Australia
Check out other E46Fanatics members rides in the Enthusist Directory! If you don't have your garage setup, sign up today HERE |
#41 |
sorry to hijack but im just wondering i got a 320 ci facelift coupe and wanted to know what is the biggest rotor i can go?
will i need to change my calipers ? thanks
#42 |
All depends on your wheels and the inner rim diameter.
Shannon.
#43 |
They are 19 x 8.5 csl 's
#44 |
Still won't be getting any bigger without changing calipers.
(inserts "that's what she said" comment here) |
#45 |
When bleeding brakes make sure you do the corner furthest from the brake master cylinder first, followed by second furthest etc...
EG: Brake master cylinder is near the drivers door in the engine bay, you should do rear-left, rear-right, front-left, front-right. |
#46 |
135i brakes aka. BMW Performance brakes from the E9X (as linked on the ECS site) aka BMW 6 pot Brembos are very good street brakes, good for occasional track use, but for lots of track use I wouldn't recommend them. The pistons in them are prone to cracking under high heat too.
#47 | |
This is also good advice. Quality rubber and Tire width is more important. Last edited by Turbo BMW; 03-19-2012 at 01:01 AM. |
#48 |
Is this for $750 alright?
Porsche 996 calipers brake kit Last edited by Bmw328monster; 10-03-2012 at 05:20 PM. |
#49 |
Yeah this is a popular upgrade. Good price too! I'm still looking to get a set and thinking I'll get the ecs set.
![]() E46 318i with transplant 3.0M54 5sp manual Still have the original washer bottle under the hood WTB new washer bottle |
#50 |
I think I have those on my rears, pretty nice calliper..great price for $750.
#51 |
Modded ///Member
Very good price, make sure you will clean the pistons and check if any leak before you use them,
What's the rotors size? I hope they don't look the same as stock. yes you will see how different between stock brake 1piston vs 4 pistons. if you need any help i'm happy too
#52 | |
#53 |
Here is some motivation...
Brembo GTR 6 Piston Front, 4 Piston Rear: ![]()
#54 |
^ yours Mitch? wow nice. I need a BBK...
![]() Evolve CSL airbox w/Alpha-N tune | KW v2 | Vorshlag Camber Plates | Rogue Engineering RSMs | BBS LM 19x9.5 19x11 | Dixis Ti exhaust | EAS Aurora 60 LED AEs |
#55 |
yep, same setup as Johnca!
#56 |
Nice. Mind PM'ing me where you got it from and how much? Thanks.
#57 |
Not to sound negative, but unless your racing your car. Their a waste anyways, unless your just after the look. In which case no need to get anything better than stock pads and fluid. What size rotors are they?
#58 |
My Ride: 325Ci ClubSport
wow.. for once the australians are answering an American, whos posted in the Aus section, without telling to F**K OFF ..
![]() Good job !! #LetsAllGetAlong
#59 |
F**K OFF ygo...
#60 |
Modded ///Member
It's ok bro I'm sure Australians have better answers than others that's why he posted here ...^^
