Old 10-07-2012, 07:32 PM   #1
pmagloir
My Ride: 2004 330Ci
Pls. Help Me Identify Oil Leak
Greetings,
I just saw a poodle of oil in my garage and identified it as oil. I warmed up the car and looked around to see where it was coming from and it appears to be coming from the VCG, between the half moons. Car is 2004 330 Ci with 70k, and according to previous maintenance records, VCG and grommets were replaced at 60K by an indy mechanic. Please see picture below. Am I right to assume that I need to replace the VCG? I thank you in advance for your responses to this post.
pmagloir is offline   Reply With Quote
Old 10-10-2012, 05:09 AM   #2
Acrono
My Ride: e46 soon.
Not sure, but possibly valve cover gasket?
Acrono is offline   Reply With Quote
Old 11-17-2012, 11:08 AM   #3
E46705
My Ride: e46
leak
Did you ever find the source of the leak?
Perhaps someone can chime in and identify the source of the oil leak from the pics? i attached a pic too. 330i.
Name:	2012-11-10 08.39.31.jpg
E46705 is offline   Reply With Quote
Old 11-19-2012, 04:35 PM   #4
spennI
My Ride: 2004 330i
It's your Oil Filter Housing Gasket (OFHG) not the VCG. The VCG normally leaks on the passenger side near the firewall. There are several DIYs on this website about OFHG replacement.
http://forum.e46fanatics.com/showthread.php?t=519743
spennI is offline   Reply With Quote
Old 11-19-2012, 04:38 PM   #5
spennI
My Ride: 2004 330i
Originally Posted by pmagloir View Post
Greetings,
Looks like your camshaft position sensor (intake side). This site has a DIY on the main DIY page for this replacement/leak fix. http://forum.e46fanatics.com/showthread.php?t=519743
Old 12-01-2012, 01:01 AM   #6
E46705
My Ride: e46
Here is what my leak looks like on the garage floor.
Sent from my SCH-I535 using Bimmer App
Old 12-01-2012, 01:23 AM   #7
Charmervin
My Ride: 2001 325ci
Really yow... Oil on the floor!!!... Show us a pic of under the car if you really need help... Else, don't waste time...
Charmervin is offline   Reply With Quote
Old 12-01-2012, 01:30 PM   #8
ms328i
My Ride: 99 328i & 04 X5
Replace your valve cover gasket and oil filter housing gasket....might as well replace the spark plugs too while you're there....your car will thank you!
ms328i is offline   Reply With Quote
Old 12-01-2012, 05:59 PM   #9
E46705
My Ride: e46
Valve cover gasket was done last year. I bought the oil filter gasket today.
ID:	480394   Click image for larger version
ID:	480395   Click image for larger version
ID:	480396   Click image for larger version
ID:	480398   Click image for larger version
Old 12-01-2012, 08:32 PM   #10
Fajitas
My Ride: 04 E46
I would suggest also replacing your Vanos oil line along with new crush washers while you're in there.
Fajitas is offline   Reply With Quote
Old 12-02-2012, 02:50 PM   #11
auto180sx
My Ride: '02 Steel Blue 330Ci
Looks like a VCG. Something to try if you have not replaced it yet is to spray off the engine of all the old gunk. Not only is a clean engine a happy one, its easier to see where stuff is leaking from.
Steel Blue FTMFW!!
OKI BMW
BMW CCA Member #444186
auto180sx is offline   Reply With Quote
Old 12-16-2012, 09:11 PM   #12
Dionne11
My Ride: 2004 325i
I just replaced my VCG before i did there was leaking on my exhaust causing smoke after VCG repair it stopped now the only leak i have is my oil filter housing but its less severe than the VCG.
Dionne11 is offline   Reply With Quote
Old 12-16-2012, 09:15 PM   #13
Dionne11
My Ride: 2004 325i
IF you decide to do the VCG DIY i paid someone and then i replaced my vanos and realized how easy it would have been to replace the VCG so lost $202 to the mechanic for something i could have done.Im an idiot.
Old 12-18-2012, 08:23 AM   #14
beemerlbb
My Ride: 04 325XI
I Agree ....the valve cover gasket and the oil filter houseing gaskets are very common and will have tearing your hair out trying to isolate the problems. You might as well go ahead and get it over with because its going to be a problem at some point . just dont wait until it gets worse . Dig in and fix it! Its not hard!. It will take some time ? but? your Beemer is worth it!. Be good to your beemer so it can be good to you!!!!!. LOL!
beemerlbb is offline   Reply With Quote
Old 03-15-2013, 01:21 PM   #15
bmwcanman
My Ride: 2004 330ci m-sport
E46705
Did you ever figure out the problem? I have the exact same situation to the point your pics will do.
bmwcanman is offline   Reply With Quote
Old 03-15-2013, 02:40 PM   #16
E46705
My Ride: e46
Originally Posted by bmwcanman View Post
E46705
PMed you back
