E46 Convertible
Thread Tools Search this Thread Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Old 09-06-2010, 08:38 PM   #1
fmzip
My Ride: '08 328xi / '01 530i
So my convertible top stopped working.......
Just inches away of fully closing and the top stops. Light blinks on the top up switch, no movement by holding down the switch.
So here is what I discover. One wire in the harness is completely cut, another is ready to break. The area of concern for reference is in the circled area below, right at he hinge point that is circled.
Here is a picture of the green wire that was close to breaking off next
So what I did was spliced in two new pieces of wire. I made certain the splices where not at the pivot point but beyond it/ Next to the green wire, you can actually seen a black wire (which was the brown and red striped wire which broke) which I replaced. I soldered them in, then wrapped them in electrical tape, then tie wrapped the harness in a few spots along the rail.
Problem solved.
fmzip is offline   Reply With Quote
Old 09-07-2010, 08:35 AM   #2
R1200RT
My Ride: 2004 330CIC
Thanks for the details.
Nick
'04 330CIC, 3 pedals, M Sports\Aerodynamics Packages
'05 BMW R1200RT
'00 BMW R1100S
'04 BMW R1200C Montauk
'95 BMW R100R Classic
R1200RT is offline   Reply With Quote
Old 10-08-2012, 08:13 AM   #3
Snik
Snik's Avatar
My Ride: IR M3 Vert.
nice
Do you ride a sportbike?
Old 10-11-2012, 09:09 PM   #4
Pbergunder
My Ride: 2004 M3 Convertible
So did you splice the open the harness to check the wire?
Pbergunder is offline   Reply With Quote
Old 10-12-2012, 09:34 AM   #5
fmzip
yes.............
as pictured
Old 10-12-2012, 10:21 AM   #6
taylor192
My Ride: 2003.5 M3
This must be a common problem, the PO of my car had this exact same repair done.
Old 10-16-2012, 08:10 PM   #7
fmzip
It is a common problem. Wish it would stay at the top of this forum so I could stop pointing countless people to it
Old 10-17-2012, 11:15 AM   #8
johnrando
My Ride: '06 330 CIC ZHP
You could consolidate the most common vert top fixes (that wiring one, the bat wing issue, etc) into one thread linking to the DIYs and ask the mods to sticky it.
John '06 330 Cic ZHP
Southern California
ZHP, Cold Weather Pkg., Leather, Jet Black/Black/Black Cube, NAV
AA Tune, Sprint Booster, BMW Perf. Intake, Magnaflow Exhaust, Dinan STEP S/W & TB, TMS Pulleys, H&R Touring Cup Kit
BMW Perf. Strut Brace, Orion V2 Angel Eyes, No-holes License Plate, SMG Paddle Shift Mod, Besian VANOS, Gold DISA, Fan delete
Old 10-17-2012, 01:37 PM   #9
dcdude68
I think you meant slice (and peel back) the harness cover to get access to make the splice? Just trying to clarify.
Either way, Fran: what did you use to re-wrap the wires with for protection? Were you able to tuck the harness out of the way so it won't get pinched again?
dcdude68 is offline   Reply With Quote
Old 10-17-2012, 03:43 PM   #10
fmzip
I cut open the braid, inspected the wires and spliced in new wire where need be. Next, soldered (no clean solder) and used shrink tubing. Then I used electrical tape to tape the braid back together
It's not that they are getting pinched, it's that they are being bent over and over again which causes the wire to fracture. No way around this from happening
BMW should have used some heavier gauged wire or one with a thicker jacket. That's what I used when I made the splice.
Old 10-17-2012, 06:06 PM   #11
Snik
Snik's Avatar
Yeah. They should've used braided wiring.
Wonder how they do all this in the current hardtop verts.
Old 10-17-2012, 06:51 PM   #12
fmzip
I did that.....
they stickied another thread instead but no one reads that one either:
http://forum.e46fanatics.com/showthread.php?t=854059
Old 02-25-2014, 12:06 AM   #13
gamefacenyc
Account Under Review
My Ride: bmw/others
my top is not working button flashing all the time and does nothing when pressed. i can manually open and close the top and ive checked the motor and it has oil in it and you can hear it turn on when i connect back the car battery. is there any relays or fuses to check?
gamefacenyc is offline   Reply With Quote
Old 02-25-2014, 12:32 AM   #14
taylor192
My Ride: 2003.5 M3
Originally Posted by fmzip View Post
I did that.....
Ironic.
Old 02-25-2014, 12:40 AM   #15
gamefacenyc
My Ride: bmw/others
i have checked my cables and nothing is cut
Old 02-25-2014, 10:18 AM   #16
taylor192
My Ride: 2003.5 M3
Did you visibly check them? or electrically test them?
If you didn't electrically test them, go do it. Wires can break internally, or at different bends. The first bend above the drivers seat is the most common bend, yet not the only bend the wires break.
Alternatively get the codes get by a shop. A blinking light means a code is stored, it is unlikely to be a fuse. If you want to check fuses, the fuse panel has a guide indicating all the fuses for the top.
Old 02-25-2014, 11:58 AM   #17
Kay D Boss
I have a 325ci, if you just need to buy some time. Lower the top completely, manually. Press the reset button below the arm rest in the back seat. Dont remove the seat! The reset button will release the roof from the hydraulic mechanism. Then you can close and ooen it manually. Call momentum bmw parts dept ask for e46 convertable allen wrench. Totally cost 7$ lol. .
Kay D Boss is offline   Reply With Quote
Old 02-25-2014, 12:01 PM   #18
Kay D Boss
And also the hydraulic fluid may be low . The reservoir is in the trunk on the left side behind the lining. Consult a professional for that. The fluid cost about 12$.
Old 02-25-2014, 01:26 PM   #19
taylor192
My Ride: 2003.5 M3
1. The latest poster has stated he's able to manually open/close the top.
2. The release button under the rear seat releases the mechanical latches that keep the storage lid locked tight. It has nothing to do with the hydraulics. The hydraulic system only pressurizes when the car is on, and depressurizes after about 30 secs. That's why you have to wait to manipulate the top manually after the car was on.
I don't mean to be rude, just there's so much misinformation on the top that it needs to be corrected or we end up answering even more questions later on.
Old 02-25-2014, 01:27 PM   #20
taylor192
My Ride: 2003.5 M3
No need to consult a professional, don't scare members away from fixing their top. The sticky about hydraulics explains why the fluid may be low, where to look for leaks and how to fix them economically.
