Old 10-09-2012, 03:24 PM   #1
johnny528
My Ride: 2002 325Xi
E46 Loose turnsignal
Hey Guys,
I decided yesterday to clean the inside of my headlights. Everything came out great but the driver side smoked turnsignal wont go in all the way. The clip is not broken and goes in perfectly. The passenger side is nice and snug. Ive tried pushing so hard and it just sticks out and i could even pull it out with my hand without much effort. Whats the issue i dont believe anything is broken.
johnny528 is offline   Reply With Quote
Old 10-09-2012, 03:39 PM   #2
johnny528
My Ride: 2002 325Xi
Here are some pics.
ID:	473250   Click image for larger version
Old 10-09-2012, 03:47 PM   #3
My Ride: Lexus
going to need more pics. try opening the screw more?
Old 10-09-2012, 04:06 PM   #4
johnny528
My Ride: 2002 325Xi
What screw? The one with the clip? As I was observing it looks as if the turn signal goes over the headlight a tiny bit. This really bothers me and I'm afraid of hitting a pothole and losing the turn signal.
Old 10-09-2012, 04:08 PM   #5
My Ride: Lexus
Yeah I'm thinking yours is the same as facelifted models. The screw you see inside the hole of the fender. the one you unscrew to remove the corner light. Maybe open it up more so the corner light bracket goes in between it. if the screw is too tight, it might not line up correctly. of course this is hard to describe without seeing the car. try taking a wide shot showing more of the area. use flash
Old 10-09-2012, 04:13 PM   #6
Brinkley
My Ride: 99 328i, 07 z4 3.0
It's not the same as face lifted models. Pre face lift ones just sort of snap in. I had a similar problem awhile back that was resolved by a new corner
Brinkley is offline   Reply With Quote
Old 10-09-2012, 04:24 PM   #7
johnny528
My Ride: 2002 325Xi
I have pre facelift which is non screw but clip. I really wanna fix tihs and i dont wanna buy a new turnsignal.
ID:	473255   Click image for larger version
ID:	473256   Click image for larger version
ID:	473257   Click image for larger version
Old 10-09-2012, 04:25 PM   #8
johnny528
My Ride: 2002 325Xi
Any other Solutions?
Old 10-09-2012, 04:28 PM   #9
///MPR77
My Ride: 02 ///M3 Tri-Ped
As Mango was saying, loosen the 8mm mounting screws, which will allow you to pull the whole headlight out just a bit, then attach corner lenses, and tighten the headlights with corners attached.
This is what i have to do, but i have LED turn signals, so i dont have to.get in there too often.
Old 10-09-2012, 04:30 PM   #10
2002GreenBMW
My Ride: 2001 325xi
I am having the same problem man, it's because the clip on the back of these aftermarket lights aren't made very well and so they don't engage properly. I have pushed so hard and finally my drivers side went in... However I ended up breaking the passenger side one ... This is my third pair. I have had luck with sealant but idk if you want to go that route..
2002GreenBMW is offline   Reply With Quote
Old 10-09-2012, 04:33 PM   #11
johnny528
My Ride: 2002 325Xi
I tried mangos solution no good. And I know doesn't it suck... I will probably leave the turn signal the way it is opposed to buying a new pair. Thanks for solutions more will be appreciated
Old 10-09-2012, 04:35 PM   #12
///MPR77
You tried pulling the headlights out a bit, and they still wouldn't attach?
Sent from my SAMSUNG-SGH-I727 using Bimmer App
Old 10-09-2012, 04:36 PM   #13
johnny528
My Ride: 2002 325Xi
Ill try to pull further
Old 10-09-2012, 04:39 PM   #14
johnny528
My Ride: 2002 325Xi
It worked love u all
Old 10-09-2012, 04:54 PM   #15
///MPR77
Sweet.
