Old 10-15-2012, 03:58 PM   #1
Mormon
My Ride: 2001 330xi
Shifting help
I own a 2001 330xi Automatic with an AA stage 1. I keep having a problem when shifting at high rpms starting in 2nd gear. Around 6000 rpm if I try to shift the transmission will hold at that rpm for around 4 seconds and then shift. after shifting the transmission light will come on and the transmission will shift rough until I turn the car off.
So I used INPA and it gave me :
146 CAN Moment interface.
I have changed the transmission fluid and filter. I can't find anything on that code. Please help
Mormon is offline   Reply With Quote
Old 10-16-2012, 06:15 PM   #2
Mormon
My Ride: 2001 330xi
Bump
Old 10-27-2012, 01:39 PM   #3
Mormon
My Ride: 2001 330xi
bump
Old 10-29-2012, 11:34 AM   #4
Mormon
My Ride: 2001 330xi
bump
Old 10-29-2012, 11:57 AM   #5
FragNasty
My Ride: Car
Every time that error shows up its at 6176 rpm. I have changed the transmission fluid and filter. I can't find anything on that code. Please help
Is the transmission related firmware/software up to date? Has it been modified in some way?
Has your car always exhibited these characteristics or is the problem new?
Have you posed this question to the AA guys? Could it be AA related?
Are we correct to presume that shifting occurs correctly at say 5k RPM or even 5.5K and that these problems occur specifically at 6k or 6.176k?
Are you somehow "controlling" the shifts by initially selecting D4 (or whatever it may be) then moving the leaver to D3 thereby "signalling" the shift to next ratio?
FragNasty is offline   Reply With Quote
Old 10-29-2012, 04:26 PM   #6
Mormon
My Ride: 2001 330xi
I'm not sure if the tranny software is up to date, but it has not been modified in any way.
The problem appeared about 4 months ago. I sent a message to AA about a month ago and have not gotten a message back.
There is no problem shifting below 6k rpm, but after that the problem occurs.
I can have the car in Drive or steptronic, but the outcome is the same.
Old 11-07-2012, 03:56 PM   #7
Mormon
My Ride: 2001 330xi
********************** Update ****************************
I just recently fix a few vacuum leaks hoping that it would fix the problem, but its still there.
Altho the holding at a certain RPM has stopped, After the shift it still gives me a transmission light and shifts rough.
I scanned the car with INPA and I got 2 codes.
8 Air Flow Meter
Error frequency : 11
Logistic counter: 40
N_32 6336.00 rpm
THR 60.21 Grad TPS
ISAPWN_ISA 94.92 %
VMAF 4.88 V
aufgetreten vor (rel. BZ) 1.30 h
ks--> ubatt
Error to relevant
Error debounce
Error currently not available
sporadic Error
146 Can Moment interface
Error frequency : 1
Logistic counter: 0
KM value 225330.00 km
Changing gear 1.00 0/1
Last Change: Changing up 2->3 33.00 0-n
Engine speed 6112.00 rpm
throttle-valve angle 100.00 %
General error
Sporadic error
If anyone has any suggestion please let me know.
Old 11-07-2012, 04:39 PM   #8
FragNasty
My Ride: Car
http://forums.bimmerforums.com/forum....php?t=1784065
The last post suggests replacing the MAF. You may examine the sensor to determine if cleaning it would be any good.
I hope this helps.
8 Air Flow Meter
N_32 6336.00 rpm
THR 60.21 Grad TPS
ISAPWN_ISA 94.92 %
VMAF 4.88 V
ks--> ubatt
Error to relevant
Error debounce
sporadic Error
Error frequency : 1
Logistic counter: 0
General error
Sporadic error
Old 11-11-2012, 06:39 PM   #9
Mormon
My Ride: 2001 330xi
Today I replaced the maf sensor and the problem is still there. Any other suggestions?
Old 11-13-2012, 09:13 AM   #10
Jim Murphy
My Ride: 2006 E46 330Ci ZHP
Time to go to an automatic transmission specialist as I am about ready to ship mine to IPT - they have pickup and delivery service as well. Mine now slips in 2/3 and 3/4 shifts, just too much power for my ZF transmission.
Jim
Jim Murphy is offline   Reply With Quote
Old 11-13-2012, 09:55 AM   #11
MaverickM3
My Ride: gets badge
Jim
That's what I was thinking with his. Maybe his isn't holding enough pressure to make a proper shift.
MaverickM3 is offline   Reply With Quote
Old 11-14-2012, 03:10 PM   #12
Jim Murphy
I am letting IPT determine what needs to be fixed/upgraded as I don't want to try to fix it locally and it ends up being time/money wasted. We will know when it is back and installed.
Jim
Old 11-15-2012, 05:19 PM   #13
Mormon
My Ride: 2001 330xi
Jim
Let me know how that goes. I have been thinking about sending my transmission to IPT.
Old 11-16-2012, 09:45 AM   #14
Jim Murphy
I will be glad to update here. IPT has a contract with a trucking company so that all that is needed is for the transmission (completely drained, of course) to be mounted on a pallett and protected (covered up) and the trucking company will pick it up. Later the same trucking company will deliver it back.
Jim
Old 11-28-2012, 03:09 PM   #15
Jim Murphy
IPT says it needs the whole works to hold up to the increased torque - torque converter, valve body and rebuild/upgrade transmission - mucho money. I should have it back by the end of next week.
Jim
Old 12-06-2012, 03:02 PM   #16
Jim Murphy
IPT is behind due to the hurricane, more later.
Jim
Old 12-06-2012, 07:14 PM   #17
always-there
My Ride: 2002 BMW 330I
Jim
Time to upgrade the valve body. There are kits that'll aid in quicker shifting so you don't over-rev while shifting the auto.
Old 01-02-2013, 02:46 PM   #18
Jim Murphy
Back-ordered BMW parts should arrive today - I hope. Way too long.
Jim
Old 01-12-2013, 01:08 PM   #19
Jim Murphy
Transmission was delivered yesterday late at BIP. I should know more next week. It has been two long months.
Old 01-15-2013, 01:34 PM   #20
Jim Murphy
I expect to pick up the car tomorrow afternoon.
Jim
