Old 10-04-2012, 09:43 PM   #1
Weste46
My Ride: 2001 330ci
Interior Lights Issue
My interior lights decided to stop turning on today. I got home and opened my door, and they did not turn on. I put the key in the ignition and turned it to position 1 and pushed the middle light, and got a small fade of light and then nothing. It happens every time now that I try this. The battery doesn't seem to be bad, the car starts just fine, and the trunk lights and smaller overhead lights turn on. So what's the issue? Thanks for any help!
Corbeau FX1 Pro & CR1, Ultimo front coils, Rob43 9-click rear shocks, Swift 10k rear springs, Meyle FCA's, AKG 95a FCA, 75d rear subframe, Powerflex 95a RTA, 95a RCA, ECS 88a diff., ECS SS brake lines, LTW FW, M3 engine mounts, UUC 5sp black mounts, BMW Performance SSK, open-loop EU2 tune, CAI, headers, x-pipe, minus ~180lbs.
Weste46 is offline   Reply With Quote
Old 10-04-2012, 09:44 PM   #2
Weste46
My Ride: 2001 330ci
I forgot to say, the trunk lights and smaller lights turn on when car is off, and ALL lights turn on when car is on.
Old 10-04-2012, 10:09 PM   #3
330xIce
My Ride: 2005 330xi
Send a message via AIM to 330xIce
Did you check the fuse box?
Follow Me On Instagram: JamesMarshall_E46
///My Progress Thread - How To Set a Signature - Black Sedans FTMFW
-James-
330xIce is offline   Reply With Quote
Old 10-04-2012, 10:11 PM   #4
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
Check the fuse box, and check the two ash tray light bulbs for breakage or deterioration. The first time I took my center console out, I ripped the little rear ash tray light bulb off, and those two wires touched and shorted out all my interior lights. So it sounds like a similar issue here.
hi its me alec is offline   Reply With Quote
Old 10-04-2012, 10:23 PM   #5
Weste46
My Ride: 2001 330ci
I wouldn't think it would be a fuse if it turns on at about 5% power EVERY time I pull my key out and put it back in. It never works twice, I always need to put the key back in. Could you send me a quick picture of what ashtray lights you're talking about? I'm not following fully. Thank you for the replies!
Old 10-04-2012, 10:26 PM   #6
Weste46
My Ride: 2001 330ci
When I got home I checked all connections to my angel eyes and one was shorting to the frame, I unplugged the AE's for now and covered anything from shorting any further. I don't see how this could relate though.. the lights work fine when car is on.
Old 10-05-2012, 07:14 AM   #7
Weste46
My Ride: 2001 330ci
Tried again this morning, same thing. I noticed they will turn on after the car is just turned off, but will not let me turn them back on (other than a brief low powered surge) until I start the car again.
Old 10-05-2012, 03:09 PM   #8
Weste46
My Ride: 2001 330ci
Okay, so ive always had a subtle pop come from under my hood after I turn my vehicle off. Now, as soon as the pop happens, that's when the lights stop working. Anything on this pop?
Old 12-09-2012, 01:36 PM   #9
Weste46
My Ride: 2001 330ci
I never updated and thought I should; there ended up being a short from my AEs on the footwell light, but never blew a fuse. took off my Orion Lites and all was well.
Sent from my DROID RAZR MAXX
Old 12-12-2012, 02:24 AM   #10
christmascompany
Banned User
Thanks for sharing the knowledge about Interior lights issue.
christmascompany is offline   Reply With Quote
