Forced Induction Forum Sponsored by Active Autowerke
Discuss supercharging, turbocharging and even nitrous and water injection here. Sponsored by Active Autowerke |
#21 | |
Regional Sponsor
Location: Well, Dick, here's the deal: I'm the best there is, plain and simple. I mean, I wake up in the morning and I piss excellence. You know, nobody can hang with my stuff.
My Ride: Is very FAST
![]() Sound Performance 630-893-5002 Cell phone 630-205-6690 IM XXSUPRAXX DO NOT PM ME!! Email me @ XXSUPRAXX@AOL.COM www.spracingonline.com |
#22 |
#23 | |
![]() 04 LSB M3 6sp, BSW stage 1, 19" Forgestar, PSS's, MXP exhaust, K&n intake, h&r springs, koni shocks. 87 rx7 tII 6266 BB .84 a/r in the works 00 Saturn sc2, DD, 36+ mpg |
#24 | |
If it's not too much to ask, could you message me the details of your swap/expenses and where you're getting it done at? Just to sort of give me a ballpark after where I'd be power-wise after I spend a certain amount. Last edited by E46inthe206; 10-15-2012 at 12:06 PM. |
#25 | |
Regional Sponsor
#26 |
I can see what I can find after work...I imagine from google search I'd pretty much just pull up HPF's charts...none of which run that high of boost I don't believe lol.
#27 |
#28 | |
Regional Sponsor
That does not help as it is an 82 mm turbo!! Here is the same turbo on a 2J !!
#29 |
craigs car is a dyno standout for sure.
Engine control is very simple and straight forward on a 2JZ. The cams arent even being controlled in current E46s by the aftermarket ECUs. I gained 60-80whp just by changing my cam angles over stock, and that was just intake cams on a VQ. There is so much power being left on the table with current E46 tunes that do employ full vanos control with aftermarket cams Def would love to see a E46 with a 5" fender cutout exhaust where the vent is now
VQ38DETT on twin 6262 with ProEFI128
#30 |
What I like best about this car is that there is literally NO smoke coming out of the back of the car. Well built and perfectly tuned! SICK
#31 |
there is no smoke out the back because the exhaust exits in front of the passenger door.
#32 | |
Regional Sponsor
There is no smoke coming out of the front either!!
#33 |
alcohol FTW!
#34 | |
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
#35 | |
HPF has this recommendation that sleeved be used in their stage 4, however they had 1k whps being produced by a non-sleeved block if memory serves. Even with the extra boost pressure required to overcome the possible exhaust manifold restriction, it didn't seem to compromise the 0.020 over-bored setup they ran. So maybe sleeves are optional on an S54 setup targeting just over 1k whp. I may be wrong about this so feel free to chime in anyone. Perhaps these manifold restrictions has been resolved in their drag setup, but the dyno readings through the TH400 auto doesn't really compare well to the 6spd, especially with that torque convertor. Does anyone know more about that? PS, what angle is that S54 slanted at? Does anyone know for sure? |
#36 | |
NO, there is no smoke because it is tuned perfectly and there is no leakage of oil from ANY part of the motor build OR the turbo seals. Last edited by boostedisbetter; 10-15-2012 at 03:19 PM. |
#37 |
Don't forget if the car is off it doesn't smoke at all. Lol
#38 |
LOL, I hope your joking or you are missing the point along with the other guy lol. You hardly EVER see a dyno-tune where the car doesn't spit a little rich smoke. This thing is PERFECT!
#39 | |
even stock turbos have some smoke Great work on a nice build
#40 |
Regional Sponsor
Thanks guys!
