Rating:
Display Modes |
#21 |
My Ride: 325Ci, 325Cic, C300
This is covered under Fluid Dynamics. The lower the pressure, the more likely you'd get cavitation at the impeller. Cavitation = lower total flow. In extreme and extended cases you'll even get erosion at the blades. In the case of a cooling system this also means lower heat transfer rate due to the bubbles in the system.
Cavitation as defined by Wikipedia : "Cavitation is the formation and then immediate implosion of cavities in a liquid – i.e. small liquid-free zones ("bubbles") – that are the consequence of forces acting upon the liquid.[1] It usually occurs when a liquid is subjected to rapid changes of pressure that cause the formation of cavities where the pressure is relatively low." ![]() Not saying this will happen in your case, but I would be cautious of reducing the designed pressure by half in a system that's been known to be weak to begin with. If you decide to test it, I would start small. Drive around town (no track days to start) and maybe avoid extended drives in elevated ambient temperatures. This is not an attack on the OP, just a little caution if you decide to proceed with the experiment. |
#22 |
It all depends on how hot the car gets. At 1 bar a standard 50/50 water/antifreeze mix boils at ~250 F. At 2 bar its another 35-45 degrees above that.
I dont know about BMWs specifically but anything north of 250 is pretty damn hot inst it? So it seems to me that at least form the perspective of not boiling your coolent 1 bar seems enough no? |
#23 |
The cap has been tested already on a dyno during various running conditions.
You guys all make very good points. One thing I'm curious about is why all other mfg (and even bmw on the newer models) operate their cooling systems at 1 BAR. My e90 and e82 had very solid cooling systems. Nothing like the e46. I'm trying to understand why the earlier models had 2 BAR systems while newer bmw's run 1 BAR.
#24 | |
Thanks for the info. My coolant never rises above 190 degrees in the Texas summers. I'll have to wait a while to compare what my 1 BAR system will do in 100 degree temps. For now, I'm confident the vendors 1 and 1.5 BAR caps will alleviate some issues for e46 models.
#25 |
Electric water pumps. They never have to move at engine speed. Reduced speed equals lower required pressure to keep bubbles at bay at the impeller.
#26 | |
![]() Sapphire Black MetallicNatural BrownSilver Cube e46 330i ZHP/ZCW/6MT - Sold HellrotDove Grey e36 ///M3 - RIP Alpine WhiteTanSand High Gloss e46 330i SunRoofLess/5MT For Sale: $300 winter wheel/tire set (sport edition F7s and Dunlop graspics) For Rent: RTAB Removal/Installation and Preload Tools |
#27 | |
Weagle Weagle
#28 |
Interesting.
Subbed for results
2003 Jeep Wrangler Rubicon 2000 BMW 323ci 1995 Saab 900 SE - JZW Stage 4 |
#29 | |
I signed up to calculate the pressure range at which our cooling system operates, but I need to know the volume of the empty space in the ET for max and min fill levels. Nobody has this info?
#30 | |
#31 |
Wears carbon fiber boxers
My Ride: 330Ci ZHP 6sp
Sub'd as well, but I believe German Auto Solutions has been documenting this for some time now.
E46Fanatic's resident mathemagician
#32 | |
Weagle Weagle
#33 | |
By lowering the total system pressure, the lowest absolute pressure achieved at the impeller will be lower at a system with 1bar vs a system running at 2. Not saying it will be enough for cavitation, but rather saying that the potential for cavitation will be greater. I am also interested at the results. Just throwing my thoughts in as part of the discussion. |
#34 | |
#35 | |
Weagle Weagle
#36 | |
I can't comment on any other potential issues, but boiling should not be an issue. |
#37 | ||
My thoughts: When you fill the system with coolant, the system is pressurized to 1 bar ~ 1 atm with the cap open. 1 bar cap means your system can only withstand 1 bar on top of top that, i.e. up to 2 bars total. Hence, the stock 2-bar cap can withstand pressures up to 3 bars. If you had a barometer that you can stick in the ET while operating the car, it would show anywhere between 1-to-3 bars. The question is whether it is higher than 2 bars or not (so that a 1 bar cap would suffice). By changing the cap to 1 atm, you're not changing the lowest attainable pressure, which is still 1bar = 1 atm, the pressure at fillup with the cap open. The system cannot operate below this pressure by design (unlike in the case of crankcase ventilation, in which case the system has a bit of negative pressure, i.e. vacuum). Of course, if you live 10,000 ft above the sea level, your lowest attainable pressure decreases a little bit, but changing the cap has no effect on this number. With a 2-bar cap, the lowest attainable pressure is still 1 atm (again, pressure at fill-up with the cap open). The difference between these two is the maximum pressures that they can operate at. With a 2 bar cap, you have a wider range of pressure gradient across the system than you would have with a 1 bar cap. That is why I said the local pressure gradient must follow. You have a pressure gradient of 2 bars vs. 1 bar across the system, why would you expect a higher pressure gradient with the latter in your system's components? You don't
#38 | ||
To quote the wikipedia page Quote:
Just because the atmospheric pressure is 1 atm, doesn't mean that the pressure can't drop below that when in motion. By conservation, the areas where the water is moving faster would exert lower pressure than where it's moving slower. Of course I should mention that I'm not a physicist and my understanding could be completely off base. But if I'm understanding this properly, then I could see it being a valid concern, especially at higher RPMs. Last edited by TerraPhantm; 10-04-2012 at 12:40 PM. |
#39 | |
Regardless, we are not talking about the pressure at the impeller or how much it can drop during operation. Question is why would a 1 bar cap would allow a higher pressure gradient across the impeller than a 2-bar cap? If the cavitation is a concern with a 1-bar cap, it could very well be a concern with a 2-bar cap. In fact, more of a concern with the 2-bar cap than the 1-bar cap. 2-bar cap has a greater tolerance than a 1-bar cap, hence by conservation, could allow even lower pressures to be attained across the impeller.
#40 |
Stay stock my friends!
Well, that clears up my confusion about a 1 bar cap...if it does mean 1 bar above the 1 bar pressure it's at naturally.
Based on that, then, then the only advantage I'd see for a lower pressure cap is that it would blow sooner than other components would blow...namely ET. The cap isn't changing the pressure the system runs at, it just rescues it a little sooner when the pressure rises because of some cooling system failure. I don't think it should affect its operation at all; just offers more protection...it seems to me.
![]() This huge woman, like 400 pounds comes up to me and says, "Doug, I would rock your world." I replied, "but I need to breathe." The girl in my sig:http://forum.e46fanatics.com/showthr...highlight=dmax |
