Suspension & Braking
Have some questions about suspension or brake setups for your E46 BMW? Get all your answers here! |
#1 |
My rear suspension is acting stupid
Problem is actually for both but left is in worse condition. As, I mentioned I installed 2 new (very cheap ones) struts, 3 new mounths in the rear as well as replaced a broken spring on the left side. Just over 1500 miles and now my strut is (right side) about to pop out of strut mount again.
Do you think installing good stuff ( like i did for front at the same time) for rear and also installing a aluminum bar on top of the strutt mounts in rear would reduce this crazy tear problem. Since I bought the problem, I have never been happy with suspension, always noisey (( here is a brief video of the problem: Last edited by ilkercatal; 09-21-2012 at 09:57 AM. Reason: more info |
#2 |
Platinum Plus Quality
I have absolutely no clue what you're talking about. From the pictures, everything appears normal.
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs |
#3 | |
I put little information, sorry
Do you think installing good stuff ( like i did for front at the same time) for rear and also installing a aluminum bar on top of the strutt mounts in rear would reduce this crazy tear problem. Since I bought the problem, I have never been happy with suspension, always noisey ((I am adding a short video here: |
#4 |
Get a Mayle HD if you can find. Cheap mounts are never a good idea as they take a lot of beating. M3 mount can fit as well and it is better constructed. I have not tried on sedans but on 330Ci M3 rear mount fits perfect.
#5 |
sounds like a bad rear shock mount (RSM). I have heard good things about Rouge engineering RSM http://www.rogueengineering.com/rogue/S_BUSH/RSM.html
#6 | |
![]() '04 330i ZHP TiAg/Alcantara 3.46/APEX/KONI/COBY/JAFFSTER |
#7 |
#8 |
thanks
#9 | |
Installing a rear strut tower bar is a band-aid and may not even help your problem anyway - depending on how it installs onto the car. Typically they mount onto the threaded studs coming out of the rear shock mounts. Mounting in this way would do nothing extra to prevent the rubber from pushing through. |
#10 |
Dude.....your strut is coming through the Rear Shock Mount tower......Buy new RSM's for 99$
Couldnt tell you if your springs or shocks are done. But you need new RSM bushings at least. Fix that as it will start to smack, cracking the tower, subframe. You name it. |
#11 | |
oh,,
also how much torque should be applied, is that a deal breaker as well?( i tighed up decent) |
#12 |
check this:
http://www.realoem.com/bmw/showparts...41&hg=33&fg=45 what parts are you missing? the bits you dont need are: 8,11,14,16,17,19 but you need everything else. From your video, either the shock mount is REALLY poor quality or 6 is missing. If you are missing the bumpstop then probably also missing dust shield which protects the piston from dirt & if your shocks are cheap or worn, you risk tearing the shock towers
#13 | ||
The bump stop (4) is designed for one end to fit snugly inside the dust boot (3). There is an interlocking groove that allows the two parts to fit together. Washer (5) will rest inside the top of the bump stop, and should sit on a groove on the shock rod. Washer (6) fits upside-down around the top of the bump stop You already have the last washer in place correctly (12) While you are in there, might as well replace gasket (9) and all self-locking hardware (10, 13, 2) and probably the lower shock bolt. Torque requirements are: Rear shock to trailing arm - 44 ft/lb Rear shock to upper mount - 10 ft/lb Rear shock upper mount to body M8 self-locking nuts - 21 ft/lb
