///M3 Forum
Old 10-02-2012, 10:01 AM   #1
gry335i
My Ride: 335i
New member with a question
Hi guys,
Just picked up a 2002 M3 convertible with 70,000 miles! Been loving every minute of it. My question is in regard to the manual transmission. sometimes when I try to get into 3rd or 5th, I get a grinding noise (not all the time) and it is hard to get it into the gears. All others are fine but its 3rd and 5th that are causing the occasional problems. Does anyone know what could be causing this problem?
Thanks in advance guys and glad to join the M3 forum now!
gry335i is offline   Reply With Quote
Old 10-02-2012, 10:23 AM   #2
roadtrip1098
My Ride: 06 STi
Could be a number of things, namely synchros, could even be the linkage - being that both the gears are on the odd side and away from center. Also and guys please correct me on this if I'm wrong, but don't 3rd and 5th exist on the same shaft?
roadtrip1098 is offline   Reply With Quote
Old 10-02-2012, 10:24 AM   #3
roadtrip1098
My Ride: 06 STi
Also, I had a subaru that had similar issues, turns out it was a pilot bearing issue, the clutch was not fully disengaging
Old 10-02-2012, 06:06 PM   #4
gry335i
My Ride: 335i
Thanks for the response, also as I was starting it up this morning(not that cold), I noticed that it cranked a bit longer than on a warm start,is this normal?
Old 10-02-2012, 06:32 PM   #5
itscoo2pyopants
My Ride: E53 4.8is
Send a message via AIM to itscoo2pyopants
it might be because the fluid is cold. mine is like that first thing in the morning putting it from 1-2. when the fluid warms up it gets better. also do you have any info on what type of fluid is in there now? ive heard mixed reviews of redline and royal purple. i stick with pensotin (sp?) mtf-2
itscoo2pyopants is offline   Reply With Quote
Old 10-02-2012, 06:38 PM   #6
illestminimike
My Ride: Project Drama
I'd start by replacing the fluid. By any chance, are you letting the car warm up or just driving off?
Old 10-02-2012, 06:40 PM   #7
dafoe
My Ride: LSB M3
Change all your fluids bro, if haven't already been done, and use OEM FLUIDS!! Shop around for the best prices. Amazon usually has some good prices.
2001 M3, LSB 6spd, purchased 6/09 with 25K miles.
Mods: Coyne Performance built ///M3
dafoe is offline   Reply With Quote
Old 10-02-2012, 06:44 PM   #8
gry335i
My Ride: 335i
I start it up and let it warm up for about a minute before driving it off.
Old 10-02-2012, 10:10 PM   #9
caliscrizle
My Ride: 02 M3
If you read the manual it recommends that you do not let the car sit to warm up it is encouraged that you get in and drive the e46 M3 due to it having a dry sump, but to not drive it hard until the yellow lights by the rpm have moved down to the warmed up level then the engine is ready to be driven at its normal to high operating rate without doing any harm to it .
Sent from my SAMSUNG-SGH-I717 using Bimmer App
caliscrizle is offline   Reply With Quote
Old 10-02-2012, 10:32 PM   #10
illestminimike
^^^this. Don't do that anymore.
Old 10-03-2012, 06:32 AM   #11
roadtrip1098
My Ride: 06 STi
Yes.
Old 10-03-2012, 08:37 AM   #12
gry335i
My Ride: 335i
Thanks for the responses everyone. One more question, is there any way to get the ashtray door off? Mine is a little worn and I wanted to see if I could replace it.
Old 10-03-2012, 09:48 AM   #13
DSilk56
My Ride: M-3 Convertible
I agree with the comment regarding driving the car from cold rather than letting it idle. Just remember to drive it GENTLY until the oil has warmed up to normal temperatures. For what it's worth, the M3 does not have a dry sump engine. It has no external oil pump and no secondary oil reservoir. Instead it has an oil pan, which is attached to the engine and sits just below the crankshaft; all of the oil drains there when the engine is stopped. A dry sump engine has a separate oil tank, like the Porsche 911.
DSilk56 is offline   Reply With Quote
Old 10-03-2012, 12:06 PM   #14
caliscrizle
My Ride: 02 M3
Thanks for clearing that up DSilk. You learn something new everyday, that's why I like this forum.
