Subframe reinforcement questions - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-04-2012, 09:35 AM   #1
325CiMaN
My Ride: 01 BMW 325ci 3.0L
I am looking to do subframe reinforcement front and rear and all new bushing at the same time. Anyone have any suggestions on where to buy and Where to Get it welded in At I'm in the bay area Napa to be exact. Also looking into getting m3 rear subframe and diff.
325CiMaN is offline   Reply With Quote
Old 10-04-2012, 09:41 AM   #2
My Ride: Lexus
when you say "all new bushings" what do you mean?
Old 10-04-2012, 09:44 AM   #3
Martin 03 325i
My Ride: 03 325I
He probably means control arm bushings
Martin 03 325i is offline   Reply With Quote
Old 10-04-2012, 09:46 AM   #4
325CiMaN
Everything in the rear, diff mounts, subframe mounts, control arm mounts upper only already have lower via adjustable lower control arm from specialty products, Spindle mounts Everything, and i would like to get powerflex or something equivalent to that.
Old 10-04-2012, 09:48 AM   #5
My Ride: Lexus
Ok good. As long as you're aware that there's 21 pieces in the rear total.
Old 10-04-2012, 09:50 AM   #6
325CiMaN
21? ... Uh oh.. Lol well it's worth it, i put allot more power to the rear and don't want to rip my subframe out.
Old 10-04-2012, 09:52 AM   #7
My Ride: Lexus
See sig, second link. scroll to bonus. all part #s are there for you
Old 10-04-2012, 10:14 AM   #8
325CiMaN
How come there isn't any sig when using the app on my phone,
Old 10-04-2012, 10:33 AM   #9
cposk
My Ride: 08' E90 M3
I recently did all of the rear bushings/balljoints and the subframe reinforcement. It is a BIG job, but definitely doable with jack stands and a good set of tools. See my thread to get an idea.
http://forum.e46fanatics.com/showthread.php?t=914098
cposk is offline   Reply With Quote
Old 10-04-2012, 10:34 AM   #10
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
21? There must be a few I don't know of.
Are you including the shock mounts?
Old 10-04-2012, 10:37 AM   #11
cposk
My Ride: 08' E90 M3
2 on each upper control arm, 2 on each lower control arm, 4 subframe mounts, 3 differential mounts, 2 trailing arm. I count 17 in the rear...
Old 10-04-2012, 11:01 AM   #12
My Ride: Lexus
See sig for part numbers. 17 probably then. missed counted. whatever part#s i listed count them
Old 10-04-2012, 11:14 AM   #13
325CiMaN
Thanks guys, i can do it by my self i have a welder. I just want to know where to get the parts from for the best price.
Old 10-04-2012, 11:15 AM   #14
My Ride: Lexus
Most excellent thread cposk. Were you able to achieve ALL of the rear bushings and balljoints using a 2-jaw puller and sockets? Didn't need the special rear end service tool set??
Old 10-04-2012, 11:52 AM   #15
325CiMaN
Thanks for the thread link that really helped out. I think i am going to go with poly bushes.
Old 10-04-2012, 12:10 PM   #16
cposk
My Ride: 08' E90 M3
Pretty much... I had to drill/chisel/pound out the bushings though, which was only possible because I had everything disassembled. Removing the bushings was by far the most difficult part...
I think I used my habor freight shop press ($199 ) to do the 2 smaller diff bushings. 20 tons of force in 1 square inch freaks me out...
Old 10-04-2012, 12:24 PM   #17
cposk
My Ride: 08' E90 M3
Let me be more clear: Yes you can install all the the bushing in the rear end with a 2 jaw puller except for the 2 front differential bushings which have no where for the jaws to grab.
Removing them is a different story. I used a 1/2in drill bit to drill around the rubber. Then I knocked out the center with a hammer. Then I used a saw saw to cut a few slits in the metal casing. Then went to town with a variety of chisels to peal the metal casing out. This is only an option if you remove the entire rear end, as you would for a subframe reinforcement project.
Old 10-04-2012, 12:26 PM   #18
My Ride: Lexus
perfect. got it. so how did you install the two differential bushing? the press right?
Old 10-04-2012, 12:38 PM   #19
Wh33lhop
My Ride: douchemobile
Your 4-piece deficit is probably in the RSMs and sway bar bushings.
Wh33lhop is offline   Reply With Quote
Old 10-04-2012, 12:40 PM   #20
cposk
My Ride: 08' E90 M3
Yes, the press worked well for these because I could brace the frame on both sides. The press didn't work for everything else because the outside lip of the holes is too skinny. The jaw puller was able to grab the lip perfectly (green marks)
Photobucket
