Old 10-04-2012, 12:41 PM   #21
cposk
My Ride: 08' E90 M3
Originally Posted by Wh33lhop View Post
Your 4-piece deficit is probably in the RSMs and sway bar bushings.
Oh yeah forgot about the sway bar bushings...
cposk is offline   Reply With Quote
Old 10-04-2012, 12:42 PM   #22
My Ride: Lexus
Good picture. confused again. So the jaw puller worked for installation of every bushing EXCEPT which ones? In other words, what will i need a press for exactly?
Old 10-04-2012, 12:47 PM   #23
cposk
My Ride: 08' E90 M3
#7.
Photobucket
Old 10-04-2012, 12:51 PM   #24
cposk
My Ride: 08' E90 M3
I've seen a thread where someone used a socket and a threaded rod to get them in. Put the socket over the hole in the back, stick the threaded rod/long bolt through the socket through the hole through the bushing, put a washer on the outside on the bushing and crank a nut down on top of it.
Old 10-04-2012, 01:47 PM   #25
My Ride: Lexus
kinda like the MIS rtab tool.. wonder if i could work that somehow.. but then the thread is probably too big
Old 10-04-2012, 02:07 PM   #26
325CiMaN
My Ride: 01 BMW 325ci 3.0L
So who do you guys recommend for poly bushings? And is having solid diff mounts and poly everything else safe? Or is it still a bad idea?
325CiMaN is offline   Reply With Quote
