Thread Tools Search this Thread Rating: Thread Rating: 1998 votes, 4.91 average.
Old 10-14-2012, 01:44 AM   #12941
MrEmitter
My Ride: 2002 330ci
Originally Posted by RKiepper View Post
Yep, I'm gonna build the E46 as close as I can in this scale and send it off to get a kit made and shipped to me.
AutoCAD?
MrEmitter is offline   Reply With Quote
Old 10-14-2012, 03:08 AM   #12942
RKiepper
My Ride: 1999 E46 328I x2
Originally Posted by MrEmitter View Post
AutoCAD?
Lego designer
RKiepper is offline   Reply With Quote
Old 10-14-2012, 03:09 AM   #12943
MrEmitter
My Ride: 2002 330ci
Lego designer
Old 10-14-2012, 12:18 PM   #12944
JTripper
My Ride: 3dirtyci
Changed My FSU yesterday evening. That little Muthaphuker they call a "hedgehog" is a pestilence to get to, an easy and but awkward DIY. I turned into a contortionist for a hot minute.
Planning to go and clean my ICV now..... any thoughts, advice?
@BMWorNADA
BMWCCA
///MPIREBOYZ#239
1st Gen. AC Schnitzer Strut Bar, M3 Face, Gunmetal VMR V710FF 18x8.5/9.5 , AEM Logger & longtube CAI, H&R Sport Cup Springs and Front Struts, Koni Rears, Reinforced Towers, Int. Trim Wrapped, Custom FX-R Retrofit , 3k Fogs, Frosted WeissLichts, 8 Track Player with Dolby.
JTripper is offline   Reply With Quote
Old 10-14-2012, 12:19 PM   #12945
JTripper
My Ride: 3dirtyci
@BMWorNADA
BMWCCA
///MPIREBOYZ#239
Old 10-14-2012, 12:20 PM   #12946
JTripper
My Ride: 3dirtyci
Thumbs Up
Originally Posted by 98bimmer View Post
Is it worth replacing disa or just getting rebuild kit?
Good question!! I'm thinking of cleaning/inspecting my DISA today along with the planned ICV cleaning. Thoughts and advice welcomed
@BMWorNADA
BMWCCA
///MPIREBOYZ#239
Old 10-14-2012, 12:43 PM   #12947
98bimmer
My Ride: E90 330i, E36 328i
Let me know what you do! Im not sure if mine is gone, i still need to inspect it but if it is.. Im not sure if i should replace it or rebuild it
98bimmer is offline   Reply With Quote
Old 10-14-2012, 02:21 PM   #12948
Hollywood516
My Ride: 02 330i
Originally Posted by Solidjake View Post
Damn man no way
Yep, i spent 2 hours sanding down the worst wheel ( front) it looks much better than it did. I took the wheels off,and I don't see anything bent or broke, so I'm dropping the car off tomorrow to get a real diagnosis of the damage.
Hollywood516 is offline   Reply With Quote
Old 10-14-2012, 04:19 PM   #12949
Imola.ZHP
My Ride: Imola ZHP
Originally Posted by ///MPR77 View Post
.... at 293k miles
Wow! Thats awesome that your e46 is holding up so well! My DISA started malfunctioning at about 80k, as I pulled it out of the car the brittle plastic shattered into a million pieces...
-- '03 330i ZHP
-- Marcus
Imola.ZHP is offline   Reply With Quote
Old 10-14-2012, 04:30 PM   #12950
bmwTuner1
My Ride: Bmw, 330ci
Cleaned it while my dogs watched
Photobucket
Photobucket
bmwTuner1 is offline   Reply With Quote
Old 10-14-2012, 04:36 PM   #12951
zhenkaaaM3
My Ride: Fst'r then your e46
Ouch that blows!
Eugene
Former E36 M3 Owner + E46s
zhenkaaaM3 is offline   Reply With Quote
Old 10-14-2012, 06:46 PM   #12952
///MPR77
My Ride: 02 ///M3 Tri-Ped
Yeah its holding up really well, mainly because I am neurotic with preventative maintenance.
I have had it since 130k miles....so that old DISA has at least 165ishk miles on it.
Old 10-14-2012, 06:57 PM   #12953
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Sorry to hear about your run in with the idiots! I hope it's nothing serious.
Guess you didn't get plate numbers, huh?
GL!
I think mine has 240K on it...haven't replaced it yet and now I feel guilty!
First control arms though! Someone is going to be pissed if mine turn out to be original! We'll see!
Upcoming comedy shows: May 20, Greenwich Village Comedy Club. 6 p.m. See Facebook for other shows and PM me if you can make one...love to see you there!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 10-14-2012, 07:20 PM   #12954
deliroast
My Ride: '02 M3 vert
Coded drl's back on. Flash when unlocked and locked, clown nose. Need to figure out auto lock and I'll be set. Oh and all windows one touch and top up/down from key
Sent from my EVO using Bimmer App
deliroast is offline   Reply With Quote
Old 10-14-2012, 07:24 PM   #12955
BigDRick323
My Ride: 2000 323i
Degreased under engine, hopefully I'll find leak culprit.
Sent from my HTC One V using Bimmer App
Old 10-14-2012, 08:28 PM   #12956
JTripper
My Ride: 3dirtyci
Trouble P0340... I'm a BOOB... over did it!
So I took off my DISA to check it (its good) also to check and tighten all hoses, boots and clamps after I cleaned my MAF (again) TB and ICV. I used MAF cleaner the ICV got freed up a bit, cleaning the TB this way way a waste of time though. I put everything back except the little bracket that connects to that electrical box, the black piece that goes on the same 10mm under the DISA and hooks on the the harness like support. ANNNND MY DUMB ARSE drop the short 10 mm screw thats for the wire harness box. it fell down on to the splash guard got to get a replacement. Other than that everything went ok. But when I start her back up I had a loose clamp in the upper boot, that made my engine light come on tightened things back up and i was fine. So I'm on my OCD cleanliness BS and decide to Seafoam my engine via vacuum/ brake booster line, again. I went inside the house for a hot second (20 mins) to watch my Giants beat up the 49'ers and came back out. She smoked the way she's supposed to and i revved her for about 5 mins after the smoke lightened up. engine ran ok. went back inside for like 20 more mins came back out to go and get my engine code erased and checked and MY Shyt STARTED WIGGING OUT ON ME!!! Sputtering as if she were gasping for air... and then she crapped out on me!
So I chilled for about 10 mins, fired her back up she idled weird then smoothed out, cool. WHEN I DECIDE TO PULL OFF 3,4 mins laters she sputtered n died. left her running for about 10 mins and i was fine. WEnt to auto zone to use their reader and got a code P0340 Now she only has this hesitation it didnt have before.
HELLLLP WTF DID I DOOOO?!
I'm putting the little bracket (that hooks on to the edge of the harness back on in the morning and head to my homeboy's shop to figure this headache now.
@BMWorNADA
BMWCCA
///MPIREBOYZ#239
Old 10-14-2012, 08:30 PM   #12957
///MPR77
GL!
Interested to see what yours looks like when you replace it.
If that was my original DISA I would be really surprised. However I think I would be even more surprised if the PO ever replaced it.
It was definitely one of the most anti-climactic jobs I have done to the car. Initially I was hyper aware of the possibility of placebo effect, and felt no difference on a quick drive around the block, but after driving around today, the car feels a bit more peppy.
Sent from my SAMSUNG-SGH-I727 using Bimmer App
Old 10-14-2012, 08:35 PM   #12958
///MPR77
Check your intake boots, and all other vacuum lines that you worked with on today, and recently.
Maybe when you were revving the engine it disconnected something that wasn't tightened down...clamps etc..
GL.
Old 10-14-2012, 08:38 PM   #12959
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Probably buying a new style 197 wheel with new run flat tire on it for $100. My spare wheel is cracked and won't hold air plus the tire is done.
Old 10-14-2012, 09:36 PM   #12960
///MPR77
Great price.
Rate This Thread
