Other BMW Models
All other BMW model questions! For additional model specific forums check out bimmerfest.com! Please post all E90/E91/E92/E93 and new M3 news at E90Fanatics.com |
#41 |
Was there a facelifted version of the E39?
#42 |
There are different bumper/suspension/interior packages, like the E46.
#43 |
100% star stuff
Yes. '97-'00 prefacelift, '01-'03 facelift.
![]() Bilstein/Eibach B12 Pro-Plus Suspension System | DICE Mediabridge | Valentine One |
#44 |
#45 |
Fully Deeked Out
That's kind of the point.
#46 |
Sh1tty Advisor
My Ride: 323Ci 5 Speed Black
![]() Oops! My Water Pump Broke Again .................... Coolant in a Bottle Last edited by MercForHire; 10-12-2012 at 01:48 PM. |
#47 |
I checked the local autotrader and it seems that unless its an M5, all the E39 are pretty much Automatics.
#48 |
Fully Deeked Out
I couldn't find any manuals either, but holy cow those things are cheap now. I had no idea.
![]() Last edited by choxor; 10-12-2012 at 02:14 PM. |
#49 | |
Again, this is why I'm tempted by the 5-speed manual 530i sports that have popped up in my area. And yes, Choxor, they've gotten ridiculously cheap... very tempting.
#50 |
Fully Deeked Out
Well hell, if you can find a cheap one in good knick I say go for it. If you like it during the test drive, of course. Lots of unplanned expenses come up when you buy a house. The extra cash could help.
#51 | |
100% star stuff
![]() Bilstein/Eibach B12 Pro-Plus Suspension System | DICE Mediabridge | Valentine One Last edited by tock172; 10-12-2012 at 02:41 PM. |
#52 | |
My only concern is that the roundels are faded and the headlights are fogged, indicating that the owner didn't care that much about the exterior... but my ZHP had faded roundels when I bought it too and it's been pretty great as far as what's been done by the PO. I'm definitely going to at least check it out.
![]() Last edited by EverydayGetaway; 10-12-2012 at 02:44 PM. |
#53 |
i use to have an 03 530i sport pkg w 5 speed and honestly i regret selling it, it was a beautiful car, smooth, quick and always brought a smile to my face, and it was so incredibly clean, but i wanted something a little smaller so went back to the E46's but if i ever came across another 5 speed one too id probably take it...as long as its an 02-03. Right now however im looking for a 04+ 5 series just because i drool whenever i see that body style and i love the way they drive and all the techy bits in them.
2002 325xi Sport 5 speed Euro clears, short shifter, style 119 wheels
2002 GMC Envoy SLT (stock) Last edited by afstud; 10-12-2012 at 03:29 PM. |
#54 |
Do they all have heated steering wheels?
#55 |
My Ride: '06 330CiC, '03 M5
E39's do not have heated steering wheels, however, you can modify the slip ring in the steering column and install an X5 heated wheel on the car. Many owners swap the wheels from season to season as they do not like the non sporty M5 heated wheel.
I was wondering if you could get Sport wheel recovered and install the X5 heating element? Then you need sort out a way to power/control the heated wheel. Maybe off the heated drivers seat?? Maybe off the switching center? As for an M5 not being a good fit, you should reconsider that statement. If you could get a deal on a reasonable M5, you put some PM into in the beginning and it will treat you right. There have been documented cases of E39 M5's going almost 300k miles!! Of course if they are seeing the rev limiter every stop light, do not expect that kind of lifespan.
Fuel pump failures - http://forum.e46fanatics.com/showthread.php?t=929501 Temp Info - http://forum.e46fanatics.com/showthread.php?t=964491 Hidden OBC Menu - Check Voltage, Temps, Fuel Level - http://forum.e46fanatics.com/showthread.php?t=239619 E46/E39 GM5 Door Lock Info - www.bmwgm5.com Lower hose fan switch O-ring - BMW #13621743299 Last edited by jfoj; 10-12-2012 at 10:04 PM. |
#56 | |
Sh1tty Advisor
assume for the worst and buy the car as cheap as possible.
![]() Oops! My Water Pump Broke Again .................... Coolant in a Bottle Last edited by MercForHire; 10-12-2012 at 10:08 PM. |
#57 |
$5400 with 540 Sport with 6 speed.
http://washingtondc.craigslist.org/n...331276447.html
Fuel pump failures - http://forum.e46fanatics.com/showthread.php?t=929501 Temp Info - http://forum.e46fanatics.com/showthread.php?t=964491 Hidden OBC Menu - Check Voltage, Temps, Fuel Level - http://forum.e46fanatics.com/showthread.php?t=239619 E46/E39 GM5 Door Lock Info - www.bmwgm5.com Lower hose fan switch O-ring - BMW #13621743299 |
#58 |
hub dia 74.11 instead of regular 72.56
![]() Last edited by Bemwe_03i; 10-12-2012 at 10:41 PM. |
#59 |
Sh1tty Advisor
e39 wheels work on e46 with hub rings
![]() Oops! My Water Pump Broke Again .................... Coolant in a Bottle |
#60 | |
