Old 10-01-2012, 09:30 AM   #1
ChrisRedmon
My Ride: 2002 PY ///M3
Advice (55w HID install for ///M3)
Howdy guys, so im willing to take the flaming in trade for answers to my questions. I just bought DDM 55W 5k HID's size DS2 for the Xenon housings in my e46 m3. With it being the 55w i need to get rid of the stock ballast. That's totally fine. Will it throw error codes? Also is there any cutting/drilling required to fit the bulbs into the housing? It seems that there are a lot more harnesses for the stock xenon than the two posi/neg that i came across in my old vehicle. I assume that's the power/ecu connection for the motorized projectors?
Pretty much just confusing myself. Can anyone step by step the install for me? If its simple plug and play we can leave it at that and ill slap them in once im off work today. Thanks guys
2002 Phoenix Yellow E46 M3 l 6MT l Nappa l Nav l STG Coilovers 7k/8k l BMW Performance SSK l OEM ZCP's l Kirk Roll Bar l Motorsport Hardware l Besian Systems l CSL/GTR Carbon Fiber Hood, Trunk & Diffuser l Status Gruppe Sec. 3 l Custom Rear Brace l Rear Seat Delete l Coby Wheel Products
ChrisRedmon is offline   Reply With Quote
Old 10-01-2012, 11:00 AM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Should have bought Morimoto ballasts from TRS. DDM is junk, gives codes, poor light output, poor efficiency, flickering, underpowering the bulbs and just plain dangerous.
You will probably need a wiring harness for 55 wayys.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 10-01-2012, 11:19 AM   #3
ChrisRedmon
Hmm, i had them in my truck for over 2 years with 0 problems. What is the purpose of said wiring harness?
Old 10-01-2012, 11:21 AM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
55 watts uses too many amps to start up. Many people fry their LCM's, clusters, etc with 55w kits
Old 10-01-2012, 11:34 AM   #5
ChrisRedmon
Understood. Well with that being said i guess ill throw in my fog lights (3k 35w) and order a wiring harness
Old 10-01-2012, 12:58 PM   #6
ChrisRedmon
Do you know what wattage the stock xenon run?
Old 10-01-2012, 01:04 PM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
35 and it's a high quality ballast
Old 10-01-2012, 01:07 PM   #8
ChrisRedmon
Okok. So if i was smart i would have bought a 35w bulb in D2S and just swaped the bulbs -___-
