Old 10-07-2012, 09:53 PM   #21
325CiMaN
My Ride: 01 BMW 325ci 3.0L
Yes there is. How do you think they make 500hp n/a Chevy 350s? If everything flows right and has the fuel to back up the extra air then it its totally plausible. Right nite i am working on a m54b30- s52b32 hybrid between the two, because they share the same crank, so basically a dual vanos s52b32 with an aluminum block. I'm going to squeeze as much power as i can na then boost it with a super charger.
325CiMaN is offline   Reply With Quote
Old 10-07-2012, 10:18 PM   #22
IrocThe325i
My Ride: is turning japanese
^ this guy makes my goal for an aluminum intake manifold seem minuscule.
way to shit all over my dreams man...
hopefully with head work and cams i can too reach my nearly 200hp/l mark
you do realize the setup to pull all the N/A power from a motor is completely different than making power on boost...
stop playing Need for speed
IrocThe325i is offline   Reply With Quote
Old 10-07-2012, 10:29 PM   #23
325CiMaN
True for a turbo. If you add a supercharger with only 6-8psi it doesn't matter. If you turbo with 20psi then it matters. And my hybrid motor is still on the drawing plans, i have been working with my machinist for a while on it. Its very plausible.. I can't wait to start machining the Block! but of you can make one out of aluminum that would be awesome! Cause i could take molds of it and lay carbon fiber and make it carbon fiber, and i could make different throttle body mounts for different size throttle bodys and bolt sizes.
Old 10-07-2012, 10:36 PM   #24
IrocThe325i
if i can get it made up ill let you know
Old 10-07-2012, 10:42 PM   #25
325CiMaN
Cool and i can have my machinist flow bench it and see if it had more flow over the stock one.
Old 10-07-2012, 10:51 PM   #26
Iceman00
Banned User
My Ride: E90 6MT
I'm waiting on that dyno.
Old 10-07-2012, 10:59 PM   #27
325CiMaN
I'm lookin I'm lookin! To many computer files!
Old 10-08-2012, 01:38 PM   #28
sedanpowersc
My Ride: 330i 5 speed
In for more info on more than 240whp out of a m54 w/o boost
| BB Gen 3 Headers | Cosmos Racing V2 CAI | Muffler Delete | RE Underdrive Pulleys |
| 3.46 Diff | Tein S-Tech | Bilstein Sports | Hawk HPS | ASA AR1 | 35% Tint |
sedanpowersc is offline   Reply With Quote
Old 10-09-2012, 12:02 PM   #29
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Easy. My old setup plus a good tune. Want more? Add head work. 250whp+. Just expensive.
Old 10-09-2012, 12:22 PM   #30
IrocThe325i
do u have a basic rundown of ur old setup without having read through whole thread??
Not from my iphone
Old 10-09-2012, 12:25 PM   #31
aggieE46
Keep it clean
aggieE46's Avatar
Dinan long tube intake with velocty stack and, bored throttle body, Evosport pulleys, ATI damper, Technik Gen3 headers, 3 inch exhaust, Schrick 264/248.
I never had a chance to put the Burns merge on and never dynoed the car with the ATI damper and new filter setup. I may have been right at 240whp. Plus, my intake cam was off a tad.... you never know. I really wanted to hit 260whp, and I think it was very possible. There are a few trick around that I wanted to try. They may die with me
Not from my iphone
Old 10-09-2012, 02:03 PM   #32
IrocThe325i
r u saying... i can break 250 crank horsepower on my 325i...
if u could do 240 wheel which is nearly 300 hp on a 3.0L
Not from my iphone
Old 10-09-2012, 04:08 PM   #33
sedanpowersc
You never had any head work done?
Old 10-09-2012, 04:09 PM   #34
jared_wiesner
My Ride: 1999 328i (M54b30)
I'm very nearly at 200WHP with my 328i and that's with no head work and no cams. With the cams and a tune for the cams, I think I'll break 210-215WHP (250 crank HP)
jared_wiesner is offline   Reply With Quote
Old 10-09-2012, 04:21 PM   #35
E46_330i_Stud
My Ride: 2004 330ci ZHP 6MT
Care to explain how? And what's your idea of "nearly" 200whp.
1995 325i 5mt ArcticGrey/Dove - SOLD
2004 330ci ZHP 6MT SilberGrau/Black - SOLD
2001 330i M-Sport 5MT StaulGrau/Grey - SOLD
1992 Accord LX Sedan 275k miles all original - DAILY
2002 Chevy Suburban LT Autoride - TOY HAULER
2005 GMC Sierra 2500HD SLT - RACE TRUCK!
E46_330i_Stud is offline   Reply With Quote
Old 10-09-2012, 04:44 PM   #36
jared_wiesner
It's all in my sig but...
195 WHP - made with:
Headers, M54B30 Intake manifold, True Cold air intake, Rogue Power Pullies, and and Epic Motorsports Tune.
Next pull will be with a 3 inch exhaust, cams and an updated tune in addition to the aforementioned parts.
Old 10-09-2012, 06:18 PM   #37
sedanpowersc
Still waiting on dyno from 325ciman although I'm pretty skeptical that he made anything over 250whp with what he listed.
Old 10-09-2012, 06:26 PM   #38
325CiMaN
Ga i found it! But its on my buddys cpu, he it's emailing to me tonight.
Old 10-09-2012, 07:27 PM   #39
sedanpowersc
Looking forward to you proving me wrong! I'd like to know more about your build if what you are claiming is in fact true, you said the motor is "toast" so I'm assuming the motor blew?
Old 10-09-2012, 08:43 PM   #40
Iceman00
Banned User
My Ride: E90 6MT
I'll keep waiting. And for the record, I added 20whp. Stock cams, headers and intake manifold. 175whp+ and waiting (maybe) for headers and intake manifold.
