?
tjt131 is offline   Reply With Quote
Old 09-19-2012, 07:48 PM   #2
tjt131
Also, has anyone had an issue with eBay headers leaking from their welded seams? I hadn't read of anyone having that issue.
Old 09-19-2012, 08:23 PM   #3
WALKD U
My Ride: Just Fast!
Should have bought some BimmerBrakes Headers...
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 09-19-2012, 08:30 PM   #4
warriorpluto
My Ride: 2000 323i
Just use the high heat permatex gasket sealer. In place of the gaskets.
Sent from my Galaxy Nexus using Bimmer App
warriorpluto is offline   Reply With Quote
Old 09-19-2012, 08:31 PM   #5
JohnBlaze
My Ride: Black Sunshine
copper sealant has worked for some people I know, but I've never used it
you can put it on both sides of the gasket
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
Old 09-19-2012, 09:09 PM   #6
HiHoBrian
My Ride: 05 M3
Your flange surfaces are warped from shoddy "ebay workers" and need to be surface ground at a machine shop. They apparently aren't flat and true all the way across. The warpage won't allow them to seat flat against the gaskets and head. Be careful not to over torque the hardware and strip the studs out of the aluminum head while attempting to get these $100 gems to seal. The extra time and money will pay off if you do it right.
sent from my ATARI sc1224
HiHoBrian is offline   Reply With Quote
Old 09-19-2012, 09:21 PM   #7
ICONIKE46
My Ride: Horse & Buggy
BUILD THREAD SOON..IG @: ssblvck_
ICONIKE46 is offline   Reply With Quote
Old 09-22-2012, 08:53 AM   #8
tjt131
It appears that I had been putting too much torque on the headers by tring to get them to match up to the exhaust pipes. Once the car was warm, I disconnected the headers from the exhaust, retightened the nuts again and then reconnected the exhaust. Seems like my leaks are gone. I will check one more time today and then put everything back together.
I concluded that getting good headers is probably worth the additional cost because these things used up way too much of my time and I still have to get a new o2 location. Only 1 out of 4 o2 locations was usable. My second precat o2 I had to use a 90degree fitting and now I am getting a "too rich" error code.
Old 09-22-2012, 09:01 AM   #9
HiHoBrian
My Ride: 05 M3
That's bad. You definatly need both precat sensors in the proper pipe at minimum. I would get that corrected immediately.
Old 09-24-2012, 01:45 AM   #10
Bandit4077
My Ride: 330i SuperVeloce
anyone put highflow cats downstream yet?
Some say, that inside his helmet, there is another helmet. All we know is...
Check out my interior: http://forum.e46fanatics.com/showthread.php?t=1055263
Bandit4077 is offline   Reply With Quote
Old 09-24-2012, 02:05 AM   #11
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
the leaking welds are COMMMMMMON and you should have them welded up before you install (again)
I have a set here for the 325/330 that are already welded if you or anyone else wants them
/_________\
O==[][]==O
Old 09-24-2012, 02:12 AM   #12
SteadyMobbin
My Ride: ImolaZHP 6spd M/T
How much?
SteadyMobbin is offline   Reply With Quote
Old 09-24-2012, 09:49 AM   #13
330i ZHP
330i ZHP's Avatar
$120 shipped
they are used but are guaranteed non leaking (I used them for about 6 months before deciding I couldnt take the O2 related problems anymore)
These fit the best of any of the ebay headers I have ever installed - flanges are really close and you do not have to put strain on the head flanges
/_________\
O==[][]==O
