Go Back   E46Fanatics > Everything Else > The Off-Topic > Health & Fitness
Health & Fitness
Discuss any topics related to heath and fitness here.
Old 09-18-2012, 09:35 PM   #1
stevenluczynski
My Ride: Is Steel Blue
Smile Help a guy get a solid plan to reach his goal?
So I've been going to regularly for about 3 years now and I have seen Improvements with my strength but I have seen little change in my physique. I have been following this routine for most of the time without the cardio part.http://www.muscleandstrength.com/wor...n-routine.html
My biceps and chest have definitely grown but I feel like my results should be better after a few years of going 5 days a week.
Here is the most recent picture of me http://i1199.photobucket.com/albums/...ps7439756b.jpg
and I guess this would be my goal http://i1199.photobucket.com/albums/...psa38fe0af.jpg
P.s.
I'm 6 foot and 165lb
stevenluczynski is offline   Reply With Quote
Old 09-18-2012, 09:55 PM   #2
DylloS
My Ride: nothing
what are your lifting numbers?
That routine is all high reps so you should have made improvements in the way you look. What does your diet look like?
DylloS is offline   Reply With Quote
Old 09-18-2012, 10:05 PM   #3
stevenluczynski
bench-1165x10 reps, 210max
squats-165-10reps not really pushing myself
So about a year ago someone told me to try out doing 3 sets of each exercise in 10,8,6 repetitions, so thats what I have been doing for the past year.
I havent really logged my diet but its mostly healthy foods, but lost of carbs(bread) i can log it for the next few days and post it here.
Old 09-19-2012, 11:21 AM   #4
dabears
My Ride: 2003 BMW M3
I feel like you've given a couple hints as to why you have yet to reach your goals.
#1 - Nutrition.
Are you getting enough protein? You should have at minimum 165g a day, and be more in the 165-230g a day range.
What is your fat intake? If its only around 20-30% of your daily calorie intake, with protein being 20-30%, that means 40-60% of your calories come from carbs... and at 4 kCal a gram you are probably not eating over maintenance calorie level.
My suggestion to you is to calculate your maintenance calories. This is the start level for where you need to eat to maintain your current weight. Since you want to add weight, but with the goal picture you posted be at a sub 10% BF level, you should consider the following:
Calculate your maintenance calories, and eat 500 calories more than that on workout days. It's impossible for most men to do this in 3 meals eating clean. If you slam down 6-7 pieces of pizza, different story. This is counter-intuitive to your goals however. You should aim for 4 meals minimum, im guessing your maintenance will be around 1800 calories... so 2300 calories, at around 600 a meal. This is for workout days only, and since intense weightlifting burns significant calories, you should add a 5th "meal" post workout, of a protein shake in the 300-500 calorie range. Achieve this by using 2 scoops of 24g per scoop protein (ON whey etc), and some high fat moderate sugar greek style yogurt, or heavy cream if you like the taste.
I do not believe you are eating enough food, nor the proper amounts of each nutrient for extensive muscle growth. I honestly believe you are past your initial gains where everything is much easier, and its going to be more difficult to see gains without more specific nutrition/work ethic. IMO at least!
#2 - Intensity & Reps
That workout program is so-so imo. If you want other examples just say. From personal experience, if you like training in the higher rep ranges, you should stick to between 8-12 reps. You may need to be training more intense, your body has adapted to the initial shock of lifting and you need to step it up to the next level in order to see gains from here on out. If you like the 10-8-6 reps (I hope they told you to up the weight each set, reverse pyramid is the name for the rep scheme) then you should pick a weight that you come close to failing on the last rep on each set... easier said then done but once you find the right one you can monitor progress as it feels lighter each week.
You need to push yourself more I think... your squats should be heavier (given your bench number) and you should be squatting to parallel.
Sorry for the paragraph reply but unlike most people who post this sort of stuff and don't have a clue, you seem dedicated and have just hit a wall. Lots of people here can help you get past it
dabears is offline   Reply With Quote
Old 09-19-2012, 12:46 PM   #5
dabears
Give this a read:
http://www.t-nation.com/free_online_...gaining_muscle
And consider this routine, its currently working wonders for me in only two weeks. I love the science behind the rep ranges (and corresponding weight lifted).
http://www.muscleandstrength.com/wor...out-split.html
Old 09-19-2012, 01:50 PM   #6
M3Inline6
aka...Dark Snow
My Ride: '17 Nardo Grey M4
Based on where you are now, you'd easily look like the guy on the left (..in the goal picture) simply by dropping body fat. Neither of those guys are overly muscular, so it is my opinion that you've given yourself a realistic goal based on your current state. Dabears has provided some information for you, so now it's time for you to eat up, lift hard, and post the results.
Originally Posted by Qwel on "Manhattan Project"
You heard of me.....burgandy and outlines like murder scenes; Germany..took ferns and flat whites for blurring greens.
M3Inline6 is offline   Reply With Quote
Old 09-19-2012, 08:56 PM   #7
stevenluczynski
Thanks for the replies!
Another question that I have is to loose body fat percentage, will that happen when I'm going over my maintenance calories on workout days?
Or do I have to do the Weightlift and bulk, then Cardio and try to lean down?
And with the plan Dabears posted should I be doing some kind of cardio to loose the body fat%?
Old 09-19-2012, 09:06 PM   #8
dwass325
My Ride: CTA
Send a message via AIM to dwass325
Just about any "split" that hits all body parts will be sufficient. The one thing I would really mention is to focus on upper chest, triceps, and lateral raises for shoulders. These movements will give you huge bang for the buck (visually).
The real issue is your diet. Not to be insulting, but the way you've phrased it tells me that you eat garbage. Log what you eat for a few days and report back. Anything that passes your lips for like 72hours. I bet you'll be shocked how A) high your carbs are and B) how low your protein is.
Originally Posted by jacques chirac View Post
I don't see what is ridiculous by robbing with a sword.A sword in one od the most lethal wepon !!!
It's more easy to kill with a sword than with a gun.
A sword is more frightening than toy-looking gun like glock.
robbing with a sword is a good thing
dwass325 is offline   Reply With Quote
Old 09-19-2012, 09:09 PM   #9
stevenluczynski
It's not an insult, I always appreciate constructive criticism! Ill log my diet starting tomorrow and report back!
Old 09-20-2012, 10:59 AM   #10
dabears
Ill wait to see the diet to determine if I think you are ready to wreak some havoc on your body with nutrition... you can lose fat and gain muscle (both at a slow, sustained rate) over a years time with careful nutrient timing. But for the majority, excess calories = muscle gain (if lifting weights) + fat gain, deficit calories = fat loss with minimal to no muscle loss (if lifting weights). Your macros and training determine how much you gain/lose of each.
Old 09-23-2012, 05:29 PM   #11
stevenluczynski
Ok so by tracking my diet I have realized I'm not getting nearly enough protein and wayy to much carbs.
and pre made diet plans you guys suggest?
Old 09-23-2012, 06:25 PM   #12
DylloS
My Ride: nothing
Premade? No. Just get a list of good quality foods and eat the right amounts
Old 09-23-2012, 06:26 PM   #13
dwass325
My Ride: CTA
I am like the diet swami over here.
Breakfast: egg whites and oatmeal, a couple whole eggs.
Subsequent meals: chicken/fish, broccoli/asparagus, brown rice/sweet potato.
A couple protein shakes are okay, too.
Use a site like livestrong.com to track nutrients of what you're eating. I don't know your height/weight, but I would suggest splitting your calories at 40% protein, 40% carbs, and 20% fat to begin with. Try that for a while and it should work well...then you can adjust from there as you learn how your body reacts to certain things (we're all different).
Old 09-23-2012, 10:49 PM   #14
M3Inline6
aka...Dark Snow
Do I have permission to change your username to Diet_Swami? How about Diet_Swami325? Or maybe dwasswami325?
Old 09-23-2012, 11:46 PM   #15
dwass325
My Ride: CTA
Permission given for Diet Swami. I don't own a 325 anymore - or any car for that matter.
Old 09-23-2012, 11:47 PM   #16
stevenluczynski
^rofl
Old 09-24-2012, 12:19 AM   #17
M3Inline6
aka...Dark Snow
Seriously? Lol! I'll change it.
Sent from my Nexus S 4G using Bimmer App
Old 09-27-2012, 11:54 AM   #18
rohde88
rohde88's Avatar
My Ride: S2000
update OP?
I think you should re-take your own picture with better posture. Honestly, your posture accentuates your deficiencies. Head up shoulders back.
-Ron
rohde88 is offline   Reply With Quote
Old 09-27-2012, 12:46 PM   #19
stevenluczynski
well this week I've been following this workout http://www.muscleandstrength.com/wor...out-split.html and paying attention to my diet.
and I will retake a picture Friday!
Old 09-27-2012, 01:00 PM   #20
dabears
How do you find it? I use 3-4 sets for the power with 5 reps, and 3 sets for 8-10 (if i hit 10 I move up in weight) for the muscle ones. Amazing split if you ask me, it's a lot more intense than starting strength / stronglift type programs yet still has all the big lifts within same rep ranges which I love.
POST YOUR DIET!!!
