Driveline, Engine & DME Tuning
Talk about driveline improvements, NA tuning and DME tuning your E46 BMW here. This includes diffs, intakes, exhausts, chips, software and OBD tuning. |
#21 |
Yes there is. How do you think they make 500hp n/a Chevy 350s? If everything flows right and has the fuel to back up the extra air then it its totally plausible. Right nite i am working on a m54b30- s52b32 hybrid between the two, because they share the same crank, so basically a dual vanos s52b32 with an aluminum block. I'm going to squeeze as much power as i can na then boost it with a super charger.
Sent from my DROID RAZR using Bimmer App |
#22 | |
^ this guy makes my goal for an aluminum intake manifold seem minuscule.
way to shit all over my dreams man... hopefully with head work and cams i can too reach my nearly 200hp/l mark Quote:
stop playing Need for speed
. FS: Non-sport steering wheel w/ multifunc + airbagFS: 18x8.5 Rota Grids et44 "The suspension should always be faster than the engine" - BMW ![]() [click sig for pics and videos] Last edited by IrocThe325i; 10-07-2012 at 09:20 PM. |
#23 | |
but of you can make one out of aluminum that would be awesome! Cause i could take molds of it and lay carbon fiber and make it carbon fiber, and i could make different throttle body mounts for different size throttle bodys and bolt sizes. Sent from my DROID RAZR using Bimmer App |
#24 | |
. FS: Non-sport steering wheel w/ multifunc + airbagFS: 18x8.5 Rota Grids et44 "The suspension should always be faster than the engine" - BMW ![]() [click sig for pics and videos] |
#25 |
#26 |
I'm waiting on that dyno.
#27 |
#28 |
In for more info on more than 240whp out of a m54 w/o boost
![]() Cosmos Racing V2 CAI | UUC TSE3 | |
#29 |
Keep it clean
Easy. My old setup plus a good tune. Want more? Add head work. 250whp+. Just expensive.
#30 | |
Not from my iphone
#31 |
Keep it clean
Dinan long tube intake with velocty stack and, bored throttle body, Evosport pulleys, ATI damper, Technik Gen3 headers, 3 inch exhaust, Schrick 264/248.
I never had a chance to put the Burns merge on and never dynoed the car with the ATI damper and new filter setup. I may have been right at 240whp. Plus, my intake cam was off a tad.... you never know. I really wanted to hit 260whp, and I think it was very possible. There are a few trick around that I wanted to try. They may die with me ![]()
#32 | |
if u could do 240 wheel which is nearly 300 hp on a 3.0L Not from my iphone
#33 | |
#34 |
I'm very nearly at 200WHP with my 328i and that's with no head work and no cams. With the cams and a tune for the cams, I think I'll break 210-215WHP (250 crank HP)
![]() Check out my band - The Marked 1999 BMW 328i (Daily Driver) - m54b30 intake manifold, ebay headers, Rebirth Motorsports CAI, Rogue Engineering underive pulleys, Epic Motorsports Software, Custom 3 inch exhaust with Burns Merge, Schrick 264/248 Cams 1967 Buick Skylark - 430 Buick Big Block Swap. Last edited by jared_wiesner; 10-09-2012 at 03:12 PM. |
#35 |
My Ride: 2004 330ci ZHP 6MT
Care to explain how? And what's your idea of "nearly" 200whp.
![]() 1995 325i 5mt ArcticGrey/Dove - SOLD 2004 330ci ZHP 6MT SilberGrau/Black - SOLD 2001 330i M-Sport 5MT StaulGrau/Grey - SOLD 1992 Accord LX Sedan 275k miles all original - DAILY 2002 Chevy Suburban LT Autoride - TOY HAULER 2005 GMC Sierra 2500HD SLT - RACE TRUCK! Last edited by E46_330i_Stud; 10-09-2012 at 03:22 PM. |
#36 | |
195 WHP - made with: Headers, M54B30 Intake manifold, True Cold air intake, Rogue Power Pullies, and and Epic Motorsports Tune. Next pull will be with a 3 inch exhaust, cams and an updated tune in addition to the aforementioned parts.
![]() Check out my band - The Marked 1999 BMW 328i (Daily Driver) - m54b30 intake manifold, ebay headers, Rebirth Motorsports CAI, Rogue Engineering underive pulleys, Epic Motorsports Software, Custom 3 inch exhaust with Burns Merge, Schrick 264/248 Cams 1967 Buick Skylark - 430 Buick Big Block Swap. Last edited by jared_wiesner; 10-09-2012 at 03:45 PM. |
#37 |
Still waiting on dyno from 325ciman although I'm pretty skeptical that he made anything over 250whp with what he listed.
#38 |
#39 |
Looking forward to you proving me wrong! I'd like to know more about your build if what you are claiming is in fact true, you said the motor is "toast" so I'm assuming the motor blew?
#40 |
I'll keep waiting. And for the record, I added 20whp. Stock cams, headers and intake manifold. 175whp+ and waiting (maybe) for headers and intake manifold.
