Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 10-06-2012, 03:02 PM   #12741
325CiMaN
My Ride: 01 BMW 325ci 3.0L
Originally Posted by tock172 View Post
O2 sensors are probably one of the easiest things to do on an e46. Perhaps easier than your standard oil service. What issues are you encountering?
The wiring is messed up, when i swapped the motor i made sure the o2's where in the right spot, but i have a random misfire while cruising due to engine ruining too rich, and o2 sensors not working properly, while inspecting wiring with my new snap on Digital multi meter i noticed that a few wires were shorted together. So now i am repairing the wire harness and am having issues with rerouting the harness to get to the spot thats shorted out
325CiMaN is offline   Reply With Quote
Old 10-06-2012, 03:04 PM   #12742
KaliVertBoy
My Ride: M3 Vert 6MT
Originally Posted by Beamer Creamer View Post
Did mechanic bounce your car when he did alignment? Prob not but it helps sometimes then you can tell if something else is wrong in system? It might keep going back into same place though i guess , then it wouldnt matter but yeah it does kinda sound like rtab is the area
I don't know if he bounced the car but I'll be sure to tell him to do that next time.
Interior Pioneer avic z2--brushed aluminum vinyled trim--wind deflecter
Exterior Csl front bumper--Gold CSL reps--Macht Schnell spacers 18mmf/10mmr--Ebay trunk spoiler
Performance Macht Schnell intake elbow--K&N drop in--Manzo Headers (still in box lol)-- TCKline/Ground Control Coilovers
Lighting OEM LED taillight retrofit w/ amber vinyl--Chris Brown mod--3500k H7's--6000k morimoto D2s's--6000k ccfl angel eyes--LED's everywhere
KaliVertBoy is offline   Reply With Quote
Old 10-06-2012, 03:10 PM   #12743
tock172
My Ride: '12 135i DCT
Damn I did not know you did a swap. Wiring and electrical issues are a pain in the ass. Hope you get it sorted out soon!
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 10-06-2012, 03:17 PM   #12744
325CiMaN
Ya 3.0l swap, it was pretty smooth process, but now little gremlins are starting to show there faces. Thank god my minor for college is electrical engineering! They are a pain but a challenge so it makes it fun.
Old 10-06-2012, 03:25 PM   #12745
Beamer Creamer
My Ride: 2005 bmw m3
Ya thats how i feel about electrical. Is that a sniffer or what is special with the snap on? Or do you need engineering degree to knownthings to use it for? Also what is the scientific explanation for why you can get really low ohms test on positive wires sometimes? I mean when testing with no power in wires, ground shows near 0 and pos. wire is under 100 ohms? Just as example cuz i cant remember what ohms were but i thot way lower than 100. System worked fine but is that measuring through battery? I duno
Beamer Creamer is offline   Reply With Quote
Old 10-06-2012, 03:35 PM   #12746
jpbutler1983
My Ride: 2001 325Ci
Thought I had a washer fluid reservoir filter leak.... As it turns out the rubber gasket that attaches to the stem which inserts into the filter was just in a bunch. Straightened it up, re-attached, added fluid and voila! I mean the pump is still not working, But I got rid of the "washer fluid level low light"...
At 165450 miles, I have no alarms on my dash! Thank you lord!
Sent from my SPH-D710 using Bimmer App
A man will be the same with a title as he was without one
jpbutler1983 is offline   Reply With Quote
Old 10-06-2012, 03:37 PM   #12747
Beamer Creamer
Ya just get him to bounce front and rear after alignment then look at numbers after again of course. Can prob bounce harder without wreckin paint if push underhood and inside of trunk near trays
Old 10-06-2012, 03:38 PM   #12748
tock172
Pump is only $18. Replaced mine 2 weeks ago when it leaked all of my fluid onto the ground.
Old 10-06-2012, 03:42 PM   #12749
Beamer Creamer
Is washer not seperate fuse from wipers? Coulda pulled? But still have leak i guess, but no light. How much is pump $30? Nevermind, youre prob workin on it. Good to see youre still runnin with 165k. No alarms but how is it otherwise?
Old 10-06-2012, 03:43 PM   #12750
325CiMaN
A digital multi meter aka dmm is a tool to test volts, ohms (resistance), and amps. The snap on one i bought is specifically made for automotive world, it can be hooked up to a lap top and it has a ociloscope, aka oscope. Which helps out diagnosing sensors, intermittent issues, it gives you the wave form of the sensor/actuator and you can watch wave form and compare to a known good sensor, or a known good wave form, and determine what is wrong. On my moms m3 i used it diagnose a intermittent missfire, i checked the coils, i noticed when the coil reaches a temperature of 230 or higher it misses until it cools back down below 230. It's an amazing tool i think everyone should have one and learn how to use it.
Are you testing for ohms with power applied or not? Cause with it applied it it isn't accurate, and a good wire, doesn't Matter if it's positive or negative or signal, should have low ohms like .001-.002ohms.
Old 10-06-2012, 03:51 PM   #12751
Beamer Creamer
The ground for the circuit was disconnected so positive would have just been run from battery pos. but no flow. I def need to learn more but as all these things go it is surprising what people know and can not figure out easy shtuff. Ya oscope and the rest sounds good. I always just looked at prices of $3000 and got turned off and didnt look into anymore. How much was yours?
Old 10-06-2012, 03:59 PM   #12752
325CiMaN
I paid a reasonable 377 for mine brand new, and also Even tho the negative is disconnected and there is no flow threw the positive, the positive electrons are still going crazy in that wire.
I learned electrical from my father add he it's a electrical engineer for Intel and designed the pentium processors and is lead on all the new stuff he isn't allowed to talk about, lol he has taught me everything he knows, which is a God awful amount, the surprising thing, I'm only 20yrsld
Old 10-06-2012, 04:21 PM   #12753
zhenkaaaM3
My Ride: Fst'r then your e46
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 10-06-2012, 06:27 PM   #12754
Beamer Creamer
Ok. Thanks. I kinda figured, so i should really have battery ground disconnected for testing any unknown wires for ohms.
Old 10-06-2012, 06:32 PM   #12755
325CiMaN
Correct, if you have the bently manual there is a HUGE wiring schematic section. It has helped me out a million times.
Old 10-06-2012, 06:36 PM   #12756
I8UR911
My Ride: Spec E46 (01 330Ci)
Installed new slotted rotors and Hawk HP plus pads. Bedded in and ready for the track next weekend!
Sent from my ADR6350 using Bimmer App
I8UR911 is offline   Reply With Quote
Old 10-06-2012, 06:37 PM   #12757
Beamer Creamer
Also i had issue after i put amp wiring behind carpet, i had to use same colored 4 guage wires for ground and one for positive, i was testing with test light and it lit on both wires. It shouldnt matter that both wires were run through loom together or does magnetic field mix somehow. Amp still worked fine so i had no idea. I spent alot of hours running all wires perfectly so i cant think of anything but them running too close to each other but they are close at the amp hookup also, or does that not matter because the magnetic field isnt as strong as over a 4 foot stretch?
Old 10-06-2012, 07:01 PM   #12758
325CiMaN
What does the wires Run ? Are they speaker wires?
Old 10-06-2012, 07:23 PM   #12759
Beamer Creamer
Main power for amp and ground from body to amp. Come on buddy who uses 4 gauge wire for speaker wire. Haha. I got crappy internet connect thru my iphone using hotspot to ipad. Takes awhile to get mail and send messages with hardly any bars connect way up north even for canada
Old 10-06-2012, 07:29 PM   #12760
325CiMaN
I used 8 gauge... Lol ya your fine you shouldn't have any interference
Rate This Thread
