Car veers left and right - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 09-27-2012, 11:06 PM   #1
leetoranges
My Ride: 2002 330i | 2003 M3
Hi so I've been noticing that my car kind of veers left and right, aka if it veers to the left a bit, i correct it and then it will veer to the right abit, it isn't alot of veering, but i would have to correct it a bit, and the car wouldn't really go straight(not touch the steering wheel for a while). I had thought it was just me, until i let my mom and dad drive my car, and they said it too it was happening.
I had replaced all 4 tires(staggered) on the car before this problem, and the tires were "balanced". I had also got the car a "alignment job".
Would this issue be the tires aren't balanced correctly or the alignment job was bad?
I have the specs for the alignment.
leetoranges is offline   Reply With Quote
Old 09-27-2012, 11:20 PM   #2
S85FTW
My Ride: E60 M5 & F30 328XI
Send a message via AIM to S85FTW
Suspension? Subframe? Poor alignment job? Improperly inflated tires? Bushings? Control arms? Wheel bearings? Could be any of those things. Check all of those yourself. Post up results of alignment up here as we'll for others to see.
S85FTW is offline   Reply With Quote
Old 09-27-2012, 11:21 PM   #3
emgee
My Ride: 3 pedal 2005 325xi
i recently started having this issue as well. i suspect it has to do with my rear trailing arm bushings and a bent rear control arm. im waiting for my new control arms to come in the mail.
emgee is offline   Reply With Quote
Old 09-27-2012, 11:22 PM   #4
emgee
i got bushings from UUC.
Old 09-27-2012, 11:36 PM   #5
leetoranges
To be honest, i kinda think it started after i got my new tires. Could them improperly doing the "tire balance" make this problem happen? And i put the spec from the alignment job image on the First post.
Old 09-28-2012, 12:03 AM   #6
S85FTW
Balancing would cause vibration, not pull. Check to make sure that your tires were mounted in the correct treadwear direction. Sometimes tire places can mix up sides. Alignment looks decent enough to where it wouldn't cause pull. If tires are fine check front control arms bushings and rear trailer arm bushings for wear or cracks.
Defective tires can cause pull but I have never experienced that in 12 years of car ownership.
Old 09-28-2012, 12:22 AM   #7
leetoranges
I just checked the tires and they are directional and have the "v" thread pointing towards the front of the car. Tires are hankook ventus v12 so i don't think they are defective.
Also i forgot to mention, that on the alignment job report, it states that he heard a slight ticking noise coming from the passenger side, but was okayed on a basic inspection. Could this potentially be the arm bushings you said?
Old 09-28-2012, 12:26 AM   #8
S85FTW
Two ways to check the bushings:
1- roll windows down. If you hear a slight knock come from the front as you come to a complete stop or accelerate from a dead stop they are bad.
2- take your wheel wrench and loosen one of your bolts on your front wheels while the car is on the ground. If you notice the wheel moving back and forth while the rest of the car stays in place they are bad.
Old 09-28-2012, 12:34 AM   #9
leetoranges
Okay i will check tomorrow for #1 on the way to work. For #2 ima do right now, If it does happen to be bad, what am i looking at in fees. If i diy or if i bring it in?
Old 09-28-2012, 12:36 AM   #10
S85FTW
Bushings don't DIY. Too much of a pain. Bring it in. The labor involved to press in new bushings you are better off just changing the arms while you are at it. Should be no more than $300 for everything.
Old 09-28-2012, 12:41 AM   #11
MJLavelle
My Ride: 2001 BMW 330ci
Impropperly balanced tires usually only create a vibration.
There are numerous things that can cause the symptoms you mentioned, and it is probably not one single item. I suspect that none of the suspension components have been replaced in your car, and they are all probably past due. Start with the control arms and FCAB's, and the RTAB's. You probably want to change the shocks and struts as well, and all of the mounting hardware, especially the rear shock mounts. The last items to address would be the front hubs and bearings, and the rear bearings, as well as the sway bar bushings and the front and rear swar bar connectors. The front sway bar connectors really should be changed along with the front struts. All of this does not need to be done at once, but you should probably attack it in the order I listed, to get the most bang for your buck.
Old 09-28-2012, 12:46 AM   #12
Russian172
My Ride: e46 sedan e46 m3
off topic thread highjack here
my wheel bearing is bad and the car veers to the left does that mean that the left side is more screwed than the right ?
Thug life one wife
Russian172 is offline   Reply With Quote
Old 09-28-2012, 12:47 AM   #13
S85FTW
Thug life one wife
Yes
Old 09-28-2012, 12:48 AM   #14
Russian172
nice blue ass
youre driving my fave car in the world dude
how does it feel for a DD ?
im a buy one when i go big on selling socks with pockets for drugs
thug life
Old 09-28-2012, 12:56 AM   #15
leetoranges
I just took a bolt out of the front and back passenger side while the car is on the ground, and nothing happened, was i supposed to hit the wheel/force it and see if it moves?
Old 09-28-2012, 12:57 AM   #16
S85FTW
nice blue ass
thug life
It's not my dd, I drive an 07 328xi as a daily but it is better than any other BMW I've owned by far. Plan on getting another winter beater as well.
Old 09-28-2012, 12:59 AM   #17
Russian172
lets trade for my tractor 325i ? for the winter
i remeber you used to have a coupe
Old 09-28-2012, 01:03 AM   #18
S85FTW
No. It would have moved on its own if it was really bad. Do the knock test while driving to work tomorrow.
Old 09-28-2012, 01:03 AM   #19
S85FTW
Haha no chance. Yeah I use to have a zhp coupe.
Old 09-28-2012, 01:06 AM   #20
Russian172
your loss BRAAHH anytime you wanna gimme a ride ?
