Thread Tools Search this Thread Rating: Thread Rating: 156 votes, 4.74 average. Display Modes
Old 10-23-2012, 03:50 PM   #161
Beamer Creamer
My Ride: 2005 bmw m3
I know what you're doing too. You should be ashamed of yourself!
I find Dex III in the stores...and as I still can, I'd just say take the conservative route. Use the fluid BMW tells you to use. It knows more than us. Nothing personal, anyone, but as soon as a discussion goes, "well I heard that such and such is okay too," I remember I'm on the Internet, where facts can get created very easily. Not that it isn't worth researching if you're interested, but it's a lot of work you don't need to do.
Dex III for PS AFAIK is still the recommended fluid.
Also, didn't read this yet, but just want to add: OE,OE,OE
I usually agree with the do it all oem only, but as much as i know bmw masterminds are smart i also know that they say " lifetime" diff and trans and changed the m3 oil from 5w30 to their own 10w60 for $15 a liter, plus have recalls..... So study for yourself also but most oem is good advice
Beamer Creamer is offline   Reply With Quote
Old 10-23-2012, 03:53 PM   #162
Beamer Creamer
Originally Posted by VALMONT View Post
front control arm bushings, what do they last 50k?
Different for every car and every driver. Im not sure why so many guys are into changing all their bushings when nothing is wrong with them. Could someone else explain why to replace if there is no clunks, squeeks, torn rubber or car doesnt feel right?
Old 10-23-2012, 03:55 PM   #163
My Ride: Lexus
Just as you say, different for every car and every driver.
Old 10-23-2012, 03:55 PM   #164
My Ride: Lexus
I sure hope you're using 10W60 on your M3.
Old 10-23-2012, 03:59 PM   #165
Beamer Creamer
Mango,
I've got to register a complaint with your comment "it's fine to put in 8 qts."
I've always said here, based on what I've read (a lot) that it's better to be a quart low than over a 1/4 quart high...which is the top of the top notch.
The capacity is 6.9 quarts, so 7 is fine. 7.9 is capacity for an Xi I believe, so 8 qts. is fine there.
But 6.9 qts. or 6.5 L is capacity for most e46s and I think if you're going to recommend a proper amount, you should just do so. Don't make someone reading think the capacities are just suggestions.
If you edit, let me know and I'll turn this post into a glowing review!
Of course proper amount is proper. But i would say drain some out if near a liter over. More is better than less cause you cant do much worse damage than a scored cyl or roasted bearing.
Old 10-23-2012, 04:00 PM   #166
My Ride: Lexus
I see Beamer Creamer is getting around to reading my threads. +5mp for you.
Old 10-23-2012, 04:06 PM   #167
Beamer Creamer
[QUOTE=KSims1868;14421062]Great write up.
Question - is there an externally visable way to tell if the VANOS seals have been changed on a used engine? I'm guessing "no"...and I need to look through the maintenance records to see if this has been addressed on my car.
I know it just had oil changed (but the dash still flashes that oil change warning on start-up), air filter, tires, and fuel pump/filter. Tonight I'm getting into the corners/tails to clean any corossion and apply di-electric grease to get that dang blinker warning light off my dash. Then later this month I'm finally going to get around to those dang A & C pillars...stupid headliner just won't stay glued here in Texas. Gotta get stronger glue and material. Last year the cooling system was done, so I'm good there. I know the auto trans has NOT been serviced, so that's on my "to do" list this year at some point.
Next things I'm doing is to run the seafoam through it, change the plugs, and I might take a look at those bushings. I wonder if I can tell if they're OEM or have been replaced? I know the car feels much tighter than other models I've driven, but there's prob no way to know. ...........................beamer creamers lame insert(Why seafoam and bushings? Not many have heard the old saying " nobody moves, nobody gets hurt".... I mean " if it aint broke dont fix it or you might just make a new more expensive actually has to be fixed problem" just sayin)
Old 10-23-2012, 04:16 PM   #168
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Beamer Creamer...
Seafoam frightens me...just saying. Be careful, read a lot of threads on it. Personally I use Techron, much milder, but gets the job done. Also, you'll need it if you want to join the cult...we ignite Techron on our forearms to form a roundel. Have ice handy.
Also, please come into my 'autophiliac' thread and speak a little bit about it for us. I'm proud you're so up front with your bimmer sexuality. Maybe with you being here, more can come out and talk about that kind of stuff. I think it'd be good for you.
See me in June!
dmax on Facebook
Mangofy your E46!
Old 10-23-2012, 04:31 PM   #169
Beamer Creamer
Thanx. How do you put piks from ipad onto here?
Old 10-23-2012, 04:36 PM   #170
Beamer Creamer
Beamer Creamer...
I just rev to 8000 several times everytime i drive car and let it "naturally" suck the shtuff through. I may look into techron but not a fan of additives, especially cleaners in oil changing viscosity
Old 10-23-2012, 05:35 PM   #171
dmax
dmax's Avatar
Ah, there you go. Techron is added to the fuel, not to oil, and is, identical to the BMW fuel system treatment.
Not to be taken internally!
Have you gummied your car yet? Please post in my autophilia thread.
See me in June!
dmax on Facebook
Mangofy your E46!
Old 11-07-2012, 01:16 AM   #172
noc0de
My Ride: 2004 325i
Thanks for this, but why on earth would you change you cabin filter every 15k? Just buy an air freshener!
noc0de is offline   Reply With Quote
Old 11-07-2012, 01:53 AM   #173
deepblue7
My Ride: f30
Just bought your E46?
You just bought your non-M E46 (323/328, 325/330) and you are probably wondering: What do I do now?
Lets start with the basics, shall we?
Engine oil
Change your engine oil and filter anywhere between 7,500 and 12,000 miles. You can likely go up to 15,000 miles without any problems as our cars hold 7 quarts, however for peace of mind, follow the 7,500-12,000 guideline.
Per the BMW owner's manual, you should check the oil level 5 minutes after a hot engine has been shut down. The dipstick is calibrated to read accurately after 5 minutes has passed.
Note: If you track your car, love to drive in a spirited matter, and/or experience lifter tick noise, it is common practice to overfill by one quart for a total of eight quarts.
You should be using oil with a specification ACEA B3/B4 (extended drain/high performance criteria) and/or LL-01. The following oils are the most readily available proper oil for your car:
Genuine BMW 5W-30
Castrol European Formula 0W-30
Mobil 1 European Formula 0W-40
Pennzoil Ultra 5W-40 European Formula
Oil Filters
You can use any OE-spec parts store filter in a pinch, but I recommend using Mahle or Mann OE-quality/OEM filters.
Mahle supplies filters to BMWs for their ///M cars. Mann supplies for non-M. Both are fine but I prefer Mahle--the quality seems more robust/high-end. Part number: 11427512300
Spark plugs
Replace every 60,000 miles (BMW says 100,000) NGK BKR6EQUP (6)
Fuel filter
OEM Mahle. If your upper intake boot has an "F" connector with a vacuum line attached, your car has the integrated fuel pressure regulator. Most E46s come with this. I believe the M56 SULEV 325 cars use the plain in/out filter. Do this every 50,000 miles. Part number: 13327512019
Differential oil
Synthetic 75W-90 gear oil such as Mobil 1 75W-90. Your non-LSD diff holds approximately 1 quart. Do this every 50,000 miles
Transmission oil
Automatic:
You should change your automatic transmission fluid and filter with OE or OE-spec'd high-quality fluid every 50-75k miles. The type and amount of fluid will depend on your year/make/model. I will list the various types of automatic transmissions and their corresponding fluid:
323i/iS/iC 7/98-3/00, 328i/iS 6/98+ - GM 5L40 (A5S 360R) Texaco ETL 7045E, supercedes ETL 7045, BMW part number: 83220026922
323i/Ci 3/00-8/00, 325i/Ci/Cic 8/00+, 325iT 3/01+, 330i/Ci/Cic 6/00+ - ZF 5HP19 (A5S 325Z), Esso ATF LT 71141, BMW part number: 83229407807
325xi/xiT 8/00+, 325iT 8/00+, 330xi 8/00+ - GM GM5 (A5S 390R), Texaco ETL 8072B, BMW part number: 83220024359
Manual:
BMW MTF-LT-2[/URL], equivalent Pentosin MTF2, or other equivalent. I use Redline D4 ATF. You can also use Redline MT-90.
Air filters
These should be replaced at roughly every 15,000 miles. Use Genuine/OEM Mann. Part number: 13721744869
Cabin air filter
These should be replaced at roughly every 15,000 miles. Part number: 64319071935
Clean idle control valve
http://www.bmw-planet.com/2009/01/10...-cleaning-e46/ Clean every 50,000 miles. If needs replacing, part number: 13411744713.
You might want to replace the rubber boot which seals it to the intake manifold. Part number: 11611437453.
Clean throttle body
Couldn't find a DIY, but personally I recommend cleaning it. From the outside (front) mine appeared to be spotless.
The backside was a VERY different story. Use throttle body cleaner. Requires removal of the airbox, upper and lower intake boots, and electrcial wire junction box. Four bolts hold it on. Replace the rubber throttle body gasket. Part number: 11611716174
DISA
This part can also cause vacuum leaks. It works by altering the volume of the intake manifold depending on engine operation/speed. Remove and inspect yours to ensure the flap is not loose.
You should feel resistance as you manually operate the flap. There should be no excessive noises or rattling. Part number if you'd like to replace: (courtesy of JFOJ)
325/2.5L engines currently use BMW Part #11617544806, which appears to have superseded an earlier BMW Part #11617502269
330/3.0L engines currently use BMW Part #11617544805, this appears to have superseded an earlier BMW Part #11617502275
323/328 - 2.3L & 2.8L engines appear to currently use BMW Part # 11611440049
Reseal or repair using: http://germanautosolutions.com/DISA_...epair_Kit.html
Brake fluid
You should completely replace and bleed your brake system every two years or 25,000 miles or more frequently if you see track use or have overheated your brakes/fluid. I recommend ATE Super Blue (or amber if you had blue last) :
http://www.ecstuning.com/BMW-E46-330...d/A/ATE/ES111/
Valve cover gasket
Major source of leaks. If the front or passenger side (right side) of your engine is covered in oil, then your valve cover gasket is leaking. By 60,000 miles, these are hard, dry, and brittle. Use Permatex Ultra Black at half moon areas and vanos seams. LESS IS MORE. Use very little sealant. Don't forget the 15 rubber grommets: part number: 11121437395. Up to 9/02, part number 11129070990 and 9/02+: 11120030496. If you experience repeated leaking, your valve cover could be damaged or warped.
Oil filter housing gasket
Major source of MAJOR leaks. The left side of the block will be wet and you'll have puddles in your driveway. Replace when leaking. Part number: 11421719855
Vanos line
Do this when you replace the oil filter housing gasket. Part number: 11361705532
Also replace four 14x20 copper sealing gaskets, part number: 32411093596
Power steering
Use ATF Dexron III only. Replace reservoir as it has integrated filter. Part number: 32411097164
Also trim and re-clamp (using new universal clamps) the power steering lines to the bottom of the reservoir and to the return line at the pump. The BMW clamps get loose over time and oil leaks/seeps out.
Exterior/interior
Of course, clean the exterior/interior and engine compartment. There's nothing worse than a dirty car with an engine compartment full of leaves, debris, oil, spiders, and dead rats. Cleaning also can help reveal problem areas or parts that are leaking. A clean engine is also more satisfying to work on.
And of course, last but not least, the cooling system.
http://forum.e46fanatics.com/showthread.php?t=914109
These are the absolute bare essentials. There's still the suspension, drivetrain items, bushings, etc. But the above list should be the first things you do.
If there's any inaccuracies, things left out, etc. feel free to add. I'll then put this in my sig and link it to anyone who is interested.
BONUS:
Suspension Refresh Guide
If this guide has helped you, let me know in the comments.
I have done all of them.
To check/replace the serpentine and a/c belt and the 3 pulleys and 2 tensioners should be added to the list.
Belts and the tensioners last longer, but oem Bmw bearings (INA) last only a few years or 30-40,000kms then they start to rattle which is insane.
deepblue7 is offline   Reply With Quote
Old 11-07-2012, 10:52 AM   #174
My Ride: Lexus
+25mp. Good job.
The belts/tensioners are part of the cooling system and should be done when following that guide. That's why I say see sig, do it all!
Old 11-13-2012, 11:55 PM   #175
Wookiee Cakes
My Ride: 2003 330i Zhp
I fudgin' love this thread.
Totally new to this DIY thing.
Gonna need tons of help
LOVE
this
thread
'03 Zhp Sedan
Aux Input, UUC Strut, AFE Stage 1, R1 Drilled Rotors, SS Brake lines, SS Clutch, Modified CDV <--the best
Wookiee Cakes is offline   Reply With Quote
Old 11-14-2012, 12:11 AM   #176
325inthe510
My Ride: 152ci of madness
I'm doing all of this plus a cooling system refresh this weekend
MY BODY IS READY
325inthe510 is offline   Reply With Quote
Old 11-15-2012, 05:27 PM   #177
My Ride: Lexus
Thread updated to reflect the electrical system. Battery, voltage regulator, and final stage resistor. Three things that can give you headaches. These three NEED to be replaced upon purchasing a used E46.
Old 11-15-2012, 05:28 PM   #178
My Ride: Lexus
LOVE
this
thread
Thank you sir. You are off to a good start. Never hesistate to me ask any questions that haven't already been answered here.
Old 11-15-2012, 05:30 PM   #179
My Ride: Lexus
This unstickied thread has over 23,000 views in the short time it's been in existence. I'm guessing it's been helpful to getting people started with their proper ownership of the E46. If there's room for another sticky, I feel this would be appropriate.
Old 11-15-2012, 08:34 PM   #180
dknightd
My Ride: 2002 330 cic
I'd strongly suggest you stick to specified levels. Don't go over, don't go under. You might get away with going slightly over on oil level, I'd like to see a reference from e46mango, or anybody, but if you go too far the oil will likely be foamed by the crank. I don't know what the tolerance is in your bmw engine, probably they are all a little different, but, if you are above the top of the full mark you might be asking for trouble. Foamed oil is basically useless - I guess it is better than no oil, but not by much. Overfilling an engine with oil can kill it just as quickly as under filling. There is a reason they mark min and max. Based on what little I've learned about these cars so far, I'd rather run them close to min than above max. It seems to be the way they are designed.
This is especially true with the cooling system. Keep the level between min and max. In fact, make sure it is always below max.
dknightd is offline   Reply With Quote
