California
Have you seen another BMW while driving around in your area? Maybe you can find their car in the E46Fanatics Garage! Northern California Southern California If you don't have your garage setup, sign up today HERE |
Rating:
#278181 |
bored
#278182 |
class is dumb
#278183 |
Town Clown
Cheer up. I don't think the instructor really means it.
Bay Area Top Dropper Orient Blue 330 Ci Vert ********************** ![]() |
#278184 |
No it's just one of those scenarios where he just doesn't care anymore.
Tenure is terrible
#278185 |
#278186 |
Tried to run the hill around our office...omg, kicked my ass.
#278187 |
I've been out of class for 2 hours
![]() Now I'm having teh sads because no mazdaspeed miata to hoon in |
#278188 |
Dropped the car off. Fingers crossed!
#278189 |
I was talking to an SA about weird color combos (conversation was sparked by an ugly custom e92 in service) and he said the ugliest one he's seen was one all the guys at the dealership refer to as "baby shĄt green/yellow." I asked if he meant Phoenix Yellow and his response was "that's the one!"
#278190 | |
#278191 |
My Ride: E46 332i,M3;E30 325i
-Kalim
(klx photo studio) ![]() M3 drive train conversion (S54 Swap, LSD, 6MT, suspension linkage) | UUC Stg 2 Organic Clutch | OEM M-Tech II Kit KW V2 | BBS GT4 RE | Falken FK452 | Alcon 6-pot 365mm BBK | M3 steering wheel | Powerflex bushings |
#278192 |
lawl
-Kalim
#278193 | |
-Kalim
#278194 |
Kalim, the master tech came out and said the injector noise is typical of the M56. Apparently the larger injectors they run are just noisier.
I still find it interesting that with the same 2.5L block, it has a larger intake diameter and higher flow injectors than an M54. Makes you wonder what kinda power it'd make with a good tune and one less set of cats ![]() Apparently the pressure bleed off is also normal. He said there's a purge valve in the pump. He said on rare occasions the valve can go bad but starts will take on the order of 5+ seconds. The fuel tank filling issue is an issue they're gonna look into though. |
#278195 |
Town Clown
#278196 | |
#278197 |
Town Clown
zilch on the E46.
#278198 |
Town Clown
that's something else that Miles should be able to fab.
#278199 | |
I think he meant the non-return valve in the pump. The system should bleed off pressure slowly. It should fall 0.5 bar or less within 20-30 minutes of the pump being switched off.
-Kalim
#278200 | |
-Kalim
| Tags |
| >implying the e9x is good, '07 og's, '08 n00bs, 01, 02, 03, 04, 05, lgtss >kyle, mkodama was not here, norcal, norcal general chat, pshaw pshawn, pshawn not shawn, wes was here |
| Rate This Thread | |
