Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 10-04-2012, 11:55 PM   #1
Asher454
My Ride: '04 325xi
Help! Is this cv boot rip?
What is this? And how much to fix??
Asher454 is offline   Reply With Quote
Old 10-05-2012, 01:23 AM   #2
peytonracer4
My Ride: '00 328i
...yeah. it's ripped.
depends on if the u joint is bad or not.
you need to remove the axle. remove the boot. clean the crap out of the joint with brake cleaner and whatever else. absolutely no grime in it. then grease the crap out of it.
then replace the boot.
if you DIY it should've be very expensive at all. just time consuming.
Old 10-05-2012, 01:53 AM   #3
MJLavelle
My Ride: 2001 BMW 330ci
Is it making noise? If so, it is Wasted. If it is quiet, then you may be OK doing what Peytonracer4 wrote.
Old 10-05-2012, 02:54 AM   #4
Asher454
My Ride: '04 325xi
The noise is like a rubbing as if it were rotors, but when I turn the car around 40-50 MPH it makes a slight vibrating noise. :-(, Any estimate as to how much it will be at a indy shop?
Old 10-05-2012, 10:53 AM   #5
Steven747
My Ride: 05 330ci
if this is the inner boot just hammer out the inner side of the axle and replace boot
Old 10-05-2012, 01:10 PM   #6
Asher454
My Ride: '04 325xi
If it is wasted what is the solution
Old 10-05-2012, 01:46 PM   #7
Steven747
My Ride: 05 330ci
you need a new axle if its making noises
Old 10-05-2012, 02:13 PM   #8
peytonracer4
My Ride: '00 328i
This.
Lift up your car and move the wheel forwards and backwards. There should be zero play in the joint.
Old 10-05-2012, 02:25 PM   #9
boostedisbetter
My Ride: 2000 Integra
LOL, looks fine to me....
But seriously, yaaaaa, I'd say that's ripped lol
Looks like it's been coating your suspension with grease for a while now...
^M3 EATER^
boostedisbetter is offline   Reply With Quote
Old 10-05-2012, 02:46 PM   #10
teamdfl
Lemony Fresh
My Ride: 325it
$300 for the GKN Loebro axle
Change the wheel bearing while you are in there.
Mod the driver first. Participate in your local BMWCCA driving school. Have you joined BMWCCA yet?
My Track Schedule
The solution to the lack of headroom in the X6
teamdfl is offline   Reply With Quote
Old 10-05-2012, 04:48 PM   #11
Asher454
My Ride: '04 325xi
Any noise at all? The only noise is slight vibrations, when I turn slightly, I think it's because most of the grease is out of it. and hardly much noise at all. The Indy shop I went to said I need new axles, if It's clicking when I turn and that isn't happening, he told me 225 for the cv boot, which is the outer one, and 385 for the axle.
Old 10-05-2012, 08:53 PM   #12
MJLavelle
Get the axle, and be done with it. Usually, once a CV boot leaks out the grease, the joint is damaged quite guickly. That is why they have a boot full of grease on them in the first place. Even if you get a new boot, the damage is probably already done. For the price difference, I would get a new (or rebuilt) one. Any chance you could do it yourself? It would save a lot of money...
