Old 10-09-2012, 09:14 PM   #41
sedanpowersc
My Ride: 330i 5 speed
Originally Posted by Iceman00 View Post
I'll keep waiting. And for the record, I added 20whp. Stock cams, headers and intake manifold. 175whp+ and waiting (maybe) for headers and intake manifold.
You added 20whp from what??
Cosmos Racing V2 CAI | UUC TSE3 |
sedanpowersc is online now   Reply With Quote
Old 10-10-2012, 07:19 AM   #42
jared_wiesner
My Ride: 1999 328i
He said he's sitting at 175 WHP, 175 minus 20 = 155....
Check out my band - The Marked
1999 BMW 328i (Daily Driver) - m54b30 intake manifold, ebay headers, Rebirth Motorsports CAI, Rogue Engineering underive pulleys, Epic Motorsports Software, Custom 3 inch exhaust with Burns Merge, Schrick 264/248 Cams
1967 Buick Skylark - 430 Buick Big Block Swap.
jared_wiesner is offline   Reply With Quote
Old 10-10-2012, 09:16 AM   #43
sedanpowersc
Yeah i understand that but is that 20whp over stock with just some headwork?
Old 10-10-2012, 09:35 AM   #44
Hornung418
My Ride: 328/4/5
The head is the most restrictive part of our engines, no matter the displacement. Just a simple polish of the OE head castings can improve the flow and increase torque and HP. Why is this hard to understand?
Hornung418 is online now   Reply With Quote
Old 10-10-2012, 11:03 AM   #45
sedanpowersc
I already knew that and i understand, im just asking, he never said what he gained 20whp from so i was confirming that it was in fact from just headwork. By that notion i should make ~215-220whp with headwork and my cai and exhaust considering my car makes anywhere from 190-200 stock
Old 10-10-2012, 11:20 AM   #46
jared_wiesner
My Ride: 1999 328i
He has stock un-ported heads. Headwork will get you very little gain without support from other mods. The head may be restrictive, but only once you open up the bottle neck of the stock exhaust manifolds and even more-so once you have cams. Headwork would be the very last thing I do to an engine that is breathing as well as it can everywhere else. Otherwise you will see very little gain from your money until you do everything else. Headwork will act like a multiplier to every other N/A mod you do. If you do nothing and only headwork, it will net you almost nothing.
Old 10-10-2012, 11:27 AM   #47
sedanpowersc
Got it.
Old 10-10-2012, 07:11 PM   #48
IrocThe325i
My Ride: is built for bends
picking up an intake mani next week for 50 bucks
the flange for the head will run me 80 bucks
velocity stacks no idea
i gotta do some research... Iceman gimme specs for my custom mani!!!
Not from my iphone
FS: Non-sport steering wheel w/ multifunc + airbag
FS: 18x8.5 Rota Grids et44
"The suspension should always be faster than the engine" - BMW
[click sig for pics and videos]
IrocThe325i is offline   Reply With Quote
Old 10-10-2012, 07:49 PM   #49
lui328i
My Ride: 99 Bmw 328i
I have built a custom intake and intake box all made of aluminu
And custom strut bar like no other and was thinking of starting to sell
Them to all fanatics check out my pic hard to see till I
Post more close up pics and also pics of fabrication process
Let me know what u think also built custom exhaust all stainless steel
Havent posted pics every thing is tig welded I have weld and fab shop
Thinking of building intake manifold but need to machine the mounting
Flang but dont know where to go from there dont know how
To actualy gain hp by just incressing volume of mani or what need help
From real knoledgable people, research is not cheap.
Really intressted in going in to performane mods and opening
Performance shop.
lui328i is offline   Reply With Quote
Old 10-10-2012, 09:52 PM   #50
sedanpowersc
Performance shop.
Very interested in see your custom manifolds! Need to dyno before and after and see what you can pick up!
Old 10-19-2012, 02:30 PM   #51
IrocThe325i
just got the other intake so hopefully will get this project goin soon
Not from my iphone
Old 10-19-2012, 06:43 PM   #52
bryce-o
My Ride: 330Ci ZHP 3 pedal
Lol lots of negativity in this thread. Lets see:
11.5:1 high compression pistons (stock CR is closer to 10:1)
272 cams
extensive headwork to flow a claimed 85% more than stock
Id believe 280+ whp from this setup. On a 4 cylinder car, every point you raise the CR is worth 20+whp, after a full dyno re-tune.
bryce-o is offline   Reply With Quote
Old 10-19-2012, 07:23 PM   #53
Russian172
My Ride: Flying brick
i have considered in stalling e90 manifold they seem less restrictive to me but you have to mate the injectors and other electronics
Need a bearing tool in Chicago-land ?http://forum.e46fanatics.com/showthread.php?t=964450
Russian172 is offline   Reply With Quote
Old 10-19-2012, 07:50 PM   #54
fastjasonbmw
My Ride: 330Xi
Fyi, don't use the disa valves from the E90 mani, I had one come apart and get stuck in #6 intake valve, somehow the valve didn't get bent.
If there is room in the m54 head, you could machine some holes for the injectors & fab a custom fuel rail. Assuming the intake ports match up to the m54 head.
fastjasonbmw is offline   Reply With Quote
Old 10-21-2012, 04:49 PM   #55
sedanpowersc
Is this an easy swap/power gain from this?
Old 10-21-2012, 04:54 PM   #56
B_Cyrus
Banned User
My Ride: Malfouf
I'm almost 100% when I say this has never been done before.
B_Cyrus is offline   Reply With Quote
Old 10-21-2012, 08:57 PM   #57
IrocThe325i
yeh i doubt the ports are even close
Not from my iphone
Old 10-21-2012, 10:01 PM   #58
sedanpowersc
Not from my iphone
That's what i was thinking but he was making it sound like it isnt too hard, but from what i understand the manifold isnt the bottle cap but the actual head is so im wondering why even go through the trouble swapping manifolds if it wasnt pretty simple to swap or worth any real gains
Old 10-22-2012, 01:04 AM   #59
Russian172
Because race car mudafaka
Old 10-22-2012, 01:13 AM   #60
secono330ci
My Ride: 04' 330ci & 99' 540i
would be interesting if the n52b30 manifold would bolt up to an m54
secono330ci is offline   Reply With Quote
