Old 10-09-2012, 11:45 AM   #1
MercForHire
My Ride: M235i 6MT
Question "RPM vs speed at each gear" table
Hi is there any way to calculate the exact rpm for each gear at every speed with 10 km/h increments.
I want to make a table and commit that to memory so I can perfect revmatch each time.
I realize this table varies with different diff ratios. But any table would be a good start.
Old 10-09-2012, 11:49 AM   #2
NOVAbimmer
My Ride: E60M
www.bokchoys.com most likely has something
NOVAbimmer is offline   Reply With Quote
Old 10-09-2012, 12:12 PM   #3
Guest021715
Account closed.
Plug in your gear and final drive (diff) ratios into Live For Speed (LFS), then drive the car on the simulated track using digital tachometer view.
Worked for me when I was wondering what highway RPM would be for my various cars.
Old 10-09-2012, 12:41 PM   #4
Zell
Zell's Avatar
My Ride: so turbo wow
Well, I don't have a table, but with a 3.07 diff, you can go by the following this "2k RPM" rule. It works pretty well for me and is really easy to remember. With the following, you'll be veeeery close to 2k RPM at these speeds in these gears (in an E46, that is):
1st, 10mph
2nd, 20mph
3rd, 30mph
4th, 40mph
5th, 50mph
6th, 60mph
Old 10-09-2012, 03:25 PM   #5
shanneba
My Ride: 2003 330Ci
Yes, simple physics, diameter of tire times 3.14, take into account the transmission ratio and rear end ration....... convert your tire size units to miles.....
Or you could simply search Yahoo for "Speed in MPH calculation" and find this link: http://www.race-cars.net/calculators...alculator.html
or this one- http://home.netcom.com/~sgalaba/mph.htm
this one gives a table listing three gears: http://www.wallaceracing.com/gear-speed.php
..... SEARCH is your Friend!!
Join BMWCCA
Old 10-09-2012, 03:27 PM   #6
WDE46
My Ride: '13 128i, '04 330Ci
QUOTE=MercForHire;14799689]Hi is there any way to calculate the exact rpm for each gear at every speed with 10 km/h increments.
I realize this table varies with different diff ratios. But any table would be a good start.[/QUOTE]
Yes there are many ways to do it. I will do it right now since I'm bored. BRB
Old 10-09-2012, 03:28 PM   #7
ZHPinthe103
My Ride: 325i Black on beige
this link is horrendous
ZHPinthe103 is offline   Reply With Quote
Old 10-09-2012, 03:28 PM   #8
MercForHire
My Ride: M235i 6MT
They should have this table printed on the dashboard or something.
Old 10-09-2012, 03:45 PM   #9
NOVAbimmer
My Ride: E60M
http://www.bokchoys.com/differential/faq.htm
Old 10-09-2012, 03:59 PM   #10
WDE46
I just made a nice table. It is setup for a 330Ci 5-speed manual with 245/40-17s on the rear wheels. You can put in anything.
https://www.dropbox.com/s/r1rxxal8mv...0vs%20RPM.xlsx
Use a wheel radius in METERS (you'll have to calculate that yourself). Unfortunately, the wheel radius changes with speed and load, so an average is the best I can do. Ratios are unitless by definition.
Attached a screenshot of the plot for those who are without excel.
Wow that used up exactly the time I had left until I leave work hahahaha.
Name:	speed vs rpm e46 330Ci 5 speed.PNG
Old 10-09-2012, 04:03 PM   #11
DangerousMind
My Ride: Sierra 1500 SLT
I have heard of that before. Oh yeah, this guy had it:
DangerousMind is offline   Reply With Quote
Old 10-09-2012, 04:14 PM   #12
My Ride: Lexus
can you make one for a 3.38 diff. this one is the stock 2.93 i assume
Old 10-09-2012, 04:17 PM   #13
MercForHire
My Ride: M235i 6MT
Thanks so awesome :thumb up:
Old 10-09-2012, 04:27 PM   #14
MercForHire
My Ride: M235i 6MT
here is teh metric table.
Old 10-09-2012, 04:57 PM   #15
WDE46
You can edit the file. Just change the final drive ratio value. Maybe I should have just put that as Diff ratio.
