Old 08-04-2012, 07:47 AM   #1
Bobobo-bo Bo-bobo
My Ride: 2000 bmw 323i
steering wheel/seat vibration
Ive replaced my wheel bearings, control arms w/ bushings, rotors, brakes, got alignment but I still get slight vibration in steering wheel and seat. its not uniform and sometimes goes away to a perfectly smooth ride on the same surface for a very short time. My tires still have good tread but my mechanic said that one was a little unevenly worn. Im wondering if its tires or something else that could be the issue? Any ideas? Thanks.
PS: By slight vibration I mean very slight, although I have rotational noise and it seems like my road noise is louder than when i got the car.
Bobobo-bo Bo-bobo is offline   Reply With Quote
Old 08-04-2012, 07:50 AM   #2
DHK
My Ride: 2002 BMW 325Ci
Only time I ever experienced something similar was when I had a tire with a bulge in it, but you said you had your tires checked.
DHK is offline   Reply With Quote
Old 08-05-2012, 11:06 AM   #3
Bobobo-bo Bo-bobo
ill deal with it until i need new tires then.
Old 08-05-2012, 11:31 AM   #4
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Your wheels might not be balanced (maybe threw a weight?)...also the rim can get bent and even though they can be balanced, you'd still feel it.
Then there are those things you didn't do anything about yet...struts/shocks...tie rod ends...that sort of thing.
I chased a vibration for about two years until I discovered the inside rim of my front wheel was bent...and I discovered it because the guy balancing my new tires noticed it on his slow speed balancer. The high speed (expensive) balancing machines can spin the wheel so fast you wouldn't notice the hop in the rim...but if you lift up your car, spin the wheel and look for a hop, you'll see it if it's there. If so, try moving that wheel to the rear where you won't notice it so much. Technically, you'd keep the tires in the same corners they're at now, as bmw doesn't recommend rotating tires.
See me in June!
dmax on Facebook
Mangofy your E46!
Old 08-06-2012, 10:59 PM   #5
TynPar
My Ride: '01 325 vert
I cannot read/hear the word "vibration" without Marky Mark popping in my head!
TynPar is offline   Reply With Quote
Old 08-07-2012, 06:06 AM   #6
Lestat_
My Ride: E46 318ci M-Sport
If it's a cyclic vibration, balancing won't fix the issue. It's most likely buckled wheel/s.
Lestat_ is offline   Reply With Quote
Old 08-07-2012, 11:46 PM   #7
Bobobo-bo Bo-bobo
kinda feels like its skipping across the road when im going around turns at a decent speed
Old 08-07-2012, 11:49 PM   #8
Zell
Zell's Avatar
My Ride: so turbo wow
Is it an intermittent vibration that you can feel in your seat? I felt them with my worn and cupped tires. New tires fixed it. I also think it could have something to do with drivetrain vibration but I don't know. I could probably do for a guibo change at some point.
Old 08-08-2012, 04:40 AM   #9
dmax
dmax's Avatar
That description alone makes me think struts or shocks. Look for oil leaking down them.
Maybe swaybar or endlinks.
See me in June!
dmax on Facebook
Mangofy your E46!
Old 08-08-2012, 05:28 AM   #10
swordsman11868
My Ride: 2003 325i
While I was under the front end the other day I noticed my sway bar bushings were looking a little worn.
I'm getting similar vibration at freeway speeds in the steering wheel. I have Bilsteins about 1 year old and FCAsFCABs also.
Edit: end links were replaced also.
Tie rods seem solid. So what do you guys think about the SB bushings being the cause?
I'm just here to change the world.
BMW Wiki: http://www.bimmerfest.com/wiki/index.php
E46Fanatics inspiration Robolop: http://forum.e46fanatics.com/showthr...87566&page=101
2016 Beheadings in Saudi Arabia: 92.
swordsman11868 is offline   Reply With Quote
Old 08-08-2012, 05:32 AM   #11
dmax
dmax's Avatar
Sway bar bushings are serious solid chunks of rubber. I removed mine probably at 180K miles and they looked identical to the new ones. Of course, if the bushing bracket is loose, that's something else.
See me in June!
dmax on Facebook
Mangofy your E46!
Old 08-08-2012, 07:41 AM   #12
lsteg
My Ride: 2001 330ci
I agree. Sounds suspension related.
lsteg is offline   Reply With Quote
Old 08-10-2012, 12:27 PM   #13
Bobobo-bo Bo-bobo
no oil leaking from shocks or struts
Old 09-25-2012, 02:46 PM   #14
Bobobo-bo Bo-bobo
So I swapped out my front driver tire with a spare and the vibration is virtually gone. Now all thats left is a little bit of random shake and more of a clicking feel in the steering wheel.
Sent from my DROID BIONIC using Bimmer App
Old 09-25-2012, 02:53 PM   #15
lsteg
My Ride: 2001 330ci
Sounds like the constant vibration may have messed with something else. Maybe tie rods or end links?
Old 10-06-2012, 05:31 PM   #16
Bobobo-bo Bo-bobo
Tie rods feel solid as well as end links. Im thinking its my tires.
