Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 10-06-2012, 05:41 PM   #1
Crestwood1001
My Ride: 2001 325xi
Adding sound deadening to a theater
We have a home theater room in the basement, one wall is the foundation and the other three are drywall. The ceiling is a drop ceiling. The room is under the dining room but the bass from the room is fairly loud through the first floor... We were considering adding some type of insulation in the ceiling because we have the drop tiles down to paint them black.
Does anyone have experience in what type if insulation or any alternative to deaden the sound a bit?
Crestwood1001 is offline   Reply With Quote
Old 10-06-2012, 07:04 PM   #2
GlockMan
GlockMan's Avatar
My Ride: Suburban LT 4x4
Double drywall and green glue.
It works, trust me.
!!! ROLL TIDE ROLL !!!
National Champs: 1925, 1926, 1930, 1934, 1941, 1961, 1964, 1965, 1973, 1978, 1979, 1992, 2009, 2011, 2012, 2015, 2017?
Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI on a BMW board since 2005.
2016 Honda Accord Sedan V6 Touring (wife)
2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD
1968 Ford Mustang with Polk/ADS (my first car)
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
GlockMan is offline   Reply With Quote
Old 10-06-2012, 08:38 PM   #3
Crestwood1001
My Ride: 2001 325xi
I'm talking about the ceiling. It's a drop ceiling
Old 10-06-2012, 08:41 PM   #4
Crestwood1001
My Ride: 2001 325xi
We will not be sheet rocking the ceiling, drop allows access to utility's.
Old 10-06-2012, 08:55 PM   #5
330iPilot
My Ride: Titanium Silver 330i
Then you are stuck. Bass is the most difficult to contain. Adding mass and de coupling the ceiling from the floor of the room above along with all of the other walls is the only way to do it. And it's not cheap.
http://www.soundproofingcompany.com/...oof-a-ceiling/
330iPilot is offline   Reply With Quote
Old 10-06-2012, 09:00 PM   #6
///MPR77
My Ride: 02 ///M3 Tri-Ped
We use Owens Corning 703 or 706 in most studios and control rooms
Wrap in fabric with 3m adhesive spray.
Old 10-06-2012, 09:10 PM   #7
330iPilot
That is for controlling sound reflections within the room. It won't do anything to keep it from escaping.
Old 10-06-2012, 10:01 PM   #8
Crestwood1001
My Ride: 2001 325xi
I'm not trying to completely silence it, just make it less offensive to the rest of the house. It's not just the bass, but that's a big part of it
Old 10-06-2012, 10:30 PM   #9
330iPilot
The problem is the transmission of the sound by vibrating the ceiling which in turn virbrates the floor turning it into a giant speaker. You have to reduce the vibrating by either adding mass, decoupling, or a combination of both.
Old 10-06-2012, 11:06 PM   #10
///MPR77
+1
Lol, just float the room.
Old 10-07-2012, 07:40 AM   #11
330iPilot
+1
That's in essence what the best solution is. You build a room within a room.
Old 10-07-2012, 07:42 AM   #12
Chadrobb4
My Ride: 2003 BMW 325xi
Auralex.com
They have a great guide and products for drop ceiling. Good stuff.
Chadrobb4 is offline   Reply With Quote
Old 10-07-2012, 07:00 PM   #13
330iPilot
They have some good articles on how to control sound.
http://www.auralexuniversity.com/NeighborsReal.html
Old 10-07-2012, 07:41 PM   #14
GlockMan
GlockMan's Avatar
Just double sheet rock the subfloor above the drop ceiling and use green glue.
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
Old 10-16-2012, 01:29 AM   #15
cjrivera
My Ride: 2008 e93 M3 Cab
It works, trust me.
Listen to these guys.
If you really want to isolate sound to that theater room, and have none of it escape to the first floor, you have to follow these suggestions. A drop down ceiling will not be able prevent sound from escaping to the main floor.
Here's another link that discusses noiseproofing a ceiling:
http://www.greengluecompany.com/benefit/how-to-use-it
All these tips are not cheap, but they are definitely worth it if keeping the main floor isolated from the noise from the theater room is important to you.
cjrivera is offline   Reply With Quote
Old 10-16-2012, 01:53 PM   #16
brew
My Ride: F150 X5 MR2
In our last house we did double drywall on the ceiling - and I think we did one layer of normal drywall and one layer of soundboard. We also used some pretty dense bluejean insulation. It worked really, really well. Someone could be blasting a movie downstairs, with explosions and everything, and the sound would be coming up through the stairwell, but not through the floor. I'm a big fan of layering different types of materials (ie., normal drywall and soundboard), so that when one material starts resonating, the other material will dampen it because they have different resonant frequencies. When I build speakers, I layer mdf and plywood together with flexible glue to do the same thing.
brew is offline   Reply With Quote
Old 10-16-2012, 06:13 PM   #17
Guest100615
Account closed per your request
If you insist on maintaining the drop down ceiling then have you considered removing the acoustic panels and filling the space with sound absorbing insulation from Owens Corning ( or even foam insulation) and then replacing the current tiles with sound deadening tiles? That might help if you don't want to throw up sheet rock.
But honest, sheet rock is the way to go. Everyone always brings up the 'access to utilities' excuse and I did too when I did my basement several years ago. But how often do you need to work on the utilities in the ceiling ? Every 10, 20 years ? Maybe never ? Standard sheetrock is only 10 bucks a sheet. It's not going to kill you if you have to rip it off the ceiling and replace 2,3,4 sheets. The only reason I used ceiling panels is because they were already existing in the basement.
sound deadening insulation
http://insulation.owenscorning.com/h...cts/quietzone/
sound deadening panels /solserene
http://insulation.owenscorning.com/a...=&id=4e7c29b90
sound deadening board
http://www.gp.com/build/product.aspx?pid=1071
acoustic sound deadening ceiling panels
http://www.armstrong.com/resclgam/na...-ceilings.html
Guest100615 is offline   Reply With Quote
Old 12-02-2012, 09:31 AM   #18
Con
My Ride: 04 AW M
www.quietrock.com
sheetrock the ceiling.
Con is offline   Reply With Quote
Old 12-21-2012, 10:46 PM   #19
330iPilot
Won't do squat for decoupling issues. Plus it's very expensive.
Old 12-22-2012, 08:03 AM   #20
GlockMan
GlockMan's Avatar
Turn the sub down and bolt some buttkickers to your chairs/couch.
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
