#1 |
Sedan on styles 285 pics pls
Hi there can some of you have this already and post a pic of a sedan with this rims on?! I have a friend who is going to give me then for 150$ but i want to know how it looks thanks rims are like this one:
#2 |
Someone? Or photoshopped or something like that pls
#3 |
For 150 bucks I think even if they don't look good to you, you'd definately be able to resell em for a profit I think those would look great on an e46
2002 325xi Sport 5 speed Euro clears, short shifter, style 119 wheels
2002 GMC Envoy SLT (stock) |
#4 |
$150 for all 4 in good condition? take that deal now
#5 |
+1 I just spent $150 on winter wheels that don't look nearly that good. Do it!
E46 323i Sport/5 speed/TiAg | 231k miles E85 Z4 3.0i Sport/6 speed/Toledo Blue | 74k miles E39 530i M-Sport/5 speed/Topaz Blue | 196k miles Dynavin Android | Laser Interceptor | GRE PSR-800 | STi-R+ | M3 seats | 50W 4300K FX-R Retrofit | Solid black interior | Mtech II front bumper | Koni FSDs Member, Three Pedal Mafia | Long informative article on oil | BITOG German Castrol FAQ ![]() |
#6 |
But, wait, do you plan to put them on your e46? Those are from an e90, right? 17 x 8? I think the offest is ~10mm different. I'd check fit carefully. Even if they don't fit, if they are in good shape, you should be able to resell for a profit. |
#7 |
Yeah i want to put then on my sedan e46 they are 17x8 et34! I thinks they fit perfectly! Is there something wrong with the size or something i should know before buy then?!
#8 |
Are those the stock E90 328i sedan wheels?
#9 |
Yes they are
#10 |
Offset is 34 mm. Both my style 45 (16 x 7) winter wheels and my 17 x 8 style 44s have an offset of 47 mm.
The difference is ~1/2 inch. This means that the inside edge of the wheel will be that much closer to the suspension than on my style 44s. From a "what does this look like" perspective, those 8" style 285s will have the same tucked-in appearance of my 7" wheels. Others may know for certain. But it takes only 5 mins to check for clearance. I'd do this especially if the tires are larger than 225/45. |
#11 |
Sh1tty Advisor
My Ride: 323Ci 5 Speed Black
Buy them and resell.
![]() Oops! My Water Pump Broke Again .................... Coolant in a Bottle |
#12 | |
#13 |
Sh1tty Advisor
I have 17 x 8.5 offset and that's about the maximum limit the fenders can handle.
#14 |
#15 |
So i can't run this on my sedan right? Also i have sport suspension! Let me know if i can run then or not
#16 |
It will stick out 1/2" more than wheels that were delivered with the E46.
But enough back and forth with the electrons. It's a friend selling them, right? The best way to find out is to take 5 mins to mount a wheel and check in the real world. Last edited by sunsetcoast; 10-09-2012 at 05:29 PM. |
#17 |
I will see so nobody have try it yet right
#18 |
They should fit perfectly flush with no rubbing. I tried a set of the 17" 5 spoke coupe wheels from an e92 and they looked great and didn't rub didn't buy them because the seller asked way to much for them and wouldn't accept my offer
Sent from my unknown using Bimmer App
#19 |
I will leave my car like that stock you think they will fit like that? I got sport suspension
