Old 10-01-2012, 02:15 PM   #1
Blind_Shooter
My Ride: is your sister
Question Manual Radiator in Automatic 323i??!!
Call me crazy but the radiator i pulled out of my car looks like a manual transmission radiator not the automatic transmission radiator.
Automatic 323i 2000.
Picture is of old radiator and the new radiator in the box that i bought. Any Idea what this is about??
ID:	471988   Click image for larger version
smells like crayons
Blind_Shooter is offline   Reply With Quote
Old 10-01-2012, 03:40 PM   #2
scarede46er
My Ride: 2001 BMW 325i ZSP
I think the difference is only that you take out a plug in one application and not in the other to plug in the transmission cooler.
Old 10-01-2012, 03:49 PM   #3
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
If it was OE then it comes with two leveling screws, I believe, and you pick the one you need.
If it's Behr, you need to order the proper one for auto or manny trans.
If it's another brand...I have no idea.
See me in June!
dmax on Facebook
Mangofy your E46!
Old 10-01-2012, 04:29 PM   #4
Blind_Shooter
It's autozone brand. Not sure which one. Don't really have enough to order an OEM one. Headed to grab a manual radiator To see if that works or not. Will update shortly
smells like crayons
Old 10-01-2012, 04:46 PM   #5
WDE46
My Ride: '13 128i, '04 330Ci
Should have shelled out $150 for the BEHR just to be sure.
Old 10-01-2012, 04:53 PM   #6
Blind_Shooter
Where can I pick a behr up at?
smells like crayons
Old 10-01-2012, 05:31 PM   #7
seattle86
My Ride: '03 330 Ci
Call me crazy, but both radiators look old and used. The radiator on the left, looks like an Automatic radiator. It has 3 inlets, 1 for upper radiator hose, 1 for lower radiator hose, and 1 for the A/T cooler. The radiator on the right looks like a manual radiator, it only has 2 inlets, 1 for the upper radiator hose, 1 for the lower radiator hose.
seattle86 is offline   Reply With Quote
Old 10-01-2012, 06:52 PM   #8
Blind_Shooter
Autozone is a bunch of idiots. They have the radiators backwards in their system, it shows an automatic radiator for manual and vice versa. I have a new radiator and its going back in tomm hopefully. Never will use them again if I can help it.
smells like crayons
Old 10-01-2012, 07:36 PM   #9
Blind_Shooter
for clarification purposes. Yes seattle86, you are absolutely correct.
smells like crayons
Old 10-02-2012, 06:49 AM   #10
WDE46
This is the cheapest one I know of.
http://www.autohausaz.com/search/pro...er=17119071519
323i, automatic, manual, problem, radiator
