Old 06-04-2012, 01:29 AM   #261
cvx5832
My Ride: 325Ci, 325Cic, C300
Exactly that - piezo sirens. There are some labeled piezo buzzers, but I didn't give those a try. There are also several form factors available.
I'm sure if you ask, and had a few minutes to spare, they'd hook them up to a 12v source. Some of them were in sealed packages though.
cvx5832 is offline   Reply With Quote
Old 06-04-2012, 01:36 AM   #262
Alexandrle330ci
My Ride: e46 BMW 330ci Sport
So just piezo sirens and they would test them thanks!! I want over 100db right!? And what if I took a AA battery
Alexandrle330ci is offline   Reply With Quote
Old 06-04-2012, 01:40 AM   #263
cvx5832
It would take 8 AA batteries to deliver 12v, but I don't know about amperage. It may be enough, but check the product info on their website if it's available. The 102db siren is there and it will also give you which stores have it available.
Old 06-04-2012, 01:43 AM   #264
Alexandrle330ci
I'll just get the piezo Soren 102db, I have heard no complaints yet, and I know this will work. Thanks
Old 06-05-2012, 11:37 PM   #265
Alexandrle330ci
Alright so I installed the piezo siren 102db. It was 6.27$ with tax I think haha. Could be a little louder, but hey no complaints. The siren will go off of you hold the trunk button down (panic mode) but, if someone simulates a break in it won't go off :/ atleast for me it won't. Here is a link to what it sounds like. Overall I'm happy.
Old 06-24-2012, 07:38 PM   #266
ccagle
My Ride: 02' 325i
Just did this using the 102db from radio shack... Took about 20 min from start to finish.. Might be the easiest mod I've done yet. Not super loud but is effective enough as an audible alert to assure I've locked it.. Nice mod for under $10. I'd give it a 10 out of 10 for the "bang for buck factor"....
ccagle is offline   Reply With Quote
Old 08-16-2012, 08:54 PM   #267
SlimE46
My Ride: 330xi e46
Originally Posted by Cowspoo View Post
Here's my side of the story.
When I lock my car, there's a light that blinks by the radio. The clown nose has never lit up. I plugged the red into the brown/black and the black into the black/blue. Nothing happened ( I held down the hood trigger).
EDIT:
The only combination for inputs that returns a sound are RED(from buzzer) into Input 1. Black into Input 2. That's a constant LOUD siren immidiately when connected
Combination in OP doesn't produce the unlock/lock beep. In my trunk, it says i'm prewired for a security system too
Anyone have luck on a 2000 3series or know what i'm doing wrong?
I have the same style wiring harness as this guy, anyone ever figure out how to get it to work with these wires?
SlimE46 is offline   Reply With Quote
Old 08-17-2012, 11:23 AM   #268
sdbimmer
My Ride: 2004 325Ci
If the "clown nose" never blinks, then the alarm system needs to be activated. That's the first thing that needs to happen. Then you can figure out the plug wires by tapping into it with a volt meter to find the trigger wire.
sdbimmer is offline   Reply With Quote
Old 08-20-2012, 11:29 AM   #269
Jperry666
My Ride: 2002 325i 5spd
Awesome mod. Did this today with a 120db siren from radio shack. Programmed the lights to blink yesterday with pa soft 1.4.0. So all in all I got an alarm for about 40 bucks.
Is there any way to have the two beeps for locking instead of unlocking?
Sent from my SCH-I500 using Bimmer App
Jperry666 is offline   Reply With Quote
Old 08-21-2012, 09:14 PM   #270
Stiggles
Stiggles's Avatar
My Ride: Was built Fri 13th
Not as far as I know.
Lock = 1 syllable word = 1 beep
Unlock = 2 syllable word = 2 beeps
Stiggles is offline   Reply With Quote
Old 09-18-2012, 12:53 PM   #271
Hovs13
My Ride: E46 325ci
I installed a piezo buzzer (instead of a siren, since I couldn't find one in Canada) and after locking or unlocking the buzzer gives off a faint high pitch tone. After a minute or two it stops.
The tone starts again in several scenarios:
- when a door/trunk/hood is opened/closed
- when a door/trunk/hood is left open it is continuous until you shut it
- when you unlock/lock another bmw (seems to be linked to the signal receiving end of the lock radio)
- and possibly when you drive the car ( i heard it only sometimes but the sound is very faint)
Anyone else notice this?
Wonder if its a result of using a buzzer instead of a siren.
Hovs13 is offline   Reply With Quote
Old 09-22-2012, 02:20 PM   #272
sfcjetjr
My Ride: 2002 BMW 325i
Today I installed RadioShack pn 273-057. Piezo buzzer, 108 db. Works and sounds factory for the most part. Press unlock, two chirps, each time the chirps are a bit different, due to the cycle in which the buzzer is on. Press lock, get one chirp, again sometimes they are a little different depending on cycle last chirp was stopped. Holding truck release button for approx 3-5 seconds, panic mode is activated, and give off incredible alternating sound volume. After 30 seconds panic mode will reset itself as not to kill battery. Mounted is same spot as others, and 108 db is way loud enough and not be obnoxious. Good one!
sfcjetjr is offline   Reply With Quote
Old 10-02-2012, 11:07 AM   #273
Dahmwern
My Ride: 2005 BMW 325xi 5spd.
Send a message via AIM to Dahmwern
I just tried this with the 'Shacks 273-079 (102dB siren - same device as the OP used in his videos). It sounded nice but there was one problem which is why I took it out:
Upon locking the car, 7 times out of 10, the siren would make a half-chirp instead of its full chirp, which sounded sad and tasteless. Its like the siren wasn't receiving the full signal to make a "chirp", so it made a "chi.." instead.
Do other people experience this and are too ashamed to admit that this happens or am I amongst the minority?
Before you ask:
- Yes, I'm pre-wired for alarm, and I tapped into the pre-wiring harness
- Yes, I activated DWA (the alarm function), clown nose blinking, and lock/unlock lights-flashing using my coding computer with NCS Expert
- Yes, I was doing everything correctly
- Yes, I did have a good connection from the siren to the harness, because the unlock chirping worked perfectly.
Any ideas?
| CSL 18" Reps | H&R Coilovers | UUC EVO3 Short Shifter | Conforti Shark Injector | Magnaflow exhaust | TMS Power Pulleys | CAI w/ Custom Built Box | Drilled\Slotted Rotors | ZHP Shift Knob | Brushed Metal Trim | ECS Carbon Fiber Brake Handle | Black Grilles | Angel Eyes | DIY Clutch Stop | DEPO Smoked Corners | DEPO Sidemarkers | DEPO Smoked R/C/R Tails | DIY AUX input | DIY Red Needle Mod | CDV Delete | Front Plate Delete | Debadged |
Dahmwern is offline   Reply With Quote
Old 10-02-2012, 11:20 AM   #274
genuity
My Ride: E46
I experienced the same thing, except I didn't wait to see if the faint high pitch tone would stop. There doesn't seem to be many with this issue that we have
genuity is offline   Reply With Quote
Old 10-02-2012, 11:30 AM   #275
sdbimmer
My Ride: 2004 325Ci
it's because you have a siren and with a siren, the sound will fluctuate up and down (hence the name siren). So when you arm/disarm your car and depending on it the sound is on the rise or on the low, the sound will be different. In your case, the sound also cycles over and over again and you might of caught it when it's about to cycle over again, that's why you are getting a half chirp.
I have the same issue with my siren. Like people have stated earlier, if you want a consistent sound, you might be better off getting a Piezo buzzer.
Old 10-02-2012, 12:51 PM   #276
Dahmwern
You may be right, but why hasn't anyone else been complaining about the weird half chip with this model then (its been used many times)?
Old 10-02-2012, 04:17 PM   #277
Hovs13
My Ride: E46 325ci
The problem is not a half chirp is a very faint hum.
Anyways, I asked my bro to pickup a siren from the states and I swapped my buzzer for the siren. Fixed the problem. It was more of an annoyance. Most people who got into my car couldn't even hear it.
Old 10-02-2012, 05:17 PM   #278
Dahmwern
What siren model did you use?
Old 10-02-2012, 06:25 PM   #279
Hovs13
My Ride: E46 325ci
I switched to the 102dB Piezo Siren
Model: 273-079 | Catalog #: 273-079
Old 10-02-2012, 07:09 PM   #280
Dahmwern
That's the one I used.
You didn't get that weird half chirp on the lock function most of the time? I wonder why I get it in my car...
I'm going to try stripping away some of the wire and soldering the wires on to the harness to get a really good connections and see if that fixes anything.
