Old 09-27-2012, 12:38 PM   #1
McDeshen
My Ride: '99 323i
Yellow line paint splatter
There were wet yellow paint lines in the road, and I accidently went over one on a turn. Paint splattered all over the skirt of the car. What should I do to remove it??
McDeshen is offline   Reply With Quote
Old 09-27-2012, 12:40 PM   #2
MercForHire
My Ride: M235i 6MT
A car wash would do jut fine.
Old 09-27-2012, 12:42 PM   #3
McDeshen
My Ride: '99 323i
Okay, thanks. Didn't know if it would come off that easy.
Old 09-27-2012, 12:44 PM   #4
lsteg
My Ride: 2001 330ci
May have to use something like Bug and Tar Remover if the normal wash doesn't get it all off.
lsteg is offline   Reply With Quote
Old 09-27-2012, 12:45 PM   #5
MercForHire
My Ride: M235i 6MT
First instinct after drinking poison should be self-induced vomit not tweet and ask on a forum about it.
Old 09-27-2012, 02:29 PM   #6
RayPooley
My Ride: 320i SE Coupe
You're not really a people person are you?
Old 09-27-2012, 02:38 PM   #7
stookin
My Ride: 2001 bmw 330i
car wash then brake clean the rest off
stookin is offline   Reply With Quote
Old 09-27-2012, 02:39 PM   #8
rwall
My Ride: 2004 325ci
Car Wash, then Goo Gone?
rwall is offline   Reply With Quote
Old 09-27-2012, 02:42 PM   #9
My Ride: Lexus
Depends on what can't be removed with a pressure washer. I'm sure it's pretty strong stuff if its meant to bond to asphalt. A trip to the body shop might be in your near future
Old 09-27-2012, 02:53 PM   #10
Zell
Zell's Avatar
My Ride: so turbo wow
Were you not supposed to be on the road? If it wasn't marked or anything, you can get the city to pay for the paint work if necessary.
Old 09-27-2012, 02:57 PM   #11
MonkeyMouse
My Ride: 2002 330i ZSP Mtech1
I agree with Zell, it should have been coned off or if two lanes one closed. Thats how they always do it around here any how. But you should be able to get it off with some work. Maybe a 3M eraser wheel in a power drill fallowed by some polishing if it has bonded to the paint.
Trevor
2007 Harley Sportster
2002 BMW 330I sport
1955 Chevy 1st series pickup
MonkeyMouse is offline   Reply With Quote
Old 09-27-2012, 03:05 PM   #12
RayPooley
Ditto.
Old 09-27-2012, 06:11 PM   #13
theOCHO
My Ride: 330i ZHP 6MT
I had this happen to my TT years ago. I tried to clean it up and it didn't work.
I called PennDOT, explained the situation, and they sent me a certificate to have my car detailed. I couldn't believe it.
Might be worth a shot.
theOCHO is offline   Reply With Quote
Old 09-27-2012, 06:41 PM   #14
sunsetcoast
My Ride: '99 323i & '00 323iT
I did the same thing a long time ago. Polishing compound took it off the already-waxed paint (if you don't have any handy, a cleaner-wax combination would be a good low-abrasive substitute). For some reason, though, it didn't work as well on the black rubber bumper or the fender liners.
sunsetcoast is offline   Reply With Quote
Old 09-27-2012, 06:42 PM   #15
nka203
My Ride: 330Ci
Send a message via AIM to nka203
did you try to remove it immediately? if you're quick about it might be able to clean it off with relative ease...before paint hardens.
Also if you havn't washed your car lately the grime and dirt underneath the paint might be good enough to have it clean off.
nka203 is offline   Reply With Quote
Old 09-28-2012, 08:34 AM   #16
sunsetcoast
Well, what did you try? How did it worK
Old 09-28-2012, 09:09 AM   #17
vbfronkis
My Ride: 2001 325iT
Yep, I used Turtle Wax bug and tar remover to get some white line paint off of my passenger side door. There was no indication anywhere that they had just painted the line and I apparently hit it at the apex of a turn.
Sprayed it, let it sit on there for about 10 minutes and it took it right off. Then I washed the rest of my car because I had a clean stripe down the side of my car.
2001 325iT, manual
vbfronkis is offline   Reply With Quote
Old 09-28-2012, 09:50 AM   #18
lsteg
My Ride: 2001 330ci
Glad to hear the B&TR worked for you. I know it's saved me a few times.
