Old 09-02-2012, 07:56 AM   #1
rbrthh
My Ride: 2002 330ci
Getrag 6 speed in 2002 330ci
has anyone else out there matted a getrag 6 speed with the M54 engine? if so what type of clutch and flywheel did you go with?
rbrthh is offline   Reply With Quote
Old 09-02-2012, 08:27 AM   #2
daniel_f.
My Ride: 330iC
well, as 6speed and m54 was an option since facelift here in europe, there should be several usable combinations.
just have a loot at bmwfans to see the part numbers.
Old 09-02-2012, 09:40 AM   #3
rbrthh
My Ride: 2002 330ci
awesome, thank you!
Old 09-02-2012, 08:34 PM   #4
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
If you're getting the non-M 6sp that was mates to the M54, you options are severely limited. That box uses an input shaft spline that is unique.
I have the UUC flywheel/clutch. It's pretty good but does rattle.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 09-04-2012, 08:25 PM   #5
genuity
My Ride: 2001 330iS
Yes. Went with dual mass flywheel and Sachs race engineered performance clutch system. Many would say stiff clutch pedal, but the heavier the better, at least for me It was mated to a pre-facelift, but should fit all M54s. Let me guess, you found that 6sp pulled from a Z4?
genuity is offline   Reply With Quote
Old 09-07-2012, 12:52 AM   #6
wanganstyle
My Ride: e36 M3 / E30 GTS1
I put a ZF 6 speed into my e30. its clutch compatibility is vast:
22 spline involute style is shared between a bunch of cars from 2004-2009:
e60 530i
e46 330zhp/325ci smg
Z4 3.0 and Z4 3.2M
E90 325/330i
common parts really; anyone can buy an aftermarket or OEM setup pretty easily
Billet Original CNC LSD for 188K
http://www.wanganstyle.com/
S54B32 E36 M3 DTA S100 Sedan Street car full swap:
http://forums.bimmerforums.com/forum....php?t=1437471
E30 M20 2,7L Alpina + Euro E46 320D ZF 6 speed install
http://www.e30tech.com/forum/showthread.php?t=110010
wanganstyle is offline   Reply With Quote
Old 09-15-2012, 11:43 PM   #7
TerraPhantm
My Ride: M3 & ZHP
Are you sure the Z4M 3.2 input shaft is the same as the rest? Just because it's also a GS6-37BZ doesn't mean much. If it is the same, using a z4m pilot bearing should allow a much wider selection of flywheels
My understanding was that although the z4m has a 22-spline count like the other variants, the M has thicker splines (kind of like e46 M transmission compared to earlier S6S420Gs)
Old 10-15-2012, 03:56 PM   #8
wanganstyle
Z4m clutch is direct interchange with 135/335 and 330zhp also. I have mixed these all up and actually have a few setups crated up to ship overseas.
In my e30 I ran:
2006 zf6mt
335 turbo clutch
330zhp flywheel
Photos are on e30tech somewhere
Old 10-17-2012, 01:34 AM   #9
TerraPhantm
My Ride: M3 & ZHP
If that is truly the case I'd probably run the Z4M pilot bearing (which is separate from the flywheel unlike all the other variants with the GS6-37BZ) to enable a much wider section of flywheels (Z4M itself uses the same flywheel as the E46 M3).
Unless you personally verified it though, I have my doubts. I remember reading a few posts on Zpost where it was confirmed the Z4M 6-speed had a different input shaft than the rest of the GS6-37BZs. I have no doubt you can run a 335 clutch with a 330 flywheel on a 320d transmission. But the Z4M gearbox itself is the wildcard from what I understand
Old 10-18-2012, 09:47 PM   #10
wanganstyle
I have a z4m flywheel here. It's the same standard as 330zhp; dual mass with needle bearing in it and 240mm self adjust style. 320d is the same 240mm standard. The e60 545i also shares this standard for pressure plate and friction disc iirc
The z4 3.0 has a flywheel/friction disc and pressure plate for 228mm
Most likely you have gotten mixed up on this issue. I bought a z4 3.0 full driveline/clutch setup as well so it was easy to compare
The pilot bearing is removable for all of them, you can order it via part number. Check real Oem if looking for it
Old 10-20-2012, 02:38 AM   #11
TerraPhantm
My Ride: M3 & ZHP
Well since you apparently have all the parts on hand, I guess I'll go with your assessment.
I would like to note that the Z4M uses the same flywheel as the E46 M3 (same part number) along with the same pilot bearing as all the older BMWs (I was wrong there). But in any case, that led me to believe that the transmission side may have been different enough for BMW to use a different design (otherwise... why didn't they just use the same style clutch on the 330 6-speeds and stick with the old 5-speed flywheels? Guess we'll never know).
Old 10-22-2012, 03:29 AM   #12
wanganstyle
The new everything is revised, more efficient. New patented tooth pattern on the spline for gearbox, new style needle bearing pilot bearing in the flywheel; Trans input shaft is shorter now.
New style flywheels also are for self adjusting clutch setups
