Old 02-23-2012, 01:41 PM   #61
Commanderwiggin
My Ride: 900rwhp Turbo M3
Originally Posted by mike@maximumpsi View Post
It is a custom one. We can build one for you. Send me an email and I can get you a price.
Are there any negatives to running a one piece driveshaft on the street or a road course? (extra vibrations, etc...)
Also what axles, pumpkin and any additional diff supports are you running?
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Old 02-24-2012, 05:30 PM   #62
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Getting back on topic:
WOW, this UUC Twin Disc clutch & ltw flywheel is one great setup. I've put a few miles on it now, & all I can say is it really feels great.
So far, I'd highly recommend this setup. I'll put a thousand miles on it or so, & I'll report back.
Good luck,
Rob
SUMMIT POINT WV 1:24:229 SCCA
Old 02-24-2012, 06:08 PM   #63
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Good luck,
Rob
My question is exactly what does this twin plate setup offer than the single disc version does not?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 02-24-2012, 06:52 PM   #64
Rob43
Rob43's Avatar
Higher cost.
I think the way to sum it up would be to say: The holding capability of an Extreme 4 or 6 puck race clutch disc, but with the smoothness & drivability of a stock / OEM clutch & flywheel.
Firm pedal feel, with total "slipable" modulation.
Rob
Old 02-25-2012, 12:30 AM   #65
bigjae1976
bigjae1976's Avatar
Higher cost.
Rob
Thanks! That's a good explanation. UUC needs to bring out a 6sp version...I might buy it.
Old 02-25-2012, 09:57 AM   #66
ZeroSum
My Ride: 05 325
thanks! That's a good explanation. Uuc needs to bring out a 6sp version...i might buy it.
+1
ZeroSum is offline   Reply With Quote
Old 02-25-2012, 10:14 AM   #67
TxZHP04
My Ride: ESS TS2+ ZHP
According to Rob it's in the works:
http://forums.bimmerforums.com/forum...3&postcount=15
Old 03-06-2012, 11:08 PM   #68
mach.schnell
My Ride: 08/2000 330Cic x2
What about the proverbial "chatter"? Need to order soon.
mach.schnell is offline   Reply With Quote
Old 03-07-2012, 04:07 PM   #69
SweTurbo
Big Pimpin'
My Ride: 323i -98
Still no pics , why do you teasu us soo much
Old 06-21-2012, 01:57 PM   #70
Sweed
My Ride: 07 6.0L / 04 M3
Bump
AA HKS Stg 2 / Nitrous Express
Sweed is offline   Reply With Quote
Old 08-07-2012, 01:05 PM   #71
Commanderwiggin
Any updates on your UUC Clutch Mike?
Old 09-29-2012, 02:07 AM   #72
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
I came here to ask the same thing.. anyone with really high horsepower ran this clutch yet (600rwhp+)?
I don't mind the OS Giken triple but I'm not against trying other solutions .. if not just to keep my OS Giken for strictly dragging/racing...
Old 10-04-2012, 03:34 PM   #73
E85head
My Ride: E46 M3
Is this compatible with SMG?
E85head is offline   Reply With Quote
Old 10-05-2012, 01:15 PM   #74
Providence
My Ride: HPF Stage 3 m3
Send a message via MSN to Providence
Has any1 tried the twin feramic ?
Providence is offline   Reply With Quote
Old 10-08-2012, 04:49 PM   #75
Forcefed M3
My Ride: HPF Stage 2.75
I heard Ravi has it, but I haven't seen him drive his car for sometime.
Forcefed M3 is offline   Reply With Quote
Old 01-24-2013, 03:01 PM   #76
Commanderwiggin
Any updates...BUMP MAXPSI!
Old 01-24-2013, 10:18 PM   #77
mike@maximumpsi
My Ride: 02M3T
Sorry guys, we didn't have an active account during those earlier posts.
I have the twin feramic in my e36 and it has held everything I have thrown it so far. We have several other units in customer cars also working nicely. We just finished a built m coupe with a 6466 and our twin scroll manifold. The car has a uuc twin with organic discs. We just saw some clutch slip on the Dyno after a few hundred miles of break-in. Since we plan on turning things up a bit we will be swapping the discs to the feramic ones.
02 M3 - Maximum PSI S2 turbo kit - 9.74@145.99, stock motor, stock ECU, first in the 9's
97 M3 - Maximum PSI turbocharged - 8.94@164.33, stock ECU, first in the 9's, first in the 8's
16 M3 - Maximum PSI full bolt ons - 10.27@137, quickest in the US
BMW SOB's turbo E30 - 8.72@158.39
Maximum PSI - Home of the quickest BMW's in the US
Click here for E46Fanatics 1/4 mile standings
Follow us on Facebook and Instagram!
mike@maximumpsi is offline   Reply With Quote
Old 01-25-2013, 12:02 AM   #78
Commanderwiggin
How much abuse have you put the twin feramic through? What kindof power have you been running with it and do you slip it alot when dragging? How much noise when compared to a giken? Would you recommend it over the giken?
Old 01-25-2013, 01:17 AM   #79
wanganstyle
My Ride: e36 M3 / E30 GTS1
The uuc setup is more daily ok than the giken but osg does have a more streetable version available-can just email them to see if they have stock of it stateside
The uuc is made nicely but known to have bolt interference issues with the rear main oil seal and oem bmw bolts.
I sent two uuc units to a client overseas 4th quarter 2012: should be fine for intended application (500-600rwhp). Engines are being built now and ill know if any interference issues show up
Others have used them stateside to about 700rwhp without issues
Os Giken setup if choosen aggressive version should be 1200rwhp ok. Also no known interference with the bolts and the os quality is second to none. I have daily driven other os setups in Japanese turbo cars happily
Sent from my GT-N7100 using Bimmer App
Billet Original CNC LSD for 188K
http://www.wanganstyle.com/
S54B32 E36 M3 DTA S100 Sedan Street car full swap:
http://forums.bimmerforums.com/forum....php?t=1437471
E30 M20 2,7L Alpina + Euro E46 320D ZF 6 speed install
http://www.e30tech.com/forum/showthread.php?t=110010
wanganstyle is offline   Reply With Quote
Old 01-31-2013, 01:49 PM   #80
Rob Levinson * UUC Motorwerks
UUC Motorwerks, *******
Rob Levinson * UUC Motorwerks's Avatar
My Ride: 7s, M5s, M3s, others
Clarification: rare issue seen mostly on Euro motors and a few US motors built with alternate BMW service parts that do not match the spec of original BMW parts.
Issue resolved at this point with a modification of the design to accomodate the alternate bolts.
- Rob Levinson * UUC Motorwerks * 678-679-5360 * uucmotorwerks.com
BIG BRAKE KIT HEADQUARTERS!
ALL CURRENT UUC SPECIALS:
-[ CLICK HERE ]
Rob Levinson * UUC Motorwerks is offline   Reply With Quote
