2002 325XI Oil change info? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 08-03-2012, 07:58 AM   #1
wasted0087
My Ride: 2002 325XI
Was just wondering which oil I should use and which oil filter I should use. I'm also replacing the Air Filter so that also.
The Engine oil cap says "BMW recommends Castrol". If that is the case, which castrol would be the best?
wasted0087 is offline   Reply With Quote
Old 08-03-2012, 09:14 AM   #2
boongsin12
My Ride: none
Castrol 0w-30. German castrol.
There are others too so do some search on forum.
Sent from my Nexus S 4G using Bimmer App
2001 330Ci
boongsin12 is offline   Reply With Quote
Old 08-03-2012, 09:39 AM   #3
SamDoe1
My Ride: 4cyl of fury
Old 08-03-2012, 01:49 PM   #4
Dreamliner330
My Ride: 330xi
I just buy the oil at the dealership and get a MANN oil and air filter online. Dealerships often give discounts if you ask and sometimes is cheaper than what you find at Walmart and etc.
Also, please search before creating threads.
Dreamliner330 is offline   Reply With Quote
Old 08-03-2012, 03:43 PM   #5
ixtoxi
My Ride: 02 330xi, 88 325iX
I use Mobil 0W-40. It is a long-life oil. Mann filter.
ixtoxi is offline   Reply With Quote
Old 08-03-2012, 05:30 PM   #6
Kubica
My Ride: 2003 325xi
Motul x-cess 5w-40 and Mann filters.
Change all the other fluids too- especially brake (ate superblue), coolant (BMW), and transfer case (redline d4 ATF).
Old 08-03-2012, 05:51 PM   #7
My325XI
My Ride: 03 325XI Sprt Prem
Here you go...
http://www.bmwusa.com/Standard/Conte...ngineOils.aspx
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
Old 08-03-2012, 07:42 PM   #8
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
any oil that meet the LL-01 spec will work pretty well. I run 5w40 liquimoly @ 5k intervals.
Royal Elite Club of 6 Speed Tourings - founder
redbull 325is is offline   Reply With Quote
Old 08-03-2012, 08:02 PM   #9
EDWAGON
My Ride: 2004 325xiT
Use Mobil1 0W-40 from Walmart and Mahle filter from pelican parts
EDWAGON is offline   Reply With Quote
Old 08-04-2012, 04:16 PM   #10
Bobby330xi
My Ride: '02 330 XI Auto
I use Mobil1 0W-40 from NAPA Autoparts and Mann filters. On sale it runs about $6.49 a qt. Buy 8 quarts so you have some to top off between changes.
Bobby330xi is offline   Reply With Quote
Old 08-04-2012, 08:45 PM   #11
tomoyer
My Ride: 03 325xi, 01 325xi
Send a message via Yahoo to tomoyer
I use Mann filters all the time, and I use either Amsoil European 5W40 or Lubro Moly 5w40, both of which are very good full synthetic oils and meet or exceed BMWs spec. I use Redline ATF and ATE Super Blue brake fluid and pre-mixed Prestone Coolant with a bottle of water wetter. At each oil change, a can of Liqui Moly Jectron and also a can of Liqui Moly Valve Clean are added (used to be called Lubro Moly Jectron Injector Cleaner and Lubro Moly Sauber Valve Cleaner). My oil and filter change interval is 5000 miles.
tomoyer is offline   Reply With Quote
Old 10-02-2012, 02:55 AM   #12
Tong101
My Ride: 2002 BMW 325xi
how many quarts do you guys use? I've been reading some forums and they say we're suppose to use more than 6.5 quarts which is what i use. is that true?!
Tong101 is offline   Reply With Quote
Old 10-02-2012, 08:12 AM   #13
yo_marc
My Ride: 05 325xi
Haven't been able to research this much myself, so I just rely on the oil change kits online - the ones that use BMW 5w30.
yo_marc is offline   Reply With Quote
Old 10-02-2012, 08:24 AM   #14
boongsin12
My Ride: none
It depends on your model. Facelift I think uses 7 qrts whereas pre-facelift is 6.5. Different oil pan capacity.
2001 330Ci
Old 10-02-2012, 09:22 AM   #15
SamDoe1
It takes as many quarts as it takes to fill it up properly. This is ~7-7.5qts. The Xi oil pan is bigger than the RWD models and it also depends on how much you can get out of the pan as well.
