Suspension & Braking
Have some questions about suspension or brake setups for your E46 BMW? Get all your answers here! |
#41 |
. FS: Non-sport steering wheel w/ multifunc + airbagFS: 18x8.5 Rota Grids et44 "The suspension should always be faster than the engine" - BMW ![]() [click sig for pics and videos] |
#42 |
really wish they made drop knuckles like they do for my iroc-z
Not from my iphone
#43 |
Weagle Weagle
I'm surprised nobody has posted a diagram of a MacPherson strut roll center. I took this from my vehicle dynamics textbook. It will help you visualize what can be done to raise the roll center.
From the diagram you can see that you can raise the roll center in several ways after lowering: 1. raise inner joint 2. lower outer joint 3. Increase shock lean towards inside 4. increase track width (seems counter intuitive, can someone check that out) Last edited by WDE46; 10-03-2012 at 05:56 AM. Reason: corrected language for raising roll center :-O |
#44 |
Alright sorry I didn't post a diagram, was feeling under the weather yesterday.
I picked up some control arms, a 3.15 diff, fcab bushings, 23/18 sway bars and spindles to use as test subjects (I love having spares lying around). I will post progress but a diagram first on some prototypes. |
#45 |
Weagle Weagle
Don't know why you are apologizing. I saw that I could add some visual so I did
#46 |
lowering ride height adversely affects roll couple it doesnt help it
Not from my iphone
#47 |
Weagle Weagle
#48 | |
#49 | |
#50 | ||
#51 | |||
For a street driven car don't waste your time, spend the time/money on better dampers or more track time. Last edited by vaio76109; 10-02-2012 at 06:23 PM. |
#52 | |
#53 |
this is for a track car already on coilovers.
so i need lower the outer pivot point of the control arm and knuckle. so i have to either elongate the ball joint or knuckle... neither of which seem to have an easy/safe method without major machining and engineering which makes me wonder why nothing has been created for our cars yet... alot of us track them but maybe not enough. Not from my iphone
#54 |
I'm gonna start emailing fabricating companies to make me a set of modified spindles/knuckles.
Should i get drop spindles or simply have them make a lower mounting point for the balljoint???
#55 |
Alright here it is, sorry for the delay:
On the left: Standard Alu control arm, when you press out the ball joint, a bearing cage needs to be installed using circlips to holy her in place. The spherical bearing is pressed into that and also held in place by circlips. A tapered pin is bolted into the tapered ball joint hole on the knuckle. Conical spacers are used to space the spherical bearing down from the control arm for proper alignment. On the right: Much simpler although heavier. Typical XI control arm. It is usable on all rwd 3 series. The ball joint end in the control arm is cut off and a receptacle for the spherical bearing is welded and braced in place. The spherical is either pressed into the receptacle or a spherical adapter is pressed in. Using the taper pin again with the conical spacers, you can then space the spherical down from the knuckle for proper control arm angle. Pretty simple to do, isn't expensive or very time consuming, it just isn't in demand, hence the extravagant price of the kits that are sold. I just picked this up today: I ha e a spare set of Alu control arms now so I will be pressing the ball jojnt out and fabbing up a custom kit for my 323. I will also be fabbing up a set of rear upper control arm spherical bearing cages for peace of mind. |
#56 | ||
#57 |
Weagle Weagle
I see. This makes sense. Just do the opposite to raise things then haha.
#58 | |
Not from my iphone
#59 | |
are they stronger than the aluminum ones?? im considering modifying a set like the drift 240 posted above. what makes the spherical stud stronger than the extended ball joints in relation to shear strength??? Not from my iphone
#60 |
Think about how much a good set of coilovers are, way more than a roll center correction kit and they get easily destroyed.
I think the issue with selling roll center kit is because they don't offer a huge performance gain like other parts would for the same money (ie; 1500$ roll center kit, vs 1500$ with of NT01 Tires and rims). The buyer will always lean to getting the best bang for buck. After their suspension is pretty much all taken care of with poly bushings and adjustable arms, a roll center kit should follow, right? Right if you want to do it right, Wrong if you take the roll center kit fund and sink it into a Dynavin or equivalent waste of money. A suspension system is a system and not individual components. Every single part of the suspension works in harmony to produce a desired, precise steering control, comfort and stability over un even roads and so on. If you have a complete system and chose to not invest in a roll center correction kit for the lower tables and tie rods, congrats on wasting all that cash on parts you will never use to their fullest. Not to mention, enjoy the dangerous bump steer, binding ball joints and other lovely problems you created by not seeing the suspension mods to the end. Last edited by drift.mechanic; 10-03-2012 at 09:01 AM. |
