Go Back   E46Fanatics > E46 BMW > Sponsor Press Releases & New Product Announcements > Site Sponsor Specials and Sales
Find out about the latest specials and sales from our site sponsors here!
Old 10-03-2012, 03:30 PM   #1
Joe@ApexRaceParts
My Ride: E36 M3
APEX | Stud Conversion Kits and Extended Lug Bolts/Free shipping to the U.S. 48!
APEX Wheel Hardware
Apex Stud Conversion kits
Try and find a BMW race car that hasn't converted to studs yet. They're stronger, safer, and improve pit stop times significantly. For non race cars, stud conversions make wheel install and removal much easier as you do not have to line up the holes in your wheels, spacers, and hubs before hand threading in a single lug bolt. Simply slide the wheel onto the studs, and let go. Your wheel will no longer spin around the hub, but will instead be lined up correctly.
APEX 75mm and 90mm Stud Kits with silver or black lug nuts
Extended length studs like these allow for a range of spacers to be used without any additional modification. You can easily use 3, 5, 10, 12mm with a 75mm kit or larger 15, 18, 20mm with the 90mm kit, or no spacer at all. When using lug bolts with spacers you are forced to purchase a different length lug for each width spacer. By remaining installed, the studs put less ware on the threads of your hubs. They guarantee there is enough thread engagement, as you can see how many threads were engaged during install. Wheel studs replace your OEM lug bolts by simply threading into your cars hub. Once installed they do not need to be removed when changing or removing wheels. Only the lug bolts are removed similar to many domestic vehicles.
  • APEX Wheel studs are 10.9 grade steel, and produced in Europe by a TUV approved OEM supplier
  • 75mm length allows for the use of spacers up to 12mm in thickness, or no spacer at all, without making any changes
  • 90mm length is recommended for spacers 15mm and larger
  • The studs have a bulletnose tip that makes lug nut install and removal easy, and prevents cross threading
  • The 75mm head has an integrated 5.5mm hex to make initial installation a breeze
  • The hardened studs are black zinc plated, while the nuts are available in both black and silver zinc plating
  • Studs and nuts are 12x1.5 thread with a 60 degree taper identical to OEM BMW hardware
  • These work on all 1, 3, Z series models, and every other BMW with a M12x1.5 lug. X5/X6, and newer 7 series use different sized hardware and cannot used this conversion
Available Sizes and Pricing:
Available Lug Nut Finishes
  • Black - +$10.00
  • Silver
Installation Kit Now Available! (Includes Red Threadlocker and 5.5mm Wrench)
Apex Extended Lug Bolts
Available in standard OEM length, and extended length version for use with 5, 12, 15, and 20mm spacers. APEX lug bolts can be purchased with either a silver or black zinc coating.
BMW extended lug bolts sold individually
Extended lugs are a must when using spacers, as the standard length lugs are not long enough to thread into the hub properly. If you want new lugs to go with your new wheels and spacers are not needed, then simply select "standard" length from the drop down menu above. If you are using spacers, then select the corresponding length extended lug bolts.
Lug Bolt Specifications:
  • M12x1.5
  • 17mm Hex head
  • 60 degree taper
  • 10.9 Grade
  • Black or Silver zinc finish
  • Made in Europe
Available Lug Bolt Finishes
Silver
Black - +$0.50
Ordering and Contact
  • Phone: Call (888) 499-9135 EXT. #1 for phone orders.
  • Payment: Credit and Debit Cards: Visa, Mastercard, AMEX, Discover, PayPal. Bank Wire Transfers are also available. Contact us to use a wire transfer for payment on your order.
  • Tax: California customers will be charged 8.75% CA sales tax.
  • Shipping: Free shipping only to domestic orders within the lower 48 states. Stud Kits will get free shipping. A full order of Extended Lug bolts with a quantity of 20x will also get free shipping.
  • APEX Hours:
    Monday thru Friday: 9AM to 6PM PST
    Saturday and Sunday: Closed
  • Warehouse and local pickup: The APEX warehouse is at 7888 Marathon Drive, Unit A, Livermore, CA, 94550 (Map It), (888) 499-9135 EXT. #2. This is where you pick up local orders.
  • Service and Installation: Apex Performance Services - Dublin: 6443 Golden Gate Drive, Dublin, CA 94568 (Map It), (888) 499-9135 EXT. #3
| * Joe V. | 888.499.9135 x803 | joe@apexraceparts.com | Facebook | Blog |
Joe@ApexRaceParts is offline   Reply With Quote
Old 10-05-2012, 02:23 PM   #2
Joe@ApexRaceParts
My Ride: E36 M3
Apex stud kits are in stock in 75mm and 90mm lengths. The stud kits make life much easier when installing wheels and tires!
Old 10-12-2012, 04:51 PM   #3
Joe@ApexRaceParts
My Ride: E36 M3
Life becomes much easier once a stud kit is installed on your car. No more worrying about lining up your lug bolt with the hub holes while fumbling holding a heavy wheel and tire!
Please call, email, or pm us with any questions you may have.
Old 10-14-2012, 04:51 PM   #4
acpstunts
My Ride: E46 330ci / E53 X5
Need 10 90mm studs. PM me price please.
acpstunts is offline   Reply With Quote
Old 10-14-2012, 04:54 PM   #5
rcsummers
Mister TechnoMeister
rcsummers's Avatar
My Ride: M3
saved for when i need a stud kit.
"RICH"
EURO.TECHNIKS
My Build Thread
rcsummers is offline   Reply With Quote
Old 10-16-2012, 12:43 PM   #6
yoshii
My Ride: 323i 2k
Bump going to need these soon
///UNDER CONSTRUCTION 323i///
18X9.5 Et33 V710
yoshii is online now   Reply With Quote
Old 10-24-2012, 06:02 PM   #7
Joe@ApexRaceParts
My Ride: E36 M3
Apex Stud Kits are in stock and ready to ship!
Old 10-31-2012, 04:52 PM   #8
Joe@ApexRaceParts
My Ride: E36 M3
Our stud kits are available with a stud install kit. The install kit includes an allen wrench and red loctite to make installation that much quicker and easier for you.
Old 11-02-2012, 08:05 AM   #9
msbhvn
My Ride: Coupe
Hi, I went to buy these yesterday. It won't let me type my home address into your automated system, it only allows for NSW Aus, not the rest of the states and territories.
Can you give me a shipping quote to queens park WA Aus 6107?
msbhvn is offline   Reply With Quote
Old 11-05-2012, 11:48 AM   #10
Joe@ApexRaceParts
My Ride: E36 M3
I have sent you a pm.
Old 11-05-2012, 11:58 AM   #11
yoshii
My Ride: 323i 2k
Ordered friday should be here Tuesday!
18X9.5 Et33 V710
Old 11-06-2012, 04:04 PM   #12
Joe@ApexRaceParts
My Ride: E36 M3
Apex stud kits are in stock in 75mm and 90mm lengths with black and silver lug nut options! Below is our 75mm kit with silver lug nuts.
Old 11-12-2012, 06:09 PM   #13
Joe@ApexRaceParts
My Ride: E36 M3
Apex stud kits are in stock in 75 and 90mm lengths with either silver or black lug nuts! This car is using our 75mm kit with black lug nuts.
Please call, pm, or email us with any questions you may have.
Old 11-17-2012, 02:39 AM   #14
nicco1117
My Ride: black beauty
Send a message via Yahoo to nicco1117
Do you have any special discounts for these? Please pm me pricing for a set of 75mm with black nuts and install kit. Thanks.
filipino pride!!!
nicco1117 is offline   Reply With Quote
Old 03-14-2013, 02:51 PM   #15
Joe@ApexRaceParts
My Ride: E36 M3
75mm and 90mm stud kits are available with silver or black lug nuts!
Old 04-15-2013, 10:37 PM   #16
E5-E46
My Ride: 04 330i
Military discount?
E5-E46 is offline   Reply With Quote
