E46 Convertible
The E46 vert forum. Talk about dropping your E46 top here. |
#1 |
What is this?
I took my back seat out to replace my rod covers and found this laying in the right seat well. It looks like a proximity sensor. Anyone have a clue?
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” |
#2 | |
#3 |
Could it be part of the alarm system - even if your alarm is not the 'enhanced' type which senses movement inside the car?
#4 |
I have movement sensor, works fine. Im pretty sure i checked it for power when looking for keyed power for sub amp( nothing there). I'll check into it more when back home
#5 |
After reading djsilver's and fmzip's posts under "Convertible top electrical troubleshooting tools", I suspected it is a storage compartment cover motor hall sensor (S700). It is. You can see the sensor I found, sitting next to the one in the car.
Not sure why I have an extra one. Apparently, they don't go bad. If anyone needs one, PM me and I'll send it to you.
