Engine & Performance
Old 09-25-2012, 01:14 PM   #1
325CiMaN
My Ride: 01 BMW 325ci 3.0L
Fs/ft random parts/ shrick cams.
All came off my 01 325ci, I have a sock oil filter housing, Oil pan, Oil pump, intake manifold needs to be thoroughly cleaned out, throttle body, and AFE throttle body spacer, good disa, oil dipstick tube, two vanos units both need seals, one good timing cover,12 good ignition coils, 2.5 injectors with fuel rail, one new thermostat, and two newer thermostats, one good A/C compressor and two brackets, all A/C hoses that are new, I'm no longer running A/C, I have the condenser but still on my car need to pull it out still, good harmonic balancer. Not to sure on prices just shoot me an offer. May have other random engine parts just ask and I'll look.
Also have a set of shrick cams for a m54b30, but they will work for the m54b25 if you make sure the can timing its absolutely perfect, i had them in my m54b25.. Specs on cams, 264 duration intake/248 duration exhaust 10.5mm intake lift and 10mm lift exhaust VAC valve springs, spring seats, retainers, and locks, VAC racing timing and oil chains, also have a set of stock chains, only has about 300-400 Miles on them, also have new lifters to go with it. Not to sure on cams and springs price, looking for offers no low ballers please. I paid around $2800 for cams and valve train components and chain set ( minus the valves)
I'm in the bay area, i live in Napa CA,
Thanks for looking,
Ron
325CiMaN is offline   Reply With Quote
Old 09-25-2012, 01:54 PM   #2
325CiMaN
Bump!
Old 09-25-2012, 02:50 PM   #3
325CiMaN
Bump!
Old 09-25-2012, 03:21 PM   #4
///MPR77
My Ride: 02 ///M3 Tri-Ped
Pm sent.
Old 09-25-2012, 04:02 PM   #5
325CiMaN
Bump!
Old 09-25-2012, 05:02 PM   #6
325CiMaN
Bump!
Old 09-25-2012, 07:31 PM   #7
325CiMaN
Bump!
Old 09-25-2012, 07:50 PM   #8
rube
My Ride: 2002 325 ICC
Spacer
PM'ed U!
rube is offline   Reply With Quote
Old 09-25-2012, 09:05 PM   #9
325CiMaN
Bump!
Old 09-25-2012, 09:14 PM   #10
daves325in2012
My Ride: 2004 330cic
Pmed about thermostat
Sent from my DROIDX using Bimmer App
Mysticblau 330cic
Pretty Facelift on..PSS9\\Alpine 9855\\More
daves325in2012 is offline   Reply With Quote
Old 09-25-2012, 09:30 PM   #11
Steven747
My Ride: 05 330ci
Bump for some good goodies
Old 09-25-2012, 09:36 PM   #12
darksideracer69
My Ride: 01 325ci
Put some pics up. Don't bump your threads like every couple hours, doesn't make a difference.
Also prices, whats the price for the cams?
IMAG02051
Old 09-25-2012, 09:50 PM   #13
325CiMaN
Also prices, whats the price for thE cams?
Good point, i will try to get some pics up by Friday. There's allot to photograph lol and for prices i'm just looking for FAIR offers, i don't want to throw done huge number out there and scare everyone off our to small of number and loose my @ss on money. i added more info on the cams.
Old 09-25-2012, 10:52 PM   #14
Steven747
My Ride: 05 330ci
people are just going to want the cams most likely and as most of us know they about 1k new
Old 09-25-2012, 11:22 PM   #15
325CiMaN
Its highly recommended tho to run the springs if you do bigger cams, just saying, i am willing to sell cams by them selves just would like to see it all leave at same time, and they are not 1k new go to vac motor sports these aren't the little cams these are the mild cams there about 1200 shipped. I my starting offer for cams by themselves is $1000, $1800 for everything ( regarding the cams not misc motor parts)
Old 09-25-2012, 11:34 PM   #16
Steven747
My Ride: 05 330ci
yeah thats why i said about.
i believe the 272's are recommended to go in with beefier parts but its just for good measurement with 264's. i would love to have that setup on my car though. 264's are the medium cams 272's are the biggest 1's shrick offer for our cars
anywho glws
Old 09-25-2012, 11:38 PM   #17
325CiMaN
anywho glws
Thanks man! Ya when i can afford to build another motor i am going to do a hybrid of m54b30 and s52b32 so basically a dual vanos s52b32 but i am going to make as much power n/a as possible with combo of 272 cams and high compression pistons and ITB's
Old 09-26-2012, 11:21 AM   #18
325CiMaN
Bump
Old 09-26-2012, 04:24 PM   #19
325CiMaN
Thermostats sold! I also found some more parts- brand new idler pulley, good hydraulic belt tensioner 300 miles on it, good water pump pulley 300 Miles on it, good power steering resivor, oil filter housing lid x2, good ac belt tensioner with pulley 1000 miles on it, idle air control valve, vacuum canister under intake manifold, secondary air valve,
plus a bunch of misc sensors and pressure switches. Here are some pictures
ID:	471139   Click image for larger version
ID:	471140   Click image for larger version
ID:	471141   Click image for larger version
ID:	471143   Click image for larger version
ID:	471144   Click image for larger version
Old 09-26-2012, 04:35 PM   #20
BigDRick323
My Ride: 2000 323i
I think I'm going to need that power steering reservoir.
Sent from my VM670 using Bimmer App
