Old 09-29-2012, 11:54 AM   #1
eaks
My Ride: 330XI
330Ci AA stage 2.. Boost line?
Hey guys.. I am in the middle of troubleshooting a boost leak in my 01 330Ci with AA stage 2 blower.. I bought a PLX boost gauge/module and tested it out last weekend. It worked.. Now my question is where is the most accurate place to tap into the vac line for a good vac/boost reading? Any pics of the location I should use?
eaks is offline   Reply With Quote
Old 09-29-2012, 09:38 PM   #2
SweTurbo
Big Pimpin'
My Ride: 323i -98
Not easy to get to but yeah thats the best place
Old 09-29-2012, 09:54 PM   #3
eaks
My Ride: 330XI
Sorry I cant even tell where that is.. lol.. can you help me out? Also what size is the tubing (I need to get a T that is that size with one line a 1/8th or whatever i need for my sensor module.. Also does this pic show a hose removed or would I tap into that hose that is connected?
Thanks again!
Old 09-29-2012, 09:58 PM   #4
SweTurbo
Big Pimpin'
My Ride: 323i -98
Port is made for a 8mm hose i think.
Its on the back of the intake manifold(the ports are facing the firewall)
If you look at your intake you'll spot the B and you can go from there.
Old 09-29-2012, 10:01 PM   #5
eaks
My Ride: 330XI
OK thanks.. So its a direct reading of manifold pressure? and there are spare nipples waiting for a hose on the stock intake?
Old 09-29-2012, 11:37 PM   #6
TrippinBimmer
My Ride: Just Fast!
one is 8mm and other 2 is 6mm...
Alpine White M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
Old 09-30-2012, 10:48 AM   #7
eaks
My Ride: 330XI
And I take it stock these are all just capped off??
Old 10-01-2012, 01:31 AM   #8
TrippinBimmer
My Ride: Just Fast!
Depends what year model urs is
Alpine White M3
MaximumPSI Stage4
Old 10-01-2012, 05:20 AM   #9
eaks
My Ride: 330XI
01 330ci!
Old 10-01-2012, 02:12 PM   #10
TrippinBimmer
My Ride: Just Fast!
Originally Posted by eaks View Post
01 330ci!
one line probably be attach in the back for the SAP unit...
Alpine White M3
MaximumPSI Stage4
Old 10-09-2012, 12:22 AM   #11
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
You can T in to the vacuum line that's routed to the bypass valve.
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
