Australia
Old 10-08-2012, 01:20 AM   #21
Davconelectric
My Ride: 2 dog powered sled
Just bolt the dam things on already. It's really not that hard. They might not even fit....
Davconelectric is offline   Reply With Quote
Old 10-08-2012, 01:41 AM   #22
Mitch E46
My Ride: M3 Convertible
A bit of back pressure in the exhaust is good
OP: So whats happening? Warranty replacement or are you installing these bad boys?
Mitch E46 is offline   Reply With Quote
Old 10-08-2012, 03:49 AM   #23
wc325i
My Ride: stick 330
All they have said to me is that the bent wouldn't affect performance, and asked me if the package was damaged when arrived thats all lol... and i emailed them back and waiting on reply
Im going to have a talk with my mechanic to see if i should fix it or not. Otherwise i will probably get it installed end of this week or early next week.
wc325i is offline   Reply With Quote
Old 10-08-2012, 03:59 AM   #24
Davconelectric
Old 10-08-2012, 04:55 AM   #25
wc325i
My Ride: stick 330
Originally Posted by Davconelectric View Post
why you
Old 10-08-2012, 05:50 AM   #26
Davconelectric
Old 10-08-2012, 10:50 PM   #27
Miss325
My Ride: 05 325CiC Individual
They look nice enough, but I would be getting them re-made/replaced. Even at a 50% discount, I would find that level of damage unacceptable (a few scratches or scuffs are all well and good). It'd take far too long sending them back to Denmark IMO, quicker to have them repaired if you don't mind that.
Good luck with the install though, hope it goes well. I'll wait till you post a review on the quality, fit and/or a dyno chart to make up my mind on these
Miss325 is offline   Reply With Quote
Old 10-08-2012, 11:05 PM   #28
ating
My Ride: 2004 M3
^ Miss325 - was that your car recently showed at the Sydney All Stars event?
Evolve CSL airbox w/Alpha-N tune | KW v2 | Vorshlag Camber Plates | WORK Equip 18x10/12 | Dixis Ti exhaust
ating is offline   Reply With Quote
Old 10-09-2012, 12:32 AM   #29
wc325i
My Ride: stick 330
I will most likely get it repaired. Hopefully the fitment will be good and i do want a dyno to see the gains. According to schmiedmann theres a +20HP and 37NM gain on a 330.
Also, normally how much does it cost to get a dyno done?
Old 10-09-2012, 05:53 PM   #30
Miss325
It was, why do you ask?
Sounds like the right move to me. Very keen to hear what your gains are too as it would give me an idea of what I could expect with my car (dying to get my exhaust system flowing nicer as I would imagine there would be a small power gain to be had).
I've had my car dyno'd 3 times, and for the life of me I can't remember how much it cost. I didn't have it dyno tuned though, I just collected my graphs and figures + ECU and sent them away to AA for the tuning. From memory it wasn't a bank breaking excersise at all though.
Old 10-09-2012, 06:16 PM   #31
xixixi
Banned User
My Ride: 01 330x-xi
Lhd
Old 10-09-2012, 10:28 PM   #32
MBM330i
My Ride: e46 330i
Dyno speed run costs are about $50 to $80
E46 318i with transplant 3.0M54 5sp manual
Still have the original washer bottle under the hood
WTB new washer bottle
MBM330i is offline   Reply With Quote
Old 10-10-2012, 02:52 AM   #33
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
my experience was the Schmiedmann headers had quite a few fitment issues - their response - these are aftermarket parts and require modifications to fit properly...took months for them to allow me to return them and get most of my money back...I lost shipping from and to them in EU
/_________\
O==[][]==O
Old 10-10-2012, 05:00 AM   #34
wc325i
My Ride: stick 330
what kind of fitment issues did you have? could you specify?
hopefully these will fit on without too many issues *fingers crossed*
Old 10-10-2012, 05:10 AM   #35
330i ZHP
330i ZHP's Avatar
I had to cut off one of the ears on the transmission, completely modify the trans support and the cats still wouldnt fit up in the tunnel - hung way down from the car and with O2s installed the pipes would not sit flush and level to the rear section - causing a twist on the rear section and making fitment to rear bumper and level tips near impossible
/_________\
O==[][]==O
Old 10-10-2012, 05:11 AM   #36
330i ZHP
330i ZHP's Avatar
their previous installs had only been done with automatic and 5spd cars and diesels
/_________\
O==[][]==O
Old 10-10-2012, 05:16 AM   #37
YGOAMG
My Ride: 325Ci ClubSport
Send a message via MSN to YGOAMG
^ Sh1t.. u even bought BBS boxes from Ebay to go with your LM reps ??..
*i wasnt going to bring it up .. bu couldnt help myself after seeing the pics !!
Find me on Instagram
@PeterMarquez346
Originally Posted by all4show View Post
who da F done that?
prestige warehouse or who?
YGOAMG is offline   Reply With Quote
Old 10-10-2012, 05:18 AM   #38
330i ZHP
330i ZHP's Avatar
nay, plain box and I used a red crayon to make the fake BBS box
/_________\
O==[][]==O
Old 10-10-2012, 06:28 AM   #39
wc325i
My Ride: stick 330
Oh wow, so it didnt fit too well on the 6 spd? I have read on their site, you have do a bit more adjustments to fit it if its 6spd. Since mines 5pd hopefully itll be good lol!
Old 11-02-2012, 06:55 AM   #40
wc325i
My Ride: stick 330
*Update*
I have installed the headers and cats. Took around 9 hrs !!
Anyways, in general fitment was better than i thought, only needed small modifications.
I have attached 5 pictures below and i will explain all the problems i came across.
First picture, once the headers were bolted on, the flange that i circled is touching that metal bit of the car which will cause crazy rattling noise if not dealt with.
To fix this problem my mechanic had to bent that pipe slightly so it's away from the metal bit.
In the second picture, you can see that the header pipes are touching the engine cover and the air con tube. To fix this, my mechanic cut a bit of the plastic off the engine cover and as for the silver tube, it needs to be relocated somehow.... haven't done that yet.
In the third picture, as you can see one of the oxygen sensors wont fit under there so it will have to be relocated somewhere further up that pipe.
Fourth picture is just showing you how the cats sit. Perfect no drama, doesnt hang too low or anything.
Fifth picture. Since the flange (in the first picture) was touching the metal part, that specific cat had to be bent a little bit as well to fit it.
These headers significantly changed the sound my eisenmann race used to make. It's raspy now (past 3.5k revs).. which i dislike.
Drone happens between 1.5k ~ 2k
Fairly quiet during idle
Cruising in 4th gear going 60km pretty quiet.
Here are some vids
ID:	476436   Click image for larger version
ID:	476437   Click image for larger version
ID:	476438   Click image for larger version
