E46 Xi Forum
Old 10-25-2011, 09:38 AM   #1
Table3
My Ride: '01 325xi
Question 11 mpg in the city?
I've got an '01 325xi here in Washington, DC. I'm currently getting about 11 mpg in the city, which stikes me as low. All four tires are at about 35psi. I dumped a fuel line cleaner in the tank, but that didn't seem to do anything. I get around 30 mpg on the highway. I welcome any and all suggestions for improving this.
Table3 is offline   Reply With Quote
Old 10-25-2011, 10:02 AM   #2
Kubica
My Ride: 2003 325xi
Prob needs some pre-cat o2 sensors, but 11 mpg is kind of extreme unless you were idling for a long time.
Kubica is online now   Reply With Quote
Old 10-25-2011, 10:02 AM   #3
TR4G-
My Ride: '01 325xi
I get around 16 (tops) in my daily driving to class at college. It makes sense for me, because its due to the type of driving: very short drives with many stop signs and red lights = shitty MPG. Keep in mind, when you actually use gas to accelerate from a stop you are getting VERY low gas mileage
TR4G- is offline   Reply With Quote
Old 10-25-2011, 10:16 AM   #4
Table3
My Ride: '01 325xi
Can you elaborate a bit on that? I'm afraid I'm not knowledgeable enough to know that means.
Old 10-25-2011, 11:38 AM   #5
Kubica
My Ride: 2003 325xi
Replace the two oxygen sensors before the catalytic converters with Bosch units- $45 each shipped from amazon.
Old 10-25-2011, 11:40 AM   #6
Table3
My Ride: '01 325xi
Gotcha, thanks. In theory, what effect should that have?
Old 09-18-2012, 07:05 PM   #7
Les330
My Ride: 2001 330XI
Did you ever change the o2's. If so, did your mpgs go up?
Les330 is offline   Reply With Quote
Old 09-18-2012, 08:33 PM   #8
NJFF26
My Ride: 02 325xi
I drive mostly city with a quick 2 exit trip on an interstate and avg 20mpg cant get anymore. I probably would benefit from plugs and o2 sensors but no codes so for now it stays as is.
NJFF26 is offline   Reply With Quote
Old 09-19-2012, 09:31 AM   #9
325xi1luv
My Ride: 325xi
I have the same issue in my xi I avg 22 over all and now I'm getting 16.9 I
Going to check nitro in the tires and re balance them
325xi1luv is offline   Reply With Quote
Old 09-19-2012, 10:43 AM   #10
Table3
My Ride: '01 325xi
No, never got around to it. Still need to look into this.
Old 09-19-2012, 04:12 PM   #11
tomoyer
My Ride: 03 325xi, 03 330xi
Send a message via Yahoo to tomoyer
Hey Kubica, the Bosch Pre-Cat O2 Sensors you mentioned from Amazon, are they the Bosch 13477s?
tomoyer is offline   Reply With Quote
Old 09-19-2012, 05:13 PM   #12
ixtoxi
My Ride: 02 330xi, 88 325iX
My '02 330Xi gets 24 mpg mixed driving on original O2 sensors and 150k miles.
ixtoxi is offline   Reply With Quote
Old 09-19-2012, 05:56 PM   #13
Kubica
My Ride: 2003 325xi
Correct.
http://www.amazon.com/Bosch-13477-Ox...ype=automotive
Plugs:
http://www.amazon.com/NGK-BKR6EQUP-M...ds=ngk+bkrequp
Air filter:
http://www.amazon.com/Mann-Filter-25...bmw+air+filter
Oil Filter:
http://www.amazon.com/Mann-Filter-HU...tal-Free+Oil+F
Wipers:
http://www.amazon.com/Bosch-422A-ICO...osch+icon+422a
http://www.amazon.com/Bosch-418A-ICO...osch+icon+418a
Old 09-19-2012, 06:23 PM   #14
tomoyer
Thanks for confirming that Kubica. Ordered them as I'm getting the following O2 Sensor codes; E3, E4 CA and CB.
Another question for you, which do you feel is the best thermostat/housing; BMW at $111.95, Behr at $67.95, Wahler at $55.00 or Motorad at $54.68?
Old 09-20-2012, 02:47 AM   #15
Kubica
My Ride: 2003 325xi
I'm running a wahler with no issues.
I recommend replacing the thermostat every 60k miles.
Old 09-20-2012, 06:25 AM   #16
325xittt
My Ride: 2003, 325 XIT
I used the link above to check out the O2 sensors. Don't know if this matters but here is a note from the Ad in Amazon for the O2 sensor.
"Note: Bosch partners with other manufacturers to supply the parts your car was originally built with. This product is in a Bosch package, however the part may have been manufactured by an independent Bosch supplier. "
So does this make it a Bosch part or not?
325xittt is offline   Reply With Quote
Old 09-30-2012, 03:57 AM   #17
YOnpds
My Ride: E46 330ci & M3
Did replacing the o2 sensors fix your problem OP?
YOnpds is offline   Reply With Quote
Old 10-03-2012, 10:19 AM   #18
Table3
My Ride: '01 325xi
Haven't tried yet.
Has anyone else?
Old 10-03-2012, 11:10 AM   #19
Kubica
My Ride: 2003 325xi
Haven't tried yet.
Has anyone else?
You've been driving for a year like this? Not smart.
Old 10-05-2012, 11:17 AM   #20
ZemogFC3S
My Ride: '02 330xi
I had my oil filter housing gasket and ccv replaced a few months ago and my obc mpg went from 17.5 to 21. I drive mostly in the suburbs.
~ '02 330xi
~ '89 RX7 TII
ZemogFC3S is offline   Reply With Quote
