Old 10-02-2012, 01:33 PM   #1
straight_beamin
My Ride: 2000 bmw 323i
Set me up for eu2 tune. Paypal ready $30.00 usd
Whoever can set me up for the eu2 flash through teamviewer or some other remote app will be sent $30.00 USD. I have become way too frustrated and I need this tune asap.
I have the DIS AND SSS software
PM or respond on thread.
Thanks, Jacob
straight_beamin is offline   Reply With Quote
Old 10-02-2012, 06:36 PM   #2
straight_beamin
Bump, i know its a pita but anyone?
Old 10-03-2012, 06:17 PM   #3
Wickedly
My Ride: 2016 BSM ///M2
We both on the same page dude :/
Wickedly is offline   Reply With Quote
Old 10-03-2012, 10:26 PM   #4
HakenTT
My Ride: 323i with S54
first post your stock extracted file. EU2 is not compatible with all ms43 ecus. Then if I see that is compatible I will send you the file.
HakenTT is offline   Reply With Quote
Old 10-04-2012, 05:29 PM   #5
straight_beamin
it is compatible i have a 323i, how do i extract the file, read pm
Old 10-04-2012, 06:03 PM   #6
smooth1
My Ride: BMW FTW
You have an MS42. Find the Galletto software.
smooth1 is offline   Reply With Quote
Old 10-04-2012, 09:15 PM   #7
straight_beamin
will report back when downloaded
Old 10-05-2012, 10:08 PM   #8
HakenTT
how do you flash it then?
you can't just be flashing your ecu, you can damage it. I got to see your stock software.
Old 10-05-2012, 11:38 PM   #9
straight_beamin
I understand, i downloaded the gellatto software but when i go to read the ecu it says impossible
Old 10-06-2012, 12:28 PM   #10
bikeaddict
My Ride: e46 330ci
I got very frustrated trying to set mine up as well. Tried everything and every guide online step by step. Finally fired up an older laptop and did the steps again to install, and worked great. So in my circumstance, it came down to the lap top and I guess it not working with the newer operating system.
bikeaddict is offline   Reply With Quote
Old 10-06-2012, 10:55 PM   #11
HakenTT
cracked galletto software is for windows XP only.
Old 10-09-2012, 09:43 AM   #12
straight_beamin
ahhh, thanks for help. so if i get win xp and set it up and read stock tune and send it to you and it is compatible it is as simple as you sending me the eu2 tune and me uploading it? thanks jake
Old 10-10-2012, 07:30 AM   #13
darksideracer69
My Ride: 01 325ci
are you still at this?
IMAG02051
Old 10-11-2012, 04:04 PM   #14
straight_beamin
ya man lol, i got windows 7 netbook so it is extremely annoying i think i need someone to do some remote access shit from their computer
Old 10-11-2012, 04:55 PM   #15
straight_beamin
cant i just buy a dme from europe with 12 14 1 430 440 installed on it and put it in my car?
Old 10-11-2012, 05:57 PM   #16
darksideracer69
My Ride: 01 325ci
Seriously? Can you just pick up a laptop off of cl load xp and do it. It's not that hard.
Sent from my SGH-T959 using Bimmer App
IMAG02051
Old 10-11-2012, 06:22 PM   #17
straight_beamin
Ya i was thinking about that just wipe all the shit and do ot fresh. Thanks man thats what im doin
Old 10-11-2012, 08:35 PM   #18
darksideracer69
My Ride: 01 325ci
Make sure you do it right and put the correct drivers for your hard drive on the xp installation disc, or it'll never work. Or get a copy with sata drivers already on a disc from a certain place.
IMAG02051
Old 10-15-2012, 05:56 PM   #19
straight_beamin
As soon as get xp on the netbook i will retry
Old 10-16-2012, 10:37 PM   #20
phubar
My Ride: 335is, HD
Hey man, Ive been struggling in the last couple of days trying to absorb as much info as possible on how to flash eu2 in the 323, just a couple of pointers:
1- You are gonna need winkfp 5.1.6 but all the inpa installs available come with 5.1.0 which wont work at all.
What u need to do is find the 5.1.6 setup package for winkfp and install that first then the rest of the inpa suite. If u do it the other way around and install the regular inpa suite then winkfp 5.1.6, it will SCREW up ur inpa install. I dont know if the mods allow links here for that kind of software so u are gonna have to find them, its not hard just make sure u use the right keywords.
2- I was only able to find one good working install of inpa 5.0.2 by some russian site, its the only one that worked right off the bat without changing anything.
3- You don't need the 20 pin adapter, u can mod the cap (not the connector but the actual cap that u screw onto the 20 pin connector) on the 20 pin connector under the hood by soldering pin 20 to 17 and severing the trace to pin 15, look at the inside of the cap and you'll know what i'm talking about. Again, I don't know if linking to other forums here is allowed or not so google "My DIS/INPA/SSS/CARSOFT/NAVCODER Interface" LOTS of good info in that thread, you just gotta know what to look for.
I went from a very iffy software setup (crashes and errors in every program, leading to a bricked dme) to a rock solid suite, have flashed my car 3 times already, the first time I was in panic mode and to "unbrick" my dme I just did a regular update newer US tune. This morning I flashed a 328 tune with the low compression setting(sluggish) and I just got back from a quick spin after flashing 7528744 "EU2 Exhaust Emission" and "Without Catalytic Converter" off of a 523, I'm gonna try the 528 tune during the weekend see how that goes.
This are just cliff notes, I gotta get to bed, I'm exhausted from kneeling all day in the avionics bay of an ah64d
Just let me know if u have any questions I'll be glad to help.
phubar is offline   Reply With Quote
