Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 09-18-2012, 11:47 AM   #221
Kris@TSS
My Ride: 2005 BMW 545i
Originally Posted by abdkhan1 View Post
Hey guys I need a little help; how is the rear shock assembly suppose to be installed?... I believe I made an error and thus putting the adjuster at the top of the shock making it very difficult to adjust.
Rear perch goes on the top for the E46 models.
Kristina "Kris" Ash
General Manager
The Suspension Source
1-888-230-1288
kristina@thesuspensionsource.com
www.thesuspensionsource.com
Like us on Facebook for 10% off
Kris@TSS is offline   Reply With Quote
Old 09-18-2012, 11:48 AM   #222
Kris@TSS
For guys who want to go over their install I suggest using the V1 instructions. A little better than the ST instructions
http://www.kw-store.com/extras/docs/...ah68620022.pdf
Kristina "Kris" Ash
General Manager
1-888-230-1288
Old 09-19-2012, 05:43 AM   #223
BMW2D4EVR
My Ride: 2002 325ci
Kris, if I'm Going towards more of a slammed look, what brand of coils should I be searching for?
Originally Posted by ///M=Power View Post
Buisness, Money, Women... BMW
BMW2D4EVR is offline   Reply With Quote
Old 09-19-2012, 12:34 PM   #224
Kris@TSS
BMW2DEVR, we own BMWs. Known as the Ultimate Driving Machine. You will lose the performance aspect of the car when "slamming" the car. Coilovers are design to enhance the performance of the car. I do not recommend lowering these cars more than 2.5" in front and 2.0" rear.
I am the type that is function/performance over looks though. If you really want something slammed maybe look into getting an S10 or Toyota Pickup. Those things have no performance LOL
Kristina "Kris" Ash
General Manager
1-888-230-1288
Old 09-19-2012, 07:55 PM   #225
BMW2D4EVR
My Ride: 2002 325ci
I understand that slamming a car is not practical. But I like the look of it, and I'm sure most of you do to. It might take away some of the performance, but I own a 325. Not a 330. Not an m3. So performance isn't really what I am going after for this car. Im going for low and slow with this one. I asked a simple question about what coils would give me the look I'm going for. I'm not trying to get into debate whether slamming cars looks good or not. I just want to know which will give me the best results.
Old 09-20-2012, 11:14 AM   #226
Kris@TSS
I do not know of a coil or coilover that will ride any good and slam you sorry.
Kristina "Kris" Ash
General Manager
1-888-230-1288
Old 09-20-2012, 11:28 AM   #227
Stiggles
Stiggles's Avatar
My Ride: Was built Fri 13th
Might have better luck in this thread: http://forum.e46fanatics.com/showthread.php?t=774348
That said, if you don't care about the warranty from ST, you could just remove the helpers. The back already goes pretty low on mine.
Not sure what wheels you run, but slammed you'd probably be tucking a lot - if not all - of the tire in the fender.
Stiggles is offline   Reply With Quote
Old 09-20-2012, 06:37 PM   #228
BMW2D4EVR
My Ride: 2002 325ci
Might end up going that route of taking off the helpers, don't really want to but it looks like that's the only choice I got unless I wanna buy another set of coils.
Curious about the ride comfort with the helpers removed.
Old 09-20-2012, 07:45 PM   #229
Stiggles
Stiggles's Avatar
It would be exactly the same, aside from the lowered ride height. The only point of the helper spring is to keep the main coil compressed against the strut, so it doesn't shift and move around.
Sent from my LG-P999 using Bimmer App
Old 09-21-2012, 10:56 AM   #230
Kris@TSS
Kristina "Kris" Ash
General Manager
1-888-230-1288
Old 09-21-2012, 05:03 PM   #231
abdkhan1
My Ride: 2005 BMW 325ci
I can tell you that its so inconvenient to adjust the ride height in the rear! I have to pull the whole springs in order to adjust. I cant access the rear perches due to it being on top and blocked by the inner wheel well!
abdkhan1 is offline   Reply With Quote
Old 09-21-2012, 05:18 PM   #232
Kris@TSS
It will be like with most coilovers.
Kristina "Kris" Ash
General Manager
1-888-230-1288
Old 09-21-2012, 05:23 PM   #233
abdkhan1
If I put the adjuster on the bottom, will it make it easier to adjust for future reference?
Old 09-21-2012, 05:42 PM   #234
Kris@TSS
Please look at this link
You could physically put the perch on the bottom but it is not recommended.
Kristina "Kris" Ash
General Manager
1-888-230-1288
Old 09-21-2012, 05:44 PM   #235
Kris@TSS
You will also lose some height as well by putting the perch on bottom.
Kristina "Kris" Ash
General Manager
1-888-230-1288
Old 09-21-2012, 05:47 PM   #236
jamex
My Ride: 2005 325Ci
No because it sits inside the wishbone which has a lip and makes it almost impossible to get the adjustment wrenches in there. Dial in your rears and leave them alone. Unbolting the damper each time is a royal pain in the ass.
Ac-2007 is your sig from bimmercruise?
jamex is offline   Reply With Quote
Old 09-21-2012, 11:25 PM   #237
abdkhan1
Thanks I did that. It took a few hours of testing them and finally got the car looking even on all corners. Looks so much better. I had to raise the rear a little bit. As for the fronts, I'm close to max drop and my tires are tucking a little. I really hope the strut is sitting all the way in. I even went about opening the hub more and the nipple only sits a quarter way in from the top.
Old 09-22-2012, 05:49 AM   #238
BMW2D4EVR
My Ride: 2002 325ci
Well I leave for college tomorrow... So I'll take the helper spring out when I have free time
Old 09-22-2012, 10:20 AM   #239
abdkhan1
Good luck bro. As for me I'm going to go back down there and make sure the strut is all the way in. I'm positive that this can't be my issue because when doing the install I made sure to rule this problem out.
Old 09-22-2012, 12:47 PM   #240
Stiggles
Stiggles's Avatar
Yes it is
