Suspension & Braking
Have some questions about suspension or brake setups for your E46 BMW? Get all your answers here! |
#1 |
Struts
I was online at bmaparts attempting to price the strut mounts which I found for $33, but I can't find the shock mounts? Are there no shock mounts for the front? Only rear?
#2 |
Wears carbon fiber boxers
My Ride: 330Ci ZHP 6sp
Strut mounts are equivalent to rear shock mounts. They have bearings in them that allow the mount to twist and such.
E46Fanatic's resident mathemagician
#3 |
The parts came in from bma. I ordered Bilstein struts and meyle strut mounts; anything else I need? I don't know if I should buy the rubber boots?
#4 |
I'd get a new rubber boot since it's gonna be off anyway.
#5 |
So that's all I need ? What about bump stops?
#6 |
Sorry I forgot you were doing struts as well.
Are you getting Bilstein HDs? If so, no bump stop or boot required. Boot is supplied.
![]() Last edited by Zell; 11-15-2012 at 12:01 PM. |
#7 |
Grand Superpatriot
I would recommend against Meyle mounts. The bolts are too short so you won't be able to mount a brace.
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs |
#8 |
Grand Superpatriot
Bilstein struts have internal bump stops.
#9 |
I bought the Bilstein touring class struts and meyle mounts. I thought that's all I needed but I see I need more things ? Don't wanna' be stuck halfway through the job. Any help is appreciated!
#10 |
Grand Superpatriot
See sig, second link. Scroll to bonus.
#11 |
Dang it, I had in mind to install braces in soon after I fixed this. I already bought the mounts..
#12 |
Thanks!
#13 |
#14 |
I just replaced the struts and I completely hate them! The ride height is waay too high! They are bilstein Touring's...I officially hate Bimmers; waay too much effing plastic.
#15 |
Your ride height should not have changed. You did something wrong
#16 |
The new strut has more travel the the Sachs
#17 |
Anyone here use the same brand ???
#18 |
Modded ///Member
I read in another thread about this happening with the Bilstein Touring's. I was going to put the same set-up on my 323, but I'm going to go with the Koni's instead.
http://forum.e46fanatics.com/showthread.php?t=916794 It's common with the Bilstein's. I'm gonna have to stick with them because with everything I need, my budget doesn't allow for Koni. I don't mind a little bit of a bigger gap so I'll let you know how my car turns out.
#19 |
They're not bad, It's just that I hate the huge wheel gap. I stayed up all night outside replacing the struts, mounts, end links, front tires, expansion tank and what not. I'm so freaking tired and just having second thoughts about having a Bimmer..it needs too much. Other than that I just found out my lcab's are gone so I just placed an order. I swear this car is nothing but a wallet beheader. To cure the huge wheel gap I'm going to purchase lowering springs. I know it's not the best idea but I don't have 2-3k to spend on a full suspension lowering kit. Bash or flame me if you want.
#20 |
I'll take a pic if you want to see the results.
