Old 09-09-2012, 03:13 PM   #1
CH715
My Ride: BMW 325CI
Traction control light and eml
Hi Guy
Any Idea why I have randomly started getting a Traction control light and EML on the dash problem is intermittent only on some drives. When I restart the car the lights clear and the car drives fine.
Cant think what it could, few months ago I had the Traction control, Brake light and ABS and that turned out to be a wheel speed sensor that I changed.
Any ideas what this could be? last work I had done to the car was Clutch and flywheel job.
Could it possibly be a bad battery? not sure how long its been in there.
Your help would be really appreciated as iv spent alot of money on this car as it is.
BMW 325CI 2001 msport 146k
CH715 is offline   Reply With Quote
Old 09-26-2012, 09:14 AM   #2
Lordray
My Ride: 2005 325Ci
I had a similar situation last week. I lost power accelerating off a red light. Brake (in yellow), traction, and eml lights came on and rpms were just hovering around 1500. I restarted the car while still rolling and now it's been fine ever since.
Throttle body?
Disa?
ICv?
Anyone know if one of these (or something else) is fixing to die on me?
Lordray is offline   Reply With Quote
Old 09-26-2012, 10:46 AM   #3
Mctwist77
My Ride: '99' BMW 323i
Yeah your car is in limp mode. It's telling you something is wrong and your car is limiting its performance to prevent you from damaging it more. You should go to an Indy or autozone and have them check your engine codes. Usually it has to do with the throttle body but then again it could be anything.
Photobucket
BMW 323I 5 Speed
Mctwist77 is offline   Reply With Quote
Old 09-26-2012, 11:12 AM   #4
Zchild
My Ride: 2000 BMW 3XXi ZSP
+1; start with checking your intake boots to make sure they are connected and without any holes. Next I would look at cleaning the throttle body and idle control valve. ust my two and a half cents worth...
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA
NCC Member Recognition Chairman
NCC High Performance Driving School Registrar
NCC Auto-X BOD Liaison
DIY Senior Committee Coordinator
2006 E90 325Xi & 2000 E46 3XXi
" Vision without resources is just hallucination"
Zchild is offline   Reply With Quote
Old 09-28-2012, 01:23 PM   #5
DrkSide_RbL
My Ride: 99' 328i Sport Sedan
Send a message via AIM to DrkSide_RbL
throttle body may have gunk and is getting stuck. Clean the flaps very well and while youre in there, clean the idle control valve also.
Sent from my SAMSUNG-SGH-I727 using Bimmer App
DrkSide_RbL is offline   Reply With Quote
dsc, eml, traction control light
