Sponsored by BimmerWorld
Old 10-03-2012, 10:31 AM   #61
IrocThe325i
My Ride: is turning japanese
dude idt xi control arms fit. the inner balljoints r different
Not from my iphone
IrocThe325i is offline   Reply With Quote
Old 10-03-2012, 10:37 AM   #62
drift.mechanic
My Ride: E46 323i
Yeah the inner ball joint are different, but the outside dia of the ball joint unit is the same. The length of the control arm from the inner bj to the outter bj is different, but that needs to be cut anyways.
The XI control arms are perfect for chopping and welding, nice and strong cast iron. Easily machined too should it require it. (Much simpler to modify the bolt it cast piece than fab a tubular arm, but the bonus of tubular is adjustable caster)
drift.mechanic is offline   Reply With Quote
Old 10-03-2012, 11:13 AM   #63
IrocThe325i
so ur gonna make both inner and outer spherical rod ends?
i just wanna find a fabricator who can modify the knuckles. they do it all the time for steering angle
Not from my iphone
Old 10-03-2012, 11:37 AM   #64
drift.mechanic
My Ride: E46 323i
Yes I will convert both. It isn't a absolute must since no binding will occur with a perfectly flat lower control arm. For reliability on the other hand, I would convert the ball joint to spherical just like the outter.
Now there is also the ease of replacement (with no alignment since their machining tolerances are in 1/10000" in MIL spec bearings), adjustability of the inner and outter with 1/1000" precision, constant adjustment for track then street (with about 10 mins of work), and the list goes on.
Old 10-03-2012, 11:55 AM   #65
IrocThe325i
when do u think ull have it done and tested by? if all works out ill buy a set from you
Not from my iphone
Old 10-03-2012, 12:38 PM   #66
drift.mechanic
My Ride: E46 323i
It's going to be close to Jan 1.
In the works now is a set of tubular spherical control arms with built in roll center correction for Honda/Acura, roll center tie rods for Civic/Integra, eye mount conversion and extended top plates for Civic/Integra (I do many SCCA and CTCC cars as you can see).
It's going to be a while, but I'll get it done
Old 10-03-2012, 03:48 PM   #67
IrocThe325i
okay lemme know im gonna keep doin research
Not from my iphone
Old 10-10-2012, 08:13 PM   #68
IrocThe325i
picking up spindles for 125. gonna mod both ball joint and tie rod mounts 1" lower
Not from my iphone
Old 10-10-2012, 08:31 PM   #69
drift.mechanic
My Ride: E46 323i
Let us know what you think. I did that mod on my old S14, hated it. Inspect the welds frequently, it's a matter of time before they crack.
Old 10-10-2012, 09:15 PM   #70
acpstunts
My Ride: E46 330ci / E53 X5
Im to tired to read through all this right now, but too chime in, Im running the SLR kit and absolutely love it
And depending on the placements of the one bolt, you can run a more drift oriented ackerman or street/track ackerman
acpstunts is offline   Reply With Quote
Old 10-10-2012, 09:51 PM   #71
IrocThe325i
do u have a pic of it installed?
Not from my iphone
Old 10-10-2012, 09:54 PM   #72
IrocThe325i
Old 10-10-2012, 10:07 PM   #73
IrocThe325i
even the bimmerworld race spindles for e36s are welded. Alot of race bmws seem to be using modified spindles usually for the spherical style end. I dont see why i can't build a set to use a streetable generic control arm with a balljoint
im simply going to extend the ball joint seat location without removing the current location but instead drill it out to be able to fit an impact in it. Lots of gusseting and reinforcement prolly a good deal of it overkill but that makes me feel better
heres the motorsport setup using a PTG kit or something:
Old 10-10-2012, 10:15 PM   #74
acpstunts
Sent from my SAMSUNG-SGH-I747 using Bimmer App
Old 10-10-2012, 10:17 PM   #75
acpstunts
Also this pic
Old 10-10-2012, 10:20 PM   #76
IrocThe325i
Also this pic
how much was it? and where can i order it???
Old 10-10-2012, 10:40 PM   #77
acpstunts
Well I bought the adjsutable control arms , and the full kit ran a bit over a thousand. If your interested get ahold of Sean from SLR. Heres his FB: http://www.facebook.com/SLRspeed?ref=ts&fref=ts they have some good high res pics of the kit on chelsea's e46
Old 10-10-2012, 10:55 PM   #78
IrocThe325i
i found there website and emailed him ill see what he says.
I would loveee to run this setupp. i still may attempt to make a setup using factory control arms too. I street my car more than i track it. did only two track events this summer
Old 10-10-2012, 11:05 PM   #79
acpstunts
Ah gotcha. I drift so the increased steering angle was a must for me, and the fact that this kit does/includes so much more made it worht the investment. His work is absolutely on point and he really knows his stuff. I do recommend calling him directly (emails with him sometime take a bit) .
Old 10-10-2012, 11:10 PM   #80
IrocThe325i
thanks for the info!!! i'm definitely considering it
